 Post subject: ST3000DM001 still clicking
PostPosted: July 12th, 2018, 2:55
Hi everyone,
I have the typical case of this ST3000DM001 clicking hard drive. I replaced the heads but still clicking (the usual 11 clicks).
Original heads were dirty so media must be damaged. I can see a nice scratched part of the first platter.
I could assume that heads get fucked up over and over again when they passed that area... right? Seems to be.
 Post subject: Re: ST3000DM001 still clicking
PostPosted: July 12th, 2018, 5:50
If the P/N of the disk is: 9YN166-xxx you can assume that all the drive is a sh*t (like almost everything that comes from the seagate factory)
PostPosted: July 12th, 2018, 11:27
If you can see damage on a ST3000DM001, just assume it's a lost cause. Usually always is.
PostPosted: July 12th, 2018, 13:34
can you get a read out of the other surfaces? Is it salvageable?
PostPosted: July 12th, 2018, 16:38
Nope, heads get ruined with the disk itself
PostPosted: July 13th, 2018, 15:03
Yes. So you should physically delete heads on damaged surfaces to be able read other surfaces.
PostPosted: July 13th, 2018, 15:19
:good: +1
http://www.rescue-it.se
PostPosted: July 17th, 2018, 14:59
Don't expect to recover anything larger than 5-10 mb in size... if it's pictures and documents you should be ok with at least some files. If the scratch is on the top platter, the chances are not so great, but still worth a try.
Yevgeniy. No, NOT Malkin.
Ambassador at ADRS®
Users browsing this forum: Google Adsense [Bot] and 9 guests
