 Post subject: ST320LT007-9ZV142 no access to user data ?
PostPosted: September 6th, 2018, 17:52
ST320LT007-9ZV142
W0Q9CKF7
0005LVM1
298.09 GB (625 142 448)
The hard drive spin fine, no scratches, and platter looks fine, the drive takes a long time to get ready, and stuck on bsy when reading ID
after many power cycles, some time I have access to the SA and I get Full drive ID but in both cases no access to user data.
also it is very very slow in reading models.
here the log
Family ID by HDD ID: 54
Selected family......................... : 54, Julius1
Model by ID............................. : ST320LT007-9ZV142
Loading default settings!
Use the options dialog to review and save utility settings.
Then press OK!
Family default settings loading!
Tech Key...
Requesting FW Pkg ver ........ JU0888.LVM1.AA0127.0005LVM1
Detecting Phys Sct Size...
Result.................................. : 4096
Detecting Max Head number...
Phys. heads............................. : 2
Obtaining Saved Mode Pages File information...
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
SMP Dbl: 0x3C000317 - 0x037FF7FF (0x0000000F)
LBA alignment........................... : 0
Obtaining Registry File information...
Reading Registry File...
Parsing Registry File...
Media Cache
MC       : enabled
MC Size  : 0x0
MC MCMT Ver is unavailable!!!
Collecting Sys Files information...
  ID        Len
   0          2  Reserved Defect Table (SA defect table)
   1          2  Drive Information File (DIF)
   2         16  Performance Parameter File (PPF)
   3       1880  Primary Defect File (P-List))
   4          9  Servo Adaptive Parameter File (SAP)
   5          4  Manufacturing Information File (MIF)
   6         50  Read Adaptive Parameters File (RAP)
   7          1  Controller Adaptive Parameters File (CAP)
   8       2400
   9          1  SMART Configuration File
   A       2251  SMART Data File
   B       1000
   C      64000  Serial Port Test Results File (Self Scan Log)
   D        160
   E        432  Data Integrity Check (DIC), HEAD 0
   F        223  DIC Dummy File
  13          8  Disc Registry File (settings, security, etc)
  15        100  BGMS File (Directed Offline Scan)
  16          2
  17         40
  19         24  Log File
  1A         33  Log File
  1B          1  Log File
  1C          9
  1D        128  Physical Overlay File 0
  1E        128  Physical Overlay File 1
  1F        640  Physical Overlay File 2
  22         80  Drive Self Test (DST), Head 0
  23         80  Drive Self Test (DST), Head 1
  2A          9  Saved Mode Pages (HDD settings)
  2B        506  R/W Operating Parameters (translator, etc)
  2C        432  Data Integrity Check (DIC), HEAD 1
  33       4576
  34        640  Packed CONGEN XML definition
  35         26  SMART Data
  3A          4
  3D       1800
  3E       1800
  3F       4576
  40          6
  41       2180
Collecting Sys File Infos completed
Collecting DT Infos...
ROM:
  ID     MemOffs        Len
   0     6020100      25600  Read Adaptive Parameters File (RAP)
   1     6028500        512  Controller Adaptive Parameters File (CAP)
   4     4000000       4096  Servo Adaptive Parameter File (SAP)
   5       6C000      81920  Servo Firmware Table
   A     609D65C       1024  Seek Profile
  13     60A9270        864  Dependent Zone Table for User Area
  14     60A95D0         96  Dependent Zone Table for System Area
  15           0     524288  Flash ROM
  1B     60A7074       8700  Dependent Zone Group Tables for User Area
  1C     60A6F34        320  Dependent Zone Group Tables for System Area
  1D     6020120        352  VBAR Configuration File
  1E     60203B0       2416  Zone Format Parameters File
RAM:
  ID     MemOffs        Len
   2     6020280        304  Zone Table
   4       7B000       4096  Servo Adaptive Parameter File (SAP)
   6      2A29B4      40996  Servo Flaw Table
  16     6020100         32  Drive Configuration Table
  17     60222C0       1216  Temperature Control Configuration
  1F     6164680       1728  RW working user preamp table
  20     6164D40         72  RW working system preamp table
Collecting DT Infos completed
Reading autotuning buffer...............   Ok
Searching module table in RAM... .......   Ok
Searching volume 3 file table in RAM....   Ok
Searching volume 0 file table in RAM....   Ok
Searching SMP RAM FID in RAM............   Ok
Searching Non Resident G-List FID in RAM   Ok
Searching CFW OVL FID in RAM............   Ok
Searching DT table(RAM, WR) in RAM......   Ok
Searching DT table(RAM, RD) in RAM......   Ok
System Files I/O method detection... ATA(direct)
Test  : HDD resources backup
Folder: E:\PC-3000\!Profiles\SgF3\Julius1\ST320LT007-9ZV142-0005LVM1-W0Q9CKF7\Data\SABackup\
Reading ROM to profile folder
Folder: E:\PC-3000\!Profiles\SgF3\Julius1\ST320LT007-9ZV142-0005LVM1-W0Q9CKF7\Data\SABackup\ROM\
Result.................................. : Ok
Reading DT to profile folder
Folder: E:\PC-3000\!Profiles\SgF3\Julius1\ST320LT007-9ZV142-0005LVM1-W0Q9CKF7\Data\SABackup\CPDir\
DT 0000 (Flash ROM), Read Adaptive Parameters File (RAP).............. : Ok
DT 0001 (Flash ROM), Controller Adaptive Parameters File (CAP)........ : Ok
DT 0004 (Flash ROM), Servo Adaptive Parameter File (SAP).............. : Ok
DT 0005 (Flash ROM), Servo Firmware Table............................. : Ok
DT 000A (Flash ROM), Seek Profile..................................... : Ok
DT 0013 (Flash ROM), Dependent Zone Table for User Area............... : Ok
DT 0014 (Flash ROM), Dependent Zone Table for System Area............. : Ok
DT 0015 (Flash ROM), Flash ROM........................................ : Ok
DT 001B (Flash ROM), Dependent Zone Group Tables for User Area........ : Ok
DT 001C (Flash ROM), Dependent Zone Group Tables for System Area...... : Ok
DT 001D (Flash ROM), VBAR Configuration File.......................... : Ok
DT 001E (Flash ROM), Zone Format Parameters File...................... : Ok
DT 0000 (RAM), Read Adaptive Parameters File (RAP).................... : Ok
DT 0001 (RAM), Controller Adaptive Parameters File (CAP).............. : Ok
DT 0002 (RAM), Zone Table............................................. : Ok
DT 0004 (RAM), Servo Adaptive Parameter File (SAP).................... : Ok
DT 0005 (RAM), Servo Firmware Table................................... : Ok
DT 0006 (RAM), Servo Flaw Table....................................... : Ok
DT 000A (RAM), Seek Profile........................................... : Ok
DT 0013 (RAM), Dependent Zone Table for User Area..................... : Ok
DT 0014 (RAM), Dependent Zone Table for System Area................... : Ok
DT 0015 (RAM), Flash ROM.............................................. : Ok
DT 0016 (RAM), Drive Configuration Table.............................. : Ok
DT 0017 (RAM), Temperature Control Configuration...................... : Ok
DT 001B (RAM), Dependent Zone Group Tables for User Area.............. : Ok
DT 001C (RAM), Dependent Zone Group Tables for System Area............ : Ok
DT 001D (RAM), VBAR Configuration File................................ : Ok
DT 001E (RAM), Zone Format Parameters File............................ : Ok
DT 001F (RAM), RW working user preamp table........................... : Ok
DT 0020 (RAM), RW working system preamp table......................... : Ok
DT reading process completed
Reading modules to profile folder
Folder: E:\PC-3000\!Profiles\SgF3\Julius1\ST320LT007-9ZV142-0005LVM1-W0Q9CKF7\Data\SABackup\ModDir\
Will be skipped : 000C, 000E, 000F, 0022, 0023, 002C
Module 0000, Reserved Defect Table (SA defect table).................. : Ok
Module 0001, Drive Information File (DIF)............................. : Ok
Module 0002, Performance Parameter File (PPF)......................... : Ok
Module 0003, Primary Defect File (P-List))............................ : Ok
Module 0004, Servo Adaptive Parameter File (SAP)...................... : Ok
Module 0005, Manufacturing Information File (MIF)..................... : Ok
