 Post subject: How to identify firmware version in WD tag?
PostPosted: November 18th, 2018, 19:35
I have a WD that comes without ROM.
It is a WD5000LPVX.
Is there any way to know the firmware version it carries?
Another curiosity that comes to me. How can I make a WD not work with copy 0 of the SA and only work with copy 1?
Thanks in advance.
 Post subject: Re: How to identify firmware version in WD tag?
PostPosted: November 18th, 2018, 19:51
Simple ...
Get a compatible PCB. Use ROM + LOADER to gain access to drive SA. When you do have access to drive firmware you can check for example overlay for version, etc ....
PostPosted: November 18th, 2018, 19:52
Thanks in advance.
Block SA regions on ROM ? Block only reading from copy 0 ?
At any rate why would you want to do this ? Better to move SA to another head if head 0 is gone ...
PostPosted: November 18th, 2018, 20:01
Thanks, that's what I use when I rebuild a ROM, I wanted to know if there was any other way.
Tomorrow if the work leaves me time I will try to see how to modify the ROM to work only with a copy of the SA. In particular I would be interested in using only copy 1.
Greetings and thanks again.
PostPosted: November 18th, 2018, 20:04
That option also fits me.
The only thing I still do not know how to do it so that he does not read from copy 0.
Tomorrow I will do tests with a good HDD and comment.
PostPosted: November 18th, 2018, 20:12
Edit ROM SA regions ?
PostPosted: November 19th, 2018, 14:28
1. ask WD guys if you know any
2. you can try to guess it by DOM
https://www.linkedin.com/in/artemrubtsov/
Users browsing this forum: Google [Bot] and 44 guests
