Had a few of these in with the same issue and normally a pretty quick fix. However with this drive I cannot upload PSHT and RDMT into RAM. I keep getting an error saying the module is not found. Modules are not being read at all (ABR error), however I can see the RPSH, USAG and MFGP in RAM. NV-RAM issue? Any ideas.
Selected family......................... : 7250A7
Model by ID............................. :
Techno mode key......................... : Ok
Error startintg command: Reading SA [0x3F0000004, 0x4]
Device error detected (ABR)
Error startintg command: Reading SA [0x3F0000004, 0x1]
Error reading module USAG(0): Error startintg command: Reading SA [0x3F0000004, 0x1]
Error startintg command: Reading SA [0x3F0100004, 0x4]
Error startintg command: Reading SA [0x3F0100004, 0x1]
Error reading module USAG(1): Error startintg command: Reading SA [0x3F0100004, 0x1]
Loading modules table................................................. : Error
Error : .............................................................. : Module USAG: no copies read!
Loading the table of "open" modules................................... : Error
Error : .............................................................. : Error executing loading "open" modules dir command
Test : HDD Translator initialization in RAM
PSHT: C:\Program Files (x86)\ACE Lab\PC-3000\!Profiles\HITACHI-IBM-ARM\7250A7\HGST HTS725032A7E630-GHBZB550-TF645BY11RX40N\Data\SABackup\Modules\~PSHT.rpm
RDMT: C:\Program Files (x86)\ACE Lab\PC-3000\!Profiles\HITACHI-IBM-ARM\7250A7\HGST HTS725032A7E630-GHBZB550-TF645BY11RX40N\Data\SABackup\Modules\~RDMT.rpm
Loading PSHT...
Module PSHT is not found!
Loading RDMT...
Module RDMT is not found!
Searching of Translator activation flag address...
Completed
