 Post subject: clicking Seagate ST1000DL002 data recovery
PostPosted: September 23rd, 2018, 17:44
I have a Seagate ST1000DL002 SATA HDD. One day, it produced uneven noises.
During the surface test there were a few bad sectors.
An another day surface test was showing more and more bad sectors, and suddenly the HDD started beeping repeatedly,
and it was no more visible under Windows and also in BIOS. Every time when powered on, just giving beeping and clicking sound.
Any help would be appreciated.
The terminal messages listed here:
Rst 0x20M
MC Internal LPC Process
FAIL Op=0900 Resp=0005
(P) SATA Reset
User Data Base  00992288
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes:  4011A624  40118734
Seg Write Preamble VBM start: 000010A7 end: 000010CE
  Footer - start: 000010D0 end: 000010F7
Seg Read Preamble VBM - start: 000010F9 end: 00001120
  Footer - start: 00001122 end: 00001149
Reconstruction: MCMT Reconstruction Start
  Max number of MC segments 22E0
Nonvolatile MCMT sequence number 0158FCA1
[RSRS] 0F7B
Reconstruction: Completed 1:
[MCMTWS]
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00000041
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00000041
MCMainPOR: Feature Enabled...
FAIL Op=0255 Resp=0005
Starting LBA of RW Request=001F2458  Length=FFFFFFFF
ProcessRWError -Read-   at LBA 001F2458  Sense Code=C3160080
FAIL Op=008F Resp=0003
InitiateMarkPendingReallocateRequest for disc_lba: 001F2458
FAIL Op=0065 Resp=0005!
(H) SATA Reset
 Post subject: Re: clicking Seagate ST1000DL002 data recovery
PostPosted: September 24th, 2018, 16:15
The heads died.
Since the drive was kind enough to give you signs that it's going to bite the dust soon, I'm assuming you've already backed up everything, no?
WD Trusted Partners
PostPosted: September 25th, 2018, 1:59
Thank you for the reply.
Because of the lack of space on my SSD, I could rescue only few gigabytes of the HDD content. Lot of my important data remained on the drive.
What is the method for getting remained data from this drive?
PostPosted: September 25th, 2018, 3:41
Head replacement, but it's not DIY....
Search for a lab to do it for you.
ACELab partner
Users browsing this forum: Bing [Bot], Google [Bot] and 30 guests