Module 0006, Read Adaptive Parameters File (RAP)...................... : Ok
Module 0007, Controller Adaptive Parameters File (CAP)................ : Ok
Module 0008........................................................... : Ok
Module 0009, SMART Configuration File................................. : Ok
Module 000A, SMART Data File.......................................... : Ok
Module 000B........................................................... : Ok
Module 000D........................................................... : Ok
Module 0013, Disc Registry File (settings, security, etc)............. : Ok
Module 0015, BGMS File (Directed Offline Scan)........................ : Ok
Module 0016........................................................... : Ok
Module 0017........................................................... : Ok
Module 0019, Log File................................................. : Ok
Module 001A, Log File................................................. : Ok
Module 001B, Log File................................................. : Ok
Module 001C........................................................... : Ok
Module 001D, Physical Overlay File 0.................................. : Ok
Module 001E, Physical Overlay File 1.................................. : Ok
Module 001F, Physical Overlay File 2.................................. : Ok
Module 002A, Saved Mode Pages (HDD settings).......................... : Ok
Module 002B, R/W Operating Parameters (translator, etc)............... : Ok
Module 0033........................................................... : Ok
Module 0034, Packed CONGEN XML definition............................. : Ok
Module 0035, SMART Data............................................... : Ok
Module 003A........................................................... : Ok
Module 003D........................................................... : Ok
Module 003E........................................................... : Ok
Module 003F........................................................... : Ok
Module 0040........................................................... : Ok
Module 0041........................................................... : Ok
Modules reading process completed
Reading HDD ID pages list...
Reading HDD ID pages...
ID Page 00............................................................ : Ok
ID Page 01............................................................ : Ok
ID Page 02............................................................ : Ok
ID Page 03............................................................ : Ok
ID Page 04............................................................ : Ok
ID Page 08............................................................ : Ok
ID Page 09............................................................ : Ok
ID Page 0A............................................................ : Ok
ID Page 0B............................................................ : Ok
ID Page 0C............................................................ : Ok
ID Page 0D............................................................ : Ok
ID Page 0E............................................................ : Ok
ID Page 0F............................................................ : Ok
Reading System Files to profile folder
Folder: E:\PC-3000\!Profiles\SgF3\Julius1\ST320LT007-9ZV142-0005LVM1-W0Q9CKF7\Data\SABackup\SysFiles\
Copies : 0 1
Sys File FC000000(0), Reserved Defect Table (SA defect table)......... : Ok
Sys File FC000000(1), Reserved Defect Table (SA defect table)......... : Ok
Sys File FC001203(0).................................................. : Ok
Sys File FC001203(1).................................................. : Ok
Sys File FC002204(0).................................................. : Ok
Sys File FC002204(1).................................................. : Ok
Sys File FC003205(0).................................................. : Ok
Sys File FC003205(1).................................................. : Ok
Sys File FC004206(0).................................................. : Ok
Sys File FC004206(1).................................................. : Ok
Sys File FC00520C(0).................................................. : Ok
Sys File FC00520C(1).................................................. : Ok
Sys File FC00620D(0).................................................. : Ok
Sys File FC00620D(1).................................................. : Ok
Sys File FC00720E(0).................................................. : Ok
Sys File FC00720E(1).................................................. : Ok
Sys File FC34501B(0), Primary Defect File (P-List))................... : Ok
Sys File FC34501B(1), Primary Defect File (P-List))................... : Ok
Sys File FC34D028(0), R/W Operating Parameters (translator, etc)...... : Ok
Sys File FC34D028(1), R/W Operating Parameters (translator, etc)...... : Ok
Sys File FC34F035(0).................................................. : Ok
Sys File FC34F035(1).................................................. : Ok
Sys File FC353100(0), Physical Overlay File 0......................... : Ok
Sys File FC353100(1), Physical Overlay File 0......................... : Ok
Sys File FC354101(0), Physical Overlay File 1......................... : Ok
Sys File FC354101(1), Physical Overlay File 1......................... : Ok
Sys File FC355102(0), Physical Overlay File 2......................... : Ok
Sys File FC355102(1), Physical Overlay File 2......................... : Ok
Sys File FC356103(0).................................................. : Ok
Sys File FC356103(1).................................................. : Ok
Sys File FC357104(0).................................................. : Ok
Sys File FC357104(1).................................................. : Ok
Sys File FC358105(0).................................................. : Ok
Sys File FC358105(1).................................................. : Ok
Sys File FC359106(0).................................................. : Ok
Sys File FC359106(1).................................................. : Ok
Sys File FC35A107(0).................................................. : Ok
Sys File FC35A107(1).................................................. : Ok
Sys File FC35B108(0).................................................. : Ok
Sys File FC35B108(1).................................................. : Ok
Sys File FC35C109(0).................................................. : Ok
Sys File FC35C109(1).................................................. : Ok
Sys File FC35D10A(0).................................................. : Ok
Sys File FC35D10A(1).................................................. : Ok
Sys File FC35E10B(0).................................................. : Ok
Sys File FC35E10B(1).................................................. : Ok
Sys File FC35F10C(0).................................................. : Ok
Sys File FC35F10C(1).................................................. : Ok
Sys File FC36010D(0).................................................. : Ok
Sys File FC36010D(1).................................................. : Ok
Sys File FC39610E(0).................................................. : Ok
Sys File FC39610E(1).................................................. : Ok
Sys File FC39710F(0).................................................. : Ok
Sys File FC39710F(1).................................................. : Ok
Sys File FC361110(0).................................................. : Ok
Sys File FC361110(1).................................................. : Ok
Sys File FC39319F(0).................................................. : Ok
Sys File FC39319F(1).................................................. : Ok
System Files reading process completed
Reading loader data to folder (LDR)
Scanning LOD files...
