Post new topic Reply to topic  [ 134 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
 Post subject: Re: WD80EFZX-68UW8N0 support ?
PostPosted: August 5th, 2018, 13:53
BGman wrote:
unknown wrote:
What I mean that you are not doing data recovery for bread and butter?
How could you survive all this years with 20-30$ maximum per case if this only your mainly profession?
I used to repair computer parts like mobos, video cards, monitors, hard drives, etc....I didn't rely on DR for bread and butter, only for peanuts...
So, data recovery isn't your main. You didn't invest on Tools (head replacement tools, clean room, PC3000,donors, R&D.....etc).
How could you judge on others if you are not working on a real data recovery business?
PostPosted: August 5th, 2018, 14:11
Online
Take your pills and go to bed...
PostPosted: August 5th, 2018, 14:25
I have proved my point.
Good night. :)
PostPosted: August 5th, 2018, 20:01
I notice that WD/HGST is using the same PCB design for both its SATA and SAS models. I wonder if the kernel code is the same, in which case it may be possible to use the SAS PCB + SATA ROM for data recovery.
I'm also wondering what additional hardware (other than a piezo transducer) could be responsible for the increased pin count in the HDA connector (28 pins).
PostPosted: August 5th, 2018, 20:23
I think no, because SoC will be switched to SATA mode by the ROM and SAS interface is not compatible with it.
Newer drives have humidity sensor inside.
This particular drive also has Helium sensor(no idea how it works)
https://www.linkedin.com/in/artemrubtsov/
PostPosted: August 5th, 2018, 20:47
How new is "newer"?
I did some investigating in the following thread:
Helium level sensors - where/what are they?
viewtopic.php?f=1&t=35770
Seagate claims that "except for a low accuracy thermistor for temperature measurement, the HGST helium drive has no digital environmental sensors".
A WD patent explains how a cheap thermistor can be calibrated to monitor the helium level.
Seagate states that its helium drives use "high-accuracy digital MEMS sensors for measuring temperature, pressure and relative humidity."
PostPosted: August 5th, 2018, 20:55
I'm also curious about the helium drive at the following site.
Seagate IronWolf Pro 12TB HDD Review | KitGuru (helium):
https://www.kitguru.net/components/hard-drives/simon-crisp/seagate-ironwolf-pro-12tb-hdd-review/2/
https://www.kitguru.net/wp-content/uploads/2017/11/Seagate-Ironwolf-12TB-Hard-Drive-Review-on-KitGuru-PCB.jpg
Its HDA connector (J2) has 28-pins whereas Seagate's ST8000AS0002 air drive has 24 (J4). The air drive has 2 differential pairs (read and write channel) while the helium drive has 4 such pairs. Does anyone have any idea what is going on inside this helium drive? AFAIK, Seagate's dual actuator drives have not yet hit the market.
PostPosted: August 6th, 2018, 2:10
Are we talking about the same thing?
    SATA HDA + SATA ROM + SAS PCB <--> SATA HBA
Could this combination negotiate a link?
    SAS HDA + SAS ROM + SATA PCB <--> SAS HBA
PostPosted: August 6th, 2018, 9:54
How new is "newer"?
4-year old Seagates(like Crawford) have them, IDK about other drives
PostPosted: August 6th, 2018, 9:56
Could be 2D-recording. I think Seagate have those already.
PostPosted: August 6th, 2018, 18:35
So that would suggest that each head has 3 read elements and 1 write element, yet Seagate's documents talk about 2 read heads. :?
PostPosted: August 6th, 2018, 23:05
Well, usually people say "thank you" but you can have it you way.
PostPosted: August 7th, 2018, 0:48
I don't understand why my observation has put your nose out of joint. Of course I'm grateful for any information. I'm simply pointing out that your explanation is inconsistent with Seagate's "documentation", as sparse as it is. That said, I believe you are probably correct, so either there are 3 read elements per head (as published in at least one patent), or there is an extra differential pair whose function is unknown to us.
BTW, I don't understand why Seagate would need a humidity sensor in a "sealed-in helium environment". Perhaps that's another error in the documentation?
PostPosted: August 7th, 2018, 2:27
Perhaps to detect, whether that environment is still sealed and not broken?
(I don't know, but I guess reversing the firmware and taking a look what it does in the firmware with the results of that sensor might help)
PostPosted: August 7th, 2018, 3:54
The KitGuru review makes no mention of TDMR in respect of the 12TB IronWolf drive, nor do Seagate's datasheet or product manual.
https://www.seagate.com/www-content/product-content/ironwolf/en-us/docs/100818527d.pdf
https://www.seagate.com/www-content/datasheets/pdfs/ironwolf-12tbDS1904-9-1707US-en_US.pdf
However, the new 14TB Exos is being promoted as a TDMR drive.
I found this Seagate patent to be helpful:
Multi-sensor data transducer:
http://patentimages.storage.googleapis.com/pdfs/US20150043098.pdf
In some embodiments, a processing circuit evaluates the sensor signals from the respective sensors and selects a best signal for use in decoding the data. In further embodiments, the sensor signals from at least some of the sensors are combined to provide a composite readback signal that is decoded to provide the originally stored data from the track. In further embodiments, servo positioning control signals are generated from the respective sensor signals to improve the positioning of the sensors relative to the tracks. In still further embodiments, data are concurrently recovered from multiple tracks using the multiple sensors in a multi-track (e.g., two dimensional, or 2D) recording environment.
AISI, true TDMR is when data are being retrieved from two or more tracks at the same time. This would imply that the transfer rate should double, all else being equal. However, the sustained transfer rate for the IronWolf is 210MB/s which is no better than earlier models.
Therefore, ISTM that the 3-lane read channel is decoding only a single track of data, but is using all 3 read elements for tighter track positioning. If so, then is this really "TDMR"?
PostPosted: August 7th, 2018, 10:14
Both 10TB and 12TB Helium Seagate models use two preamps inside, that's why so many wires.
But why they use it's a guess work, could be TDMW or could be something else.
PostPosted: August 7th, 2018, 16:44
Doomer wrote:
Both 10TB and 12TB Helium Seagate models use two preamps inside, that's why so many wires. But why they use it's a guess work, could be TDMW or could be something else.
Do you have any references that we could read?
I'm wondering what sort of output one would get from a head test via terminal. Shorting the read channel would be interesting, too.
I'm assuming that these drives would support recent ATA commands which enable an end user to see the "PhysicalElementStatus". I'm wondering whether such commands would report the status of each read element or each head?
All SeaChest Utilities User Guides:
http://support.seagate.com/seachest/SeaChest_Combo_UserGuides.html
PostPosted: August 7th, 2018, 17:09
I don't have any public references
PostPosted: August 7th, 2018, 17:24
I don't understand marketing people. ISTM that, if your product has a unique feature that sets it apart from its competitors, then you should promote it.
BTW, I notice that several "air drives" from WD and Seagate have barometric pressure sensors, but you won't see this in any of their public docs.
PostPosted: November 11th, 2018, 17:54
(Helium filled HGST) WD80EFZX-68UW8N0 ROM (structural analysis):
http://www.hddoracle.com/viewtopic.php?f=153&t=2549
Users browsing this forum: BGman, Google [Bot] and 31 guests
