 Post subject: WD10JMVW 11AJGS3
PostPosted: November 1st, 2018, 4:14
Hi
I have this drive from wd may passport, it recognised by windows and MRT and even I can do logical test, but MRT dont recognised any information about family and etc, I try to write loader using module 1b 11 and 411 and succesfull to do that, but notting changed, any help guys?
A Beginner in Data Recovery with MRT Ultra
 Post subject: Re: WD10JMVW 11AJGS3
PostPosted: November 1st, 2018, 8:23
Maybe reading is difficult because of issues with pending process, or maybe is SED locked limiting access - without more information any responses will be relatively vague....
PostPosted: November 1st, 2018, 8:53
That's it.
@OP
You have to bypass SED to get access to FW.
PostPosted: November 1st, 2018, 10:00
unknown wrote:
That's it.
@OP
Im new hear ,what is SED, could you tell me how to bypass SED?
PostPosted: November 1st, 2018, 10:27
If you can do logic scan why are you messing with firmware ? Just clone/image the drive if you do need the data ?
If you do have access to LBA at a reasonable speed there shouldn't be any need to gain access to SA unless you want to patch 02, etc ...
PostPosted: November 1st, 2018, 10:49
I can logical scan , but drive have some bad sectors and during scan its stuck and reset ,in generally hard drive is not fully fanctional!
PostPosted: November 1st, 2018, 11:23
Clone / image it with MRT DE ?
PostPosted: November 1st, 2018, 14:37
Data is not important, i want to repair drive.
PostPosted: November 1st, 2018, 14:52
Don't bother. Buy new one.
PostPosted: November 2nd, 2018, 14:55
Can u explain more? what is problem of drive? it not my drive but a client, so I want to repair.
PostPosted: November 2nd, 2018, 15:47
The issue could be many things. But with a 1TB hard drive costing $50, its not worth risking fixing a drive that may (or more likely will) fail again. Besides surely you are charging more than the cost of a new drive to fix a bad one!!
PostPosted: November 2nd, 2018, 21:02
in your country yes but in mine, 50$ for us its like 500$ for you, so its worth to repiar drive for client.
PostPosted: November 3rd, 2018, 15:07
You will not be able to fix it. Same way you can't revive dead people ! lol
Let it Rest in Peace. Buy a new drive.
PostPosted: November 4th, 2018, 2:53
can you explain what is problem? beacuse in first sight it seem not major problem.
PostPosted: November 4th, 2018, 3:09
unknown wrote:
That's it.
@OP
how to bypass SED ?
PostPosted: November 4th, 2018, 12:14
Problem :
So you do need to ger rid of SED by patching module 02, and then either move G to P and keep on scanning and adding defects to P or try to run SS if possible or run ARCO if possible ...
But those high capacity drives normaly when start to have bad blocks will die shortly even if you do manage to SS them. Surface might be damaged, heads might be dying, etc ...
You can't fix physical damage with software / VSCs and the fact that the PCB is USB only doesn't help ... Just replace the drive. It's safer and faster.
PostPosted: November 5th, 2018, 4:39
this is log from mrt
is there any hope ?
i cant logic scan anymore
Users browsing this forum: Bing [Bot] and 12 guests