reading file FC00620D...
reading file FC353100...
   Appending: Overlay ID = 00
reading file FC354101...
   Appending: Overlay ID = 01
reading file FC355102...
reading file FC356103...
   Appending: Overlay ID = 04
reading file FC357104...
   Appending: Overlay ID = 05
reading file FC358105...
reading file FC359106...
reading file FC35A107...
reading file FC35B108...
reading file FC35C109...
reading file FC35D10A...
reading file FC35E10B...
reading file FC35F10C...
reading file FC36010D...
reading file FC39610E...
reading file FC39710F...
reading file FC39319F...
   Appending: Overlay ID = 06
Backup of service information completed
and here the terminal
Rst 0x10M
(P) SATA Reset
[PORFAIL:MC.disabled]
Seg Read Error at LBA= 004966A0
Seg Read Error at LBA= 00496B00
Seg Read Error at LBA= 00496F60
Seg Read Error at LBA= 004973C0
Seg Read Error at LBA= 00497820
Seg Read Error at LBA= 00497C80
Seg Read Error at LBA= 004980E0
Seg Read Error at LBA= 00498540
Seg Read Error at LBA= 004989A0
Seg Read Error at LBA= 00498E00
Seg Read Error at LBA= 00499260
Seg Read Error at LBA= 004996C0
Seg Read Error at LBA= 00499B20
Seg Read Error at LBA= 00499F80
Seg Read Error at LBA= 0049A3E0
Seg Read Error at LBA= 0049A840
Seg Read Error at LBA= 0049ACA0
Seg Read Error at LBA= 0049B100
Seg Read Error at LBA= 0049B560
Seg Read Error at LBA= 0049B9C0
Seg Read Error at LBA= 0049BE20
Seg Read Error at LBA= 0049C280
Seg Read Error at LBA= 0049C6E0
Seg Read Error at LBA= 0049CB40
Seg Read Error at LBA= 0049CFA0
Seg Read Error at LBA= 0049D400
Seg Read Error at LBA= 0049D860
Seg Read Error at LBA= 0049DCC0
Seg Read Error at LBA= 0049E120
Seg Read Error at LBA= 0049E580
ASCII Diag mode
F3 T> Idle Task Took Too Long to Complete
Spinning Down
Spin Down Complete
Elapsed Time 3.967 secs
Delaying 5000 msec
Jumping to Power On Resetý
Rst 0x10M
(P) SATA Reset
Seg Read Error at LBA= 004A0880
Seg Read Error at LBA= 004A0CE0
Seg Read Error at LBA= 004A1140
Seg Read Error at LBA= 004A15A0
ASCII Diag mode
Package Version: JU0888.LVM1.AA0127.0005LVM1, Package P/N: ---------, Package Builder ID: 84,
Package Build Date: 02/04/2013, Package Build Time: 13:12:20, Package CFW Version: JU08.LVM1.00494991.8400,
Package SFW1 Version: 884B, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 01270001, CustomerRel: 0005, Changelist: 00494991, ProdType: JU08.LVM1, Date: 02/04/2013, Time: 131220, UserId: 00080603
Servo FW Rev: 8893
RAP FW Implementation Key: 10, Format Rev: 5402, Contents Rev: 54 05 04 05
SphinxST Rev: 6799; CurSpd: 3.0Gb; SpdLimit: No; SSC: No; LED: No; StagSpinByp: Yes;
SATA Block Registers
  ATA
100A0000: 0000 0000 0000 0000  0000 0000 0000 0000
100A0010: 0000 0000 0000 0080  0000 0000 0000 0400
100A0020: 0080 0000 0010 0210  0000 0000 0000 0000
100A0030: 0080 841B 0000 0000  0000 0000 0000 0000
100A0040: 0000 0000 0000 0000  0000 0000 0000 0000
100A0050: 0000 0000 4795 57A5  CE2D 0000 0000 0000
100A0060: 0001 0000 0000 0000  0000 0000 0000 0000
100A0070: 0000 0001 0000 0000  0000 0000 0000 0000
100A0080: 0000 0400 0001 0001  0000 0000 0000 0050
100A0090: 0001 0000 0000 0000  0000 0000 0000 0000
100A00A0: 0000 0000 0000 0000  0000 0000 0000 0000
100A00B0: 0000 0000 0000 0000  0000 0000 0000 0000
100A00C0: 0000 0000 0000 0000  0000 0000 0000 0000
100A00D0: FFFF FFFF FFFF FFFF  0000 0000 0000 0000
100A00E0: 0000 0000 0000 0000  0000 0000 0000 0000
100A00F0: 0000 0000 0000 0000  0000 0000 0000 0000
  SATA Global
100A0100: 0000 0000 0000
  Link Layer
100A0130: 0000 0000 0000 0000  8000 0004 0F40 0000
100A0140: 0020 025B 0000 0000  0000 0000 0000 0000
100A0150: 0000 0000 0001 00E7  0000 0000 0000 0000
100A0160: 0000 0000 0000 0000  0000 0000 0000 0000
100A0170: 0000 0000 0000 0000  0000 0000 0000 0000
100A0180: 0000 0000 0000 0000  0000 0000 0000 0000
100A0190: 0000 0000 0000 0000  0000 0000 0000 0000
100A01A0: 0000 0000 0000 0000  0000 0000 0000 0000
100A01B0: 0000 0000 0000 0000  0000 0000 0000 0000
100A01C0: 0000 0000 0000 0000  0000 0000 0000 0000
100A01D0: 0000 0000 0000 0000  0000 0000 0000 0000
100A01E0: 0000 0000 0000 5032  5232 2495 DC05 0000
100A01F0: 0000 0000 0000 0000  0000 0000 0000 0D00
