 Post subject: Rosewood ST2000LM007
PostPosted: November 19th, 2018, 16:54
This drive spins up and comes ready but has no capacity showing. I adapted the ROM in PC3K, but do not get the handshake message and have no terminal access. I have swapped the ROM to a new board which is possible on these drives so I believe. Terminal output both before ROM adaptation and after are the same.
Boot 0x80M[LBA=0x00000406 EC=][LBA=0x00000457 EC=][LBA=0x0000048C EC=][LBA=0x0000048C EC=]
DSC PASS[LBA=0x0000CF67 EC=][LBA=0x0000D00B EC=][LBA=0x0000D00B EC=]
SimError - Remaining in BootFW
00001002Perform a double download without a power cycle
Could be head failure but wanted to get input from you guys.
 Post subject: Re: Rosewood ST2000LM007
PostPosted: November 19th, 2018, 23:48
Have you tried to make rom adaption between original and donor? It could enable you to get access to terminal in some cases
PostPosted: November 20th, 2018, 5:09
Most likely the ROM is incorrect, or possibly SA is unreadable due to damage. Check if the serial number matches.
PostPosted: November 20th, 2018, 9:45
+1
No bitcoin donations :)
PostPosted: November 20th, 2018, 11:53
Thanks everyone. I should have stated that the ROM SN and drive SN do match. Looks like ROM corruption.
Users browsing this forum: Google Adsense [Bot], mingo1977 and 15 guests
