 Post subject: Dolphin users can fix the Seagate LM partial sector
PostPosted: December 7th, 2018, 5:04
Recently, I found that DFL released a tutorial on LM partial user sector access on their official website. I heard that someone has solved this problem. It seems that this time it is true.It seems that this time they are the first.
https://www.dolphindatalab.com/how-to-u ... pair-tool/
 Post subject: Re: Dolphin users can fix the Seagate LM partial sector
PostPosted: December 9th, 2018, 17:29
If the entries in the NRGList are deleted and included in the PList and the translator is regenerated, should not the data be lost?
PostPosted: December 9th, 2018, 19:24
mhp666 wrote:
If you include the entries on the P-List i would think that if done correctly the LBAs wouldn't shift as they would still point to the same PBAs ... Might be wrong.
I will do the test when I can. Although it could work for one firmware version and for another no. I have no idea.
Greetings.
PostPosted: December 10th, 2018, 23:32
LM? is it Seagate rosewood?
PostPosted: December 11th, 2018, 3:07
Yes, the most complicated one currently
PostPosted: December 17th, 2018, 22:02
translator issue of Rosewood always caused by a bad sys file , it seems request more experience rather than a tool solution.
I agree with @Spildit
PostPosted: December 17th, 2018, 23:09
Banned User
Dolphin Data Lab has received more and more Seagate LM partial sector access data recovery cases and over 99% cases have been perfectly recovered and returned to clients with happiness.
the news seems reliable to some degree.
https://www.dolphindatalab.com/seagate- ... recovered/
PostPosted: December 21st, 2018, 10:51
"For these cases, only Dolphin engineers are able to fix them manually and get lost data recovered."
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 48 guests