  Transport Layer
100A0250: xxxx xxxx xxxx xxxx  xxxx xxxx 0000 000F
100A0260: 0000 0000 0000 0000  0000 0020 0000 3018
100A0270: 00E0 0000 0000 4200  0000 0000 0001 1002
100A0280: 0000 0000 0000 0000  0000 0000 0000 0000
100A0290: 0000 0000
  NCQ Cmd Validation
100A0300: 0000 0000 0000 0000  0000 0001 0000 0000
  Application Layer
100A0390: xxxx xxxx xxxx xxxx  0000 0400 0000 5058
  Shadow Task File
100A03A0: xxxx xxxx 0000 0000  0000 0000 0000 0000
100A03B0: 0000 0000 0000 0000  0001 0001 0000 0000
100A03C0: 0000 0050 0001 0000  0000 0034 0000 0000
100A03D0: 0000 0000 0000 0000  0000 0000 0000 0000
100A03E0: 0000 0000 0000 0000  0000 0000 0000 0000
100A03F0: 0000 0000 0000 0000
  PhyPM Regs
100A0700: 000C 000F 0004 0001  0010 0000 0000 0000
100A0710: 0000 0000 0000 0000  0000 0000 0000 0000
100A0720: FFFF FFFF FFFF FFFF  0000
  Physical Layer
100A0800: 0000 0000 0000 9123  0000 0000 0000 0022
100A0810: 0000 0001 0000 005D  2CC0 6BF7 9000 0033
100A0820: 364D A494 0800 4FB9  1414 0270 0000 0000
100A0830: 0000 047F 0000 1000  0000 0000 0000 0000
100A0840: FFFF FFFF FFFF FFFF  FFFF FFFF FFFF FFFF
100A0850: 0000 0000 0000 0000  0000 0000 0000 0000
100A0860: 0000 0000 0000 0000  0000 0000 0000 0000
100A0870: 0000 0000 0000 0000  003F 0000 0000 0000
100A0880: 0000 0000 0000 0000  0000 0000 0000 0000
100A0890: 0000 0000 0000 0000  0000 0000 0000 0000
100A08A0: 0000 0000 0000 0000  0000 0000 0000 0000
100A08B0: 0000 0000 0000 0000  0000 0000 0000 0000
100A08C0: 0000 0000 0000 0000  0000 0000 0000 0000
100A08D0: 0000 0000 0000 0000  0000 0000 0000 0000
100A08E0: 0000 0000 0000 0000  0000 0000 0000 0000
100A08F0: 0000 0000 0000 0000  0000 0000 0000 0000
  SATA Visibility Mux
100A02E0: xxxx xxxx xxxx xxxx  xxxx xxxx 0000 0000
100A02F0: FFFF FFFF FFFF FFFF  FFFF FFFF FFFF FFFF
  Layers Diag Mux
100A0EF0: xxxx xxxx xxxx xxxx  xxxx xxxx 0000 0000
100A0F00: 0007 0000 0000 0000  0000 0000
MiPhy365 Phy Registers
  Core
0000: 00 1F 08 08 10 00 00 00  00 00 00 00 00 00 00 00
0010: 00 00 00 80 00 63 00 00  00 00 00 00 00 00 00 00
0020: 11 05 01 08 00 11 8F 03  00 00 00 00 00 00 00 00
0030: 07 03 FF 01 7C 00 00 00  00 00 00 00 00 00 00 00
0040: 9C 9E 2B 24 06 24 18 07  12 00 00 00 00 00 00 00
0050: 0D 02 64 00 00 00 05 E8  00 C6 3F 07 A8 00 58 00
0060: AA 00 04 44 00 40 00 00  00 01 00 00 00 00 00 00
0070: 01 47 00 00 00 00 00 00  00 00 00 00 00 00 00 00
0080: 02 00 21 06 61 90 70 00  01 00 00 00 00 00 00 00
0090: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
00A0: 7C A9 AA 2A 39 00 00 00  00 00 00 00 00 00 00 00
00B0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
00C0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
00D0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
00E0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
00F0: 00 00 00 00 00 00 00 00  00 00 00 31 C6 00 FF 00
  Wrapper
6000: 6005 0064 0000 0000  0000 0000 0000 0000
6008: 0000 0000 0000 0000  0000 0000 0000 0000
6010: D006 0001 0002 0000  0001
  Banked Registers Gen1
0020: 10 03 01 08 00 01 CF 03
0056: 05 E8 00 C6
0062: 04 44
0082: 32
  Banked Registers Gen2
0056: 05 E8 00 C6
0062: 04 44
0082: 21
  VBM Cache Search Registers
10012680: 15A0 004A 0008 0000  007F 2480 0000 00FF
10012690: 0000 0000 0000 0000  0000 0000 0000 0000
  Traverser Regs
10012700: 4B12 0000 0000
  Host Data Manager Regs Bank 0
10012800: 0007 0000 7FFF 0000  0000 0000 0000 0000
10012810: 0000 0000 0000 0000  0000 0000 0000 0000
  Disc Data Manager Registers Bank 0
10012900: 78C7 0010 0088 0000  0080 0000 0080 0000
10012910: 0080 0000 0080 0000  0080 0000 0080 0000
  PBM Memory Controller Registers
10012A00: 0040 0000 0318 0000  3809 0000 0000 0000
10012A10: 0032 0000 000B 0000  0003 0000 0000 0000
10012A20: 2315 0344 8724 0724  080A C81C 040D 0003
10012A30: 0004 0000 007E 0012  0012 0053 0053 0000
10012A40: 0000 0000 0000 0000  0000 0000 0000 0000
10012A50: 0000 0000 0000 0000  0000 0000 0000 0000
10012A60: 0000 0000 0000 0000  0000 0000 0000 0000
10012A70: 0000 0000 0000 0000  0000 0000 0000 0000
  FDE Block
10012B00: 0000 0000 0000 0000  0000 0000 0000 0000
10012B10: 0000 0000 0000 0000  0000 0000 0000 0000
