 Post subject: ST31500541AS show as unallocated with 3.86GB
PostPosted: August 5th, 2018, 9:33
My Seagate HDD stop working & show as unallocated with 3.86GB.
After my diagnostic when i plug the disk in the power support of computer, the disk motor works but after some seconds i heard knocks .. after 7 or 8 knocks the motor disk stop.
 Post subject: Re: ST31500541AS show as unallocated with 3.86GB
PostPosted: August 5th, 2018, 9:47
Can you post terminal log?
Unfortunately, typical symptoms of head/s failure.
PostPosted: August 5th, 2018, 9:50
likely heads are gone
Data Recovery Pakistan
PostPosted: August 5th, 2018, 10:03
how can i make a terminal log ??
PostPosted: August 5th, 2018, 10:04
if i changed the heads, the drive will works again ??
PostPosted: August 5th, 2018, 10:38
Maybe, but it all depends of the data in the drive. If it the data is not worth some US$ 200 or 300 at least, then just get another drive
PostPosted: August 5th, 2018, 10:39
Thank you
PostPosted: August 5th, 2018, 12:06
After that the motor stops, does it start to spin again after few seconds or it stay stationary?
If motor starts to spin again without re-plugging power supply, then it might be a firmware issue, this can happen often in particular 7200.11 seagate drives as ST3750330AS or ST31000333AS models.
But if you have any other seagate family or even a common 7200.11 drive as ST3500320AS model, then motor will not spin up again automatically and this means that heads are faulty.
PostPosted: August 5th, 2018, 12:33
I forgot to say, also your ST31500541AS (Barracuda LP) drive can behave by re-starting the motor if there is a firmware issue.
If motor doesn't spin alone again, then definitely it has bad heads.
PostPosted: August 6th, 2018, 16:43
To get a terminal log :
http://www.hddoracle.com/viewtopic.php?f=46&t=192
http://www.hddoracle.com/viewtopic.php?f=6&t=193
DO NOT OPEN THE DRIVE LID !!!
If heads are gone (and most likely they are) there is nothing you can do to solve the "problem" and get your data back. You will need to send the drive to a reputable data recovery firm and NOT an ordinary computer repair shop.
http://www.hddoracle.com/viewtopic.php?f=56&t=1427
Users browsing this forum: BGman, Google [Bot] and 35 guests
