 Post subject: What is PBM , PGM , PPM... extensions R Studio Find it
PostPosted: January 4th, 2019, 8:10
I have a Toshiba hdd. Customer have made Windows recover to old laptop hdd.
New windows have made a new D partition. And he lost all data.
I have searched with RStudio.
But there aren't any known files and any old partitions.. Found some kind of big files that has PBM PGM PPM ... extensions. Tried to search with some another programs. Same.
I leave searched in Hex NFTS, EXIF , and some different things. I cannot find anything.
Searched internet. Says PBM PGM PPM are some graphic or picture format. I tried to open it. But not opening. Also guessed it was image files. Searched file by file. . Nothing . Guessed compressed file. WinRAR not opening.
I tried to remove HDD password and unlock with MRT. Nothing changed.
I have some more hdd for my experience. There are Some hdd has some situations.
I have a hdd had bit locker. RStudio finding same extension files .
My guess this hdd encrypted with bit locker.
Anyone has advice . What is that files. And how can I recover them
A Recovery Service In Turkey . Veri Kurtarma Türkiye https://www.digitalverikurtarma.com
Donor Drives hdddonormarket.com
 Post subject: Re: What is PBM , PGM , PBA... extension R Studio Find it
PostPosted: January 4th, 2019, 8:19
can you open one each file type with HxD and post screenshot of file from 0x0 ?
 Post subject: Re: What is PBM , PGM , PPM... extensions R Studio Find it
PostPosted: January 4th, 2019, 8:32
Probably user restore windows from factory media.
Use another software(ActivePartition recovery, WinHex,) you can try with MRT DE
But if he restore from factory media, then...
PostPosted: January 4th, 2019, 16:05
MRT DE
Yes he made factory restore
I tried MRT DE
PostPosted: January 4th, 2019, 16:19
PPM
PGM
PBM
PostPosted: January 4th, 2019, 16:21
And Also some known format extension files. Big size. kinda over 1 GB
PostPosted: January 4th, 2019, 17:55
Ok, here :
HddDonorMarket wrote:
- I have a Toshiba hdd.
-Customer have made Windows recover to old laptop hdd.
- New windows have made a new D partition. And he lost all data.
-I tried to remove HDD password and unlock with MRT. Nothing changed.
-I have a hdd had bit locker.
-My guess this hdd encrypted with bit locker.
1 - If a drive is LOCKED with ATA PASSWOR you will NOT HAVE any ACCESS TO LBA. Unlocking the HDD with MRT will do nothing. Drive was already unlocked to start with.
2 - Ask client if bitlocker was used and ask for bitlocker key.
3 - Your sectors are random garbage and not actual pictures. Data IS ENCRYPTED with 3rd party tools like Bitlocker, Truecrypt, etc.
4 - Re-Installing from the recovery CDs, etc did wipe the encryption keys and setting/partitons, etc ... so you are in for PAIN ...
5 - Most likely it's un-recoverable unless you can :
- Do a full clone
- Try to force full decryption with RepairBDE - http://www.hddoracle.com/viewtopic.php?f=94&t=542
- Use logic recovery ....
But most likely keys are gone and data is encrypted forever and un-recoverable ...
PostPosted: January 4th, 2019, 20:50
Hi, Googling for: PPM PBM PGM format
https://en.wikipedia.org/wiki/Netpbm_format
http://paulbourke.net/dataformats/ppm/
I haven't looked to see if files match these specs or not, but magic number appears to be about right.
if files are intact, the utility at second link may be able to save files in another format to better use them.
what folder were they in, or where were the files found relating to user file saving locations / OS worker files / Application specific folders? An application installed on the PC may provide some insight in what the files are for etc.
PostPosted: January 5th, 2019, 5:25
Spildit wrote:
Ok, here :
- Do a full clone
Thanks. I will send back this hdd to customer I guess.. But have at least another 2 hdd (garbage ) in my stock. Look like Same case. I will try with them.
PostPosted: January 5th, 2019, 5:33
Not in a folder. R Studio putting in Graphic parts . Folder names PBM , PGM, PPM.
In order to that link , that files 1st sector information look like PBM PGM PPM file. But data is not belong to that file types.
So my guess look like true. Some kind encryption . And I don't know which !!!!
Like a nightmare )))
Bring it back. And relax )))
I will try to find that kind cases solution. Maybe in future. Not now
Thanks for replies.
PostPosted: January 5th, 2019, 16:38
Your welcome ! Too bad that you couldn't solve this one but most likely it's impossible to solve if client isn't going to provide at least what was used for encryption even less a "key" to decrypt ... Assuming of course that the data is indeed encrypted ....
Well better luck next time. We can't allways win...
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 61 guests