10012B20: 0200 20F0 6B23 E873  34E9 5048 0000 0000
10012B30: 0000 0000 0000 0000  0000 0000 0000 0000
  Hardware Phy Event Counters
00000000: 0000 0000 0000 0000  0000 0000 0000 0000
00000010: 0000 0000 0000 0000  0001 0000
R_ERR on RX FIS Non-data: 00000, Data: 00000
R_ERR on TX FIS Non-data: 00000, Data: 00000
ASCII Diag mode
F3 T>V4
Reassigned Sectors List
Entries: 00A4, Retrieved: 00A4, Alts: 0000, Removed: 0000, Pending: 0520, GList: 0000, RList: 0000
Idx  LBA          PBA          LLLCHS of LBA Wdg PLPCHS of PBA SFI    Hours Msecs  Status   BBM Mask
0000 0005E678 0005E685 00028C.1.00D0 063 00028C.1.00D0 0565F6 ----- ------ 00100001 00000000
0001 0005E682 0005E68F 00028C.1.00DA 06C 00028C.1.00DA 05DA7E ----- ------ 00100001 00000000
0002 0005E6FF 0005E70C 00028D.1.0030 00C 00028D.1.0030 00AAE4 ----- ------ 00100001 00000000
0003 0005E704 0005E711 00028D.1.0035 010 00028D.1.0035 00E506 ----- ------ 00100001 00000000
0004 0005E790 0005E79D 00028D.1.00C1 086 00028D.1.00C1 074242 ----- ------ 00100001 00000000
0005 0005E79A 0005E7A7 00028D.1.00CB 08E 00028D.1.00CB 07B686 ----- ------ 00100001 00000000
0006 0005E817 0005E824 00028E.1.0021 02E 00028E.1.0021 0286E2 ----- ------ 00100001 00000000
0007 0005E81C 0005E829 00028E.1.0026 032 00028E.1.0026 02C104 ----- ------ 00100001 00000000
0008 0005E8A8 0005E8B5 00028E.1.00B2 0A8 00028E.1.00B2 091E40 ----- ------ 00100001 00000000
0009 0005E8B2 0005E8BF 00028E.1.00BC 0B1 00028E.1.00BC 0992C8 ----- ------ 00100001 00000000
000A 0005E92F 0005E93C 00028F.1.0012 051 00028F.1.0012 046324 ----- ------ 00100001 00000000
000B 0005E934 0005E941 00028F.1.0017 055 00028F.1.0017 049D46 ----- ------ 00100001 00000000
000C 0005E9C0 0005E9CD 00028F.1.00A3 0CB 00028F.1.00A3 0AFA82 ----- ------ 00100001 00000000
000D 0005EA47 0005EA54 000290.1.0003 073 000290.1.0003 063F22 ----- ------ 00100001 00000000
000E 0005EA4C 0005EA59 000290.1.0008 077 000290.1.0008 067944 ----- ------ 00100001 00000000
000F 0005EAD8 0005EAE5 000290.1.0094 0ED 000290.1.0094 0CD680 ----- ------ 00100001 00000000
0010 0005EAE2 0005EAEF 000290.1.009E 0F5 000290.1.009E 0D4AC4 ----- ------ 00100001 00000000
0011 0005EB5F 0005EB6C 000290.1.011B 066 000290.1.011B 059016 ----- ------ 00100001 00000000
0012 0005EB64 0005EB71 000290.1.0120 06B 000290.1.0120 05CA7C ----- ------ 00100001 00000000
0013 0005EBF0 0005EBFD 000291.1.0085 017 000291.1.0085 014948 ----- ------ 00100001 00000000
0014 0005EBFA 0005EC07 000291.1.008F 020 000291.1.008F 01BDC6 ----- ------ 00100001 00000000
0015 0005EC77 0005EC84 000291.1.010C 089 000291.1.010C 076C62 ----- ------ 00100001 00000000
0016 0005EC7C 0005EC89 000291.1.0111 08D 000291.1.0111 07A684 ----- ------ 00100001 00000000
0017 0005ED08 0005ED15 000292.1.0076 03A 000292.1.0076 03258A ----- ------ 00100001 00000000
0018 0005ED12 0005ED1F 000292.1.0080 042 000292.1.0080 0399CE ----- ------ 00100001 00000000
0019 0005ED8F 0005ED9C 000292.1.00FD 0AB 000292.1.00FD 094860 ----- ------ 00100001 00000000
001A 0005ED94 0005EDA1 000292.1.0102 0AF 000292.1.0102 098282 ----- ------ 00100001 00000000
001B 0005EE20 0005EE2D 000293.1.0067 05C 000293.1.0067 050188 ----- ------ 00100001 00000000
001C 0005EEA7 0005EEB4 000293.1.00EE 0CE 000293.1.00EE 0B24A2 ----- ------ 00100001 00000000
001D 0005EEAC 0005EEB9 000293.1.00F3 0D2 000293.1.00F3 0B5EC4 ----- ------ 00100001 00000000
001E 0005EF38 0005EF45 000294.1.0058 07E 000294.1.0058 06DD86 ----- ------ 00100001 00000000
001F 0005EF42 0005EF4F 000294.1.0062 087 000294.1.0062 07520E ----- ------ 00100001 00000000
0020 0005EFBF 0005EFCC 000294.1.00DF 0F0 000294.1.00DF 0D00A0 ----- ------ 00100001 00000000
0021 0005EFC4 0005EFD1 000294.1.00E4 0F4 000294.1.00E4 0D3AC2 ----- ------ 00100001 00000000
0022 0005F050 0005F05D 000295.1.0049 0A1 000295.1.0049 08B9C8 ----- ------ 00100001 00000000
0023 0005F05A 0005F067 000295.1.0053 0A9 000295.1.0053 092E0C ----- ------ 00100001 00000000
0024 0005F0D7 0005F0E4 000295.1.00D0 01A 000295.1.00D0 01735E ----- ------ 00100001 00000000
0025 0005F0DC 0005F0E9 000295.1.00D5 01F 000295.1.00D5 01ADC4 ----- ------ 00100001 00000000
