Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Problem wd7500bmvw-11ajgs2
PostPosted: July 5th, 2018, 14:09
mhp666 wrote:
I explain the steps of firmware that I have made.
I remove the HDD PCB.
power on -> disable module 411 -> power off
I put the HDD PCB.
power on -> Resolve slow response -> power off
power on -> enable module 411 -> power off
Correct detection
In my case if I did not remove the HDD board, I could not deactivate module 411, I preferred this to the short circuit, since with the isolated PCB it managed the ROM modules without problems.
Is this a joke ? :shock: :shock: :shock:
If you remove the PCB and if you disable module 411 with the PCB without any drive how the hell does MRT writes to SA to disable module 411 ?
Unless that function is changing something in ROM like changing FW zones the procedure doesn't make much sense ....
PostPosted: July 5th, 2018, 14:44
It is indeed a module of the ROM.
In my case I had to remove the hard disk board to disable the module 411.
In other cases it is not necessary.
Leaving the plate isolated takes a few minutes to enter RDY.
It was a great idea that gave me ddrecovery.
Greetings.
PostPosted: July 5th, 2018, 14:47
It may be that the module is in the SA, but that you deactivate it in the ROM.
I do not want to give a lot of data in case I'm wrong I'm short on knowledge.
PostPosted: July 5th, 2018, 16:20
Ok ... Whatever ....
Nice that you did get your data back ... You must be a very lucky guy ...
PostPosted: July 5th, 2018, 22:39
I put the HDD PCB.
Correct detection
@mhp666 your process is correct, and there are simpler methods--short circuit or use jumpers, after disk ready, then disable module 411.
Disable module 411 wont write SA, why are you so sure that it needs to write SA? Did you have a try? I did try on both PC3k and MRT, PC3k not yet has this function, but MRT does.
PostPosted: July 6th, 2018, 8:50
mrtlabinfo wrote:
@colanco Seems you have already used our new function of "Disable 411 module", which is really easy in operation and powerful in function;
Yes, the truth does nothing new but it makes the process much simpler. It's a good function.
There are some interesting things in this new update. Good job.
The difference with PC3K is still important, but with serious upgrades like this, the distance is getting shorter
PostPosted: July 6th, 2018, 9:42
I had intended not to put any more comments on this absurd thread.
But the way things are going I wouldn't want other new users to believe that this gentleman has recovered something.
mhp666 YOU HAVE NOT RECOVERED ANYTHING (nor will you), you have destroyed and thrown away the data of at least two clients, who are you trying to mislead?
As far as the drive of this thread is concerned, you have successfully recovered 275MB of a total of 678GB and destroyed 677GB of a total of 678GB, that is data recovery?
PostPosted: July 6th, 2018, 10:04
Colanco, I do not want to argue.
What you want to believe or guess is your business.
I am here to learn and what I can help.
A greeting.
PostPosted: July 6th, 2018, 13:31
reco wrote:
(...)Disable module 411 wont write SA, why are you so sure that it needs to write SA? Did you have a try? I did try on both PC3k and MRT, PC3k not yet has this function, but MRT does.
I don't have MRT with me but I will check it out next time if i have to work with one of those MRT units.
Regards.
PostPosted: July 7th, 2018, 14:50
Regards.
you'll have to check it out on a drive who does have MOD 411 (some doesnt)
PostPosted: July 7th, 2018, 17:11
Ok, thanks !
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 39 guests
