 Post subject: diskpart has encountered an error the parameter is incorrect
PostPosted: December 12th, 2018, 5:41
diskpart has encountered an error the parameter is incorrect,,,
Hi anyone have solutions please???
 Post subject: Re: diskpart has encountered an error the parameter is incor
PostPosted: December 12th, 2018, 15:59
Try with another tool ?
Do you need the data ? Hopefully not.
Zero fill the drive, re-format it and re-partition the drive with another tool ...
And don't forget to test the drive for errors ... check S.M.A.R.T., do a full LBA scan .... etc ...
PostPosted: December 13th, 2018, 6:05
Hi,Thanks for replying,,,I do all but not working!!! i am 100% sure it is a software issu. zero fill going to 100% and success!!! but the drive is not going to a specifi file system.means dont goes to ntfs or fat32,it shows windows was unable to compleate the format,,,or in diskpart after goes 100% it shows incorrect parameter,,,i think its hard disk firmware issu and not a minor problem
PostPosted: December 13th, 2018, 15:14
Testing hard disks with some confidence :
If this doesn't help replace the drive ...
And check other system components like PSU and motherboard ...
http://www.hddoracle.com/viewtopic.php?f=56&t=2590
Users browsing this forum: No registered users and 52 guests
cron