0026 0005F168 0005F175 000296.1.003A 0C3 000296.1.003A 0A95D0 ----- ------ 00100001 00000000
0027 0005F172 0005F17F 000296.1.0044 0CC 000296.1.0044 0B0A58 ----- ------ 00100001 00000000
0028 0005F1EF 0005F1FC 000296.1.00C1 03D 000296.1.00C1 034FAA ----- ------ 00100001 00000000
0029 0005F1F4 0005F201 000296.1.00C6 041 000296.1.00C6 0389CC ----- ------ 00100001 00000000
002A 0005F280 0005F28D 000297.1.002B 0E6 000297.1.002B 0C7212 ----- ------ 00100001 00000000
002B 0005F307 0005F314 000297.1.00B2 05F 000297.1.00B2 052BA8 ----- ------ 00100001 00000000
002C 0005F30C 0005F319 000297.1.00B7 063 000297.1.00B7 0565CA ----- ------ 00100001 00000000
002D 00092CD4 00092CE1 000405.1.0045 03E 000405.1.0045 035A56 ----- ------ 00100001 00000000
002E 00092D60 00092D6D 000405.1.00D1 0B3 000405.1.00D1 09B74C ----- ------ 00100001 00000000
002F 00092DEC 00092DF9 000406.1.0036 060 000406.1.0036 05365C ----- ------ 00100001 00000000
0030 00092E78 00092E85 000406.1.00C2 0D6 000406.1.00C2 0B9398 ----- ------ 00100001 00000000
0031 00092F04 00092F11 000407.1.0027 082 000407.1.0027 07125A ----- ------ 00100001 00000000
0032 00092F90 00092F9D 000407.1.00B3 000 000407.1.00B3 000656 ----- ------ 00100001 00000000
0033 0009301C 00093029 000407.0.0018 0ED 000407.0.0018 0D1C6E ----- ------ 00100001 00000000
0034 000930A8 000930B5 000407.0.00A4 069 000407.0.00A4 05CB36 ----- ------ 00100001 00000000
0035 00093134 00093141 000406.0.0003 013 000406.0.0003 0112C9 ----- ------ 00100001 00000000
0036 000931C0 000931CD 000406.0.008F 086 000406.0.008F 076E5C ----- ------ 00100001 00000000
0037 0009324C 00093259 000406.0.011B 002 000406.0.011B 001D24 ----- ------ 00100001 00000000
0038 000932D8 000932E5 000405.0.007A 0A4 000405.0.007A 0911C7 ----- ------ 00100001 00000000
0039 00093364 00093371 000405.0.0106 01F 000405.0.0106 01C04A ----- ------ 00100001 00000000
003A 000933F0 000933FD 000404.0.0065 0C2 000404.0.0065 0AB54D ----- ------ 00100001 00000000
003B 0009347C 00093489 000404.0.00F1 03D 000404.0.00F1 0363B5 ----- ------ 00100001 00000000
003C 00093508 00093515 000403.0.0050 0DF 000403.0.0050 0C5873 ----- ------ 00100001 00000000
003D 00093594 000935A1 000403.0.00DC 05B 000403.0.00DC 05073B ----- ------ 00100001 00000000
003E 00093620 0009362D 000402.0.003B 005 000402.0.003B 004ECE ----- ------ 00100001 00000000
003F 000936AC 000936B9 000402.0.00C7 078 000402.0.00C7 06AA61 ----- ------ 00100001 00000000
0040 00093738 00093745 000401.0.0026 023 000401.0.0026 01F239 ----- ------ 00100001 00000000
0041 000937C4 000937D1 000401.0.00B2 096 000401.0.00B2 084DCC ----- ------ 00100001 00000000
0042 00093850 0009385D 000400.0.0011 041 000400.0.0011 0395A4 ----- ------ 00100001 00000000
0043 000938DC 000938E9 000400.0.009D 0B4 000400.0.009D 09F137 ----- ------ 00100001 00000000
0044 00093968 00093975 000400.0.0129 02F 000400.0.0129 029FBA ----- ------ 00100001 00000000
0045 000939F4 00093A01 0003FF.0.0088 0D2 0003FF.0.0088 0B94A2 ----- ------ 00100001 00000000
0046 00093A80 00093A8D 0003FF.0.0114 04D 0003FF.0.0114 044325 ----- ------ 00100001 00000000
0047 00093B0C 00093B19 0003FE.0.0073 0EF 0003FE.0.0073 0D37E3 ----- ------ 00100001 00000000
0048 00093B98 00093BA5 0003FE.0.00FF 06B 0003FE.0.00FF 05E690 ----- ------ 00100001 00000000
0049 00093C24 00093C31 0003FD.0.005E 015 0003FD.0.005E 012E3E ----- ------ 00100001 00000000
004A 00093CB0 00093CBD 0003FD.0.00EA 088 0003FD.0.00EA 0789D1 ----- ------ 00100001 00000000
004B 00093D3C 00093D49 0003FC.0.0049 033 0003FC.0.0049 02D1A9 ----- ------ 00100001 00000000
004C 00093DC8 00093DD5 0003FC.0.00D5 0A6 0003FC.0.00D5 092D3C ----- ------ 00100001 00000000
004D 00093E54 00093E61 0003FB.0.0034 050 0003FB.0.0034 0474CF ----- ------ 00100001 00000000
004E 00093EE0 00093EED 0003FB.0.00C0 0C4 0003FB.0.00C0 0AD0A7 ----- ------ 00100001 00000000
004F 00093F6C 00093F79 0003FA.0.001F 06E 0003FA.0.001F 061855 ----- ------ 00100001 00000000
0050 00093FF8 00094005 0003FA.0.00AB 0E1 0003FA.0.00AB 0C73CD ----- ------ 00100001 00000000
0051 00094084 00094091 0003F9.0.000A 08C 0003F9.0.000A 07BBC0 ----- ------ 00100001 00000000
0052 00094110 0009411D 0003F9.0.0096 007 0003F9.0.0096 006A43 ----- ------ 00100001 00000000
0053 0009419C 000941A9 0003F9.0.0122 07A 0003F9.0.0122 06C5BB ----- ------ 00100001 00000000
0054 00094228 00094235 0003F8.0.0081 025 0003F8.0.0081 020DAE ----- ------ 00100001 00000000
0055 000942B4 000942C1 0003F8.0.010D 098 0003F8.0.010D 086941 ----- ------ 00100001 00000000
0056 00094340 0009434D 0003F7.0.006C 042 0003F7.0.006C 03B0D4 ----- ------ 00100001 00000000
0057 000943CC 000943D9 0003F7.0.00F8 0B6 0003F7.0.00F8 0A0CAC ----- ------ 00100001 00000000
0058 00094458 00094465 0003F6.0.0057 060 0003F6.0.0057 05543F ----- ------ 00100001 00000000
0059 000944E4 000944F1 0003F6.0.00E3 0D3 0003F6.0.00E3 0BAFD2 ----- ------ 00100001 00000000
005A 00094570 0009457D 0003F5.0.0042 07E 0003F5.0.0042 06F7C5 ----- ------ 00100001 00000000
005B 000945FC 00094609 0003F5.0.00CE 0F1 0003F5.0.00CE 0D533D ----- ------ 00100001 00000000
005C 00094688 00094695 0003F4.0.002D 09C 0003F4.0.002D 089B30 ----- ------ 00100001 00000000
005D 00094714 00094721 0003F4.0.00B9 017 0003F4.0.00B9 0149B3 ----- ------ 00100001 00000000
005E 000947A0 000947AD 0003F3.0.0018 0B9 0003F3.0.0018 0A3E56 ----- ------ 00100001 00000000
005F 0009482C 00094839 0003F3.0.00A4 035 0003F3.0.00A4 02ED1E ----- ------ 00100001 00000000
0060 000948B8 000948C5 0003F2.0.0003 0D7 0003F2.0.0003 0BE1C1 ----- ------ 00100001 00000000
0061 00094944 00094951 0003F2.0.008F 052 0003F2.0.008F 049044 ----- ------ 00100001 00000000
0062 000949D0 000949DD 0003F2.0.011B 0C6 0003F2.0.011B 0AEC1C ----- ------ 00100001 00000000
0063 00094A5C 00094A69 0003F1.0.007A 070 0003F1.0.007A 0633AF ----- ------ 00100001 00000000
0064 00094AE8 00094AF5 0003F1.0.0106 0E3 0003F1.0.0106 0C8F42 ----- ------ 00100001 00000000
0065 00094B74 00094B81 0003F0.0.0065 08E 0003F0.0.0065 07D735 ----- ------ 00100001 00000000
0066 00094C00 00094C0D 0003F0.0.00F1 009 0003F0.0.00F1 00859D ----- ------ 00100001 00000000
0067 00094C8C 00094C99 0003EF.0.0050 0AB 0003EF.0.0050 097A5B ----- ------ 00100001 00000000
0068 00094D18 00094D25 0003EF.0.00DC 027 0003EF.0.00DC 022923 ----- ------ 00100001 00000000
0069 00094DA4 00094DB1 0003EE.0.003B 0C9 0003EE.0.003B 0B1DC6 ----- ------ 00100001 00000000
006A 00094E30 00094E3D 0003EE.0.00C7 044 0003EE.0.00C7 03CC49 ----- ------ 00100001 00000000
006B 00094EBC 00094EC9 0003ED.0.0026 0E7 0003ED.0.0026 0CC131 ----- ------ 00100001 00000000
006C 00094F48 00094F55 0003ED.0.00B2 062 0003ED.0.00B2 056FB4 ----- ------ 00100001 00000000
006D 00094FD4 00094FE1 0003EC.0.0011 00D 0003EC.0.0011 00B78C ----- ------ 00100001 00000000
006E 00095060 0009506D 0003EC.0.009D 080 0003EC.0.009D 07131F ----- ------ 00100001 00000000
006F 000950EC 000950F9 0003EC.0.0129 0F3 0003EC.0.0129 0D6EB2 ----- ------ 00100001 00000000
0070 00095178 00095185 0003EB.0.0088 09E 0003EB.0.0088 08B68A ----- ------ 00100001 00000000
0071 00095204 00095211 0003EB.0.0114 019 0003EB.0.0114 01650D ----- ------ 00100001 00000000
0072 00095290 0009529D 0003EA.0.0073 0BB 0003EA.0.0073 0A59CB ----- ------ 00100001 00000000
0073 0009531C 00095329 0003EA.0.00FF 037 0003EA.0.00FF 030878 ----- ------ 00100001 00000000
0074 000953A8 000953B5 0003E9.0.005E 0D9 0003E9.0.005E 0BFD36 ----- ------ 00100001 00000000
0075 00095434 00095441 0003E9.0.00EA 054 0003E9.0.00EA 04ABB9 ----- ------ 00100001 00000000
0076 000954C0 000954CD 0003E8.0.0049 0F7 0003E8.0.0049 0DA0A1 ----- ------ 00100001 00000000
0077 0009554C 00095559 0003E8.0.00D5 072 0003E8.0.00D5 064F24 ----- ------ 00100001 00000000
0078 000955D8 000955E5 0003E7.0.0034 01C 0003E7.0.0034 0196B7 ----- ------ 00100001 00000000
0079 00095664 00095671 0003E7.0.00C0 090 0003E7.0.00C0 07F28F ----- ------ 00100001 00000000
007A 000956F0 000956FD 0003E6.0.001F 03A 0003E6.0.001F 033A3D ----- ------ 00100001 00000000
007B 0009577C 00095789 0003E6.0.00AB 0AD 0003E6.0.00AB 0995B5 ----- ------ 00100001 00000000
007C 00095808 00095815 0003E5.0.000A 058 0003E5.0.000A 04DDA8 ----- ------ 00100001 00000000
007D 00095894 000958A1 0003E5.0.0096 0CB 0003E5.0.0096 0B393B ----- ------ 00100001 00000000
007E 00095920 0009592D 0003E5.0.0122 046 0003E5.0.0122 03E7A3 ----- ------ 00100001 00000000
007F 000959AC 000959B9 0003E4.0.0081 0E9 0003E4.0.0081 0CDCA6 ----- ------ 00100001 00000000
0080 00095A38 00095A45 0003E4.0.010D 064 0003E4.0.010D 058B29 ----- ------ 00100001 00000000
0081 00095AC4 00095AD1 0003E3.0.006C 00E 0003E3.0.006C 00D2BC ----- ------ 00100001 00000000
0082 00095B50 00095B5D 0003E3.0.00F8 082 0003E3.0.00F8 072E94 ----- ------ 00100001 00000000
0083 00095BDC 00095BE9 0003E2.0.0057 02C 0003E2.0.0057 027627 ----- ------ 00100001 00000000
0084 00095C68 00095C75 0003E2.0.00E3 09F 0003E2.0.00E3 08D1BA ----- ------ 00100001 00000000
0085 00095CF4 00095D01 0003E1.0.0042 04A 0003E1.0.0042 0419AD ----- ------ 00100001 00000000
0086 00095D80 00095D8D 0003E1.0.00CE 0BD 0003E1.0.00CE 0A7525 ----- ------ 00100001 00000000
0087 00095E0C 00095E19 0003E0.0.002D 068 0003E0.0.002D 05BD18 ----- ------ 00100001 00000000
0088 00095E98 00095EA5 0003E0.0.00B9 0DB 0003E0.0.00B9 0C18AB ----- ------ 00100001 00000000
0089 00095F24 00095F31 0003DF.0.0018 085 0003DF.0.0018 07603E ----- ------ 00100001 00000000
008A 00095FB0 00095FBD 0003DF.0.00A4 001 0003DF.0.00A4 000F06 ----- ------ 00100001 00000000
008B 0009603C 00096049 0003DE.0.0003 0A3 0003DE.0.0003 0903A9 ----- ------ 00100001 00000000
008C 000960C8 000960D5 0003DE.0.008F 01E 0003DE.0.008F 01B22C ----- ------ 00100001 00000000
008D 00096154 00096161 0003DE.0.011B 092 0003DE.0.011B 080E04 ----- ------ 00100001 00000000
008E 000961E0 000961ED 0003DD.0.007A 03C 0003DD.0.007A 035597 ----- ------ 00100001 00000000
008F 0009626C 00096279 0003DD.0.0106 0AF 0003DD.0.0106 09B12A ----- ------ 00100001 00000000
0090 000962F8 00096305 000408.0.0065 083 000408.0.0065 073BEB ----- ------ 00100001 00000000
0091 00096384 00096391 000408.0.00F1 0F6 000408.0.00F1 0D9763 ----- ------ 00100001 00000000
0092 00096410 0009641D 000409.0.0050 0A0 000409.0.0050 08DF11 ----- ------ 00100001 00000000
0093 0009649C 000964A9 000409.0.00DC 01C 000409.0.00DC 018DD9 ----- ------ 00100001 00000000
0094 00096528 00096535 00040A.0.003B 0BE 00040A.0.003B 0A827C ----- ------ 00100001 00000000
0095 000965B4 000965C1 00040A.0.00C7 039 00040A.0.00C7 0330FF ----- ------ 00100001 00000000
0096 00096640 0009664D 00040B.0.0026 0DC 00040B.0.0026 0C25E7 ----- ------ 00100001 00000000
0097 000966CC 000966D9 00040B.0.00B2 057 00040B.0.00B2 04D46A ----- ------ 00100001 00000000
0098 00096758 00096765 00040C.0.0011 002 00040C.0.0011 001C42 ----- ------ 00100001 00000000
0099 000967E4 000967F1 00040C.0.009D 075 00040C.0.009D 0677D5 ----- ------ 00100001 00000000
009A 00096870 0009687D 00040C.0.0129 0E8 00040C.0.0129 0CD368 ----- ------ 00100001 00000000
009B 000968FC 00096909 00040D.0.0088 093 00040D.0.0088 081B40 ----- ------ 00100001 00000000
009C 00096988 00096995 00040D.0.0114 00E 00040D.0.0114 00C9C3 ----- ------ 00100001 00000000
009D 00096A14 00096A21 00040E.0.0073 0B0 00040E.0.0073 09BE81 ----- ------ 00100001 00000000
009E 00096AA0 00096AAD 00040E.0.00FF 02C 00040E.0.00FF 026D2E ----- ------ 00100001 00000000
009F 00096B2C 00096B39 00040F.0.005E 0CE 00040F.0.005E 0B61EC ----- ------ 00100001 00000000
00A0 00096BB8 00096BC5 00040F.0.00EA 049 00040F.0.00EA 04106F ----- ------ 00100001 00000000
00A1 00096C44 00096C51 000410.0.0049 0EC 000410.0.0049 0D0557 ----- ------ 00100001 00000000
00A2 00096CD0 00096CDD 000410.0.00D5 067 000410.0.00D5 05B3DA ----- ------ 00100001 00000000
00A3 000E8821 000E882E 000645.1.0000 0AE 000645.1.0000 0968D6 ----- ------ 00100001 00000000
F3 T>
ASCII Diag mode
F3 T>V40
Nonresident GList           4 entries returned
Total entries available: 4
    PBA    Len  Flags  Phy Cyl Hd  PhySctr    SFI
   3EFFA    C     20      1B3   0    101    53803
   3F1E3    1     20      1B5   0     90    5455A
48515EE   99      0    26DB4   1      0    47C18
4853502   99      0    2847D   0      0    58AA8
F3 T>
 Post subject: Re: ST320LT007-9ZV142 no access to user data ?
PostPosted: September 7th, 2018, 2:21
Sounds like weak/bad head(s) to me, common on this model.
PostPosted: September 18th, 2018, 13:26
replaced head still the same problem
Users browsing this forum: Bing [Bot], Google [Bot], Spildit and 30 guests
