 Post subject: Seek_Error_Rate on 1[TB] HGST Drive
PostPosted: February 5th, 2019, 20:12
Hi. I'm new in this forum. I want to ask you about a disk that I have purchased. The disk was taken from a new notebook to which an SSD was placed.
It is a guy who is dedicated to selling notebooks, which changes the disk that comes by default by an SSD disk at the request of customers.
The disk is a 1[TB] HGST Z5K1 (HTS541010B7E610). Attached below the gSmartControl LOG that I did as soon as I received it:
smartctl 6.6 2016-05-31 r4324 [x86_64-linux-4.15.0-43-generic] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     HGST HTS541010B7E610
Serial Number:    WXN1AA7K3JAR
LU WWN Device Id: 5 0014ee 6083c2672
Firmware Version: 03.01A03
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Form Factor:      2.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Fri Feb  1 01:06:46 2019 -03
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is:   Unavailable
APM level is:     254 (maximum performance)
Rd look-ahead is: Enabled
Write cache is:   Enabled
ATA Security is:  Disabled, frozen [SEC2]
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)   Offline data collection activity
               was never started.
               Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)   The previous self-test routine completed
               without error or no self-test has ever
               been run.
Total time to complete Offline
data collection:       (  660) seconds.
capabilities:           (0x51) SMART execute Offline immediate.
               No Auto Offline data collection support.
               Suspend Offline collection upon new
               command.
               No Offline surface scan supported.
               Self-test supported.
               No Conveyance Self-test supported.
               Selective Self-test supported.
SMART capabilities:            (0x0003)   Saves SMART data before entering
               power-saving mode.
               Supports SMART auto save timer.
Error logging capability:        (0x01)   Error logging supported.
               General Purpose Logging supported.
Short self-test routine
recommended polling time:     (   2) minutes.
Extended self-test routine
recommended polling time:     (  73) minutes.
SCT capabilities:           (0x303d)   SCT Status supported.
               SCT Error Recovery Control supported.
               SCT Feature Control supported.
               SCT Data Table supported.
SMART Attributes Data Structure revision number: 32
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   100   100   050    -    0
  3 Spin_Up_Time            POS--K   057   056   021    -    1266
  4 Start_Stop_Count        -O--CK   100   100   000    -    19
  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    0
  7 Seek_Error_Rate         POSR-K   100   100   030    -    37404
  9 Power_On_Hours          -O--CK   100   100   000    -    12
10 Spin_Retry_Count        PO--CK   100   100   050    -    0
12 Power_Cycle_Count       -O--CK   100   100   000    -    17
183 Runtime_Bad_Block       -O--CK   100   100   000    -    0
184 End-to-End_Error        PO-RCK   100   100   097    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
188 Command_Timeout         -O--CK   100   100   000    -    0
189 High_Fly_Writes         -O-RCK   100   100   000    -    0
191 G-Sense_Error_Rate      -O--CK   072   072   000    -    28
192 Power-Off_Retract_Count -O--CK   100   100   000    -    25769803782
193 Load_Cycle_Count        -O--CK   100   100   000    -    245
194 Temperature_Celsius     -O---K   035   040   000    -    35 (Min/Max 28/37)
197 Current_Pending_Sector  -O--CK   100   100   000    -    0
198 Offline_Uncorrectable   ----CK   100   100   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   100   100   000    -    0
200 Multi_Zone_Error_Rate   ---R--   200   200   000    -    0
240 Head_Flying_Hours       -O--CK   100   100   000    -    6726
243 Unknown_Attribute       -O--CK   100   100   000    -    8238
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      6  Ext. Comprehensive SMART error log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  SATA NCQ Queued Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x24       GPL     R/O    277  Current Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS      16  Device vendor specific log
0xa8-0xb6  GPL,SL  VS       1  Device vendor specific log
0xb7       GPL,SL  VS      74  Device vendor specific log
0xbd       GPL,SL  VS       1  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL     VS      93  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 26 (device log contains only the most recent 24 errors)
   CR     = Command Register
   FEATR  = Features Register
   COUNT  = Count (was: Sector Count) Register
   LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
   LH     = LBA High (was: Cylinder High) Register    ]   LBA
   LM     = LBA Mid (was: Cylinder Low) Register      ] Register
   LL     = LBA Low (was: Sector Number) Register     ]
   DV     = Device (was: Device/Head) Register
   DC     = Device Control Register
   ER     = Error register
   ST     = Status register
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 26 [1] occurred at disk power-on lifetime: 7 hours (0 days + 7 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  04 -- 51 00 00 00 00 00 00 00 02 e0 00
  Commands leading to the command that caused the error were:
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     00:04:21.800  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     00:04:21.800  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 00 e0 00     00:04:21.527  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 21 e0 00     00:04:21.524  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     00:04:21.524  READ DMA EXT
Error 25 [0] occurred at disk power-on lifetime: 7 hours (0 days + 7 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     00:00:03.857  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     00:00:03.857  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 00 e0 00     00:00:03.559  READ DMA EXT
  25 00 00 00 20 00 00 74 70 6d 8f e0 00     00:00:03.558  READ DMA EXT
  25 00 00 00 20 00 00 00 00 00 02 e0 00     00:00:03.557  READ DMA EXT
Error 24 [23] occurred at disk power-on lifetime: 7 hours (0 days + 7 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     02:37:20.094  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     02:37:20.094  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 00 e0 00     02:37:15.998  READ DMA EXT
  25 00 00 00 20 00 00 74 70 6d 8f e0 00     02:37:15.995  READ DMA EXT
  25 00 00 00 20 00 00 00 00 00 02 e0 00     02:37:15.995  READ DMA EXT
Error 23 [22] occurred at disk power-on lifetime: 7 hours (0 days + 7 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     02:31:01.363  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     02:31:01.363  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 00 e0 00     02:31:01.075  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 21 e0 00     02:31:01.072  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     02:31:01.072  READ DMA EXT
Error 22 [21] occurred at disk power-on lifetime: 7 hours (0 days + 7 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     02:19:43.665  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     02:19:43.665  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 00 e0 00     02:19:43.376  READ DMA EXT
  25 00 00 00 20 00 00 74 70 6d 8f e0 00     02:19:43.374  READ DMA EXT
  25 00 00 00 20 00 00 00 00 00 02 e0 00     02:19:43.374  READ DMA EXT
Error 21 [20] occurred at disk power-on lifetime: 6 hours (0 days + 6 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     01:58:37.213  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     01:58:37.212  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 00 e0 00     01:58:36.921  READ DMA EXT
  25 00 00 00 20 00 00 74 70 6d 8f e0 00     01:58:36.920  READ DMA EXT
  25 00 00 00 20 00 00 00 00 00 02 e0 00     01:58:36.920  READ DMA EXT
Error 20 [19] occurred at disk power-on lifetime: 5 hours (0 days + 5 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     00:50:13.500  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     00:50:13.500  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 00 e0 00     00:50:13.207  READ DMA EXT
  25 00 00 00 20 00 00 74 70 6d 8f e0 00     00:50:13.206  READ DMA EXT
  25 00 00 00 20 00 00 00 00 00 02 e0 00     00:50:13.205  READ DMA EXT
Error 19 [18] occurred at disk power-on lifetime: 5 hours (0 days + 5 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     00:43:42.870  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     00:43:42.870  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 00 e0 00     00:43:42.578  READ DMA EXT
  25 00 00 00 20 00 00 74 70 6d 8f e0 00     00:43:42.577  READ DMA EXT
  25 00 00 00 20 00 00 00 00 00 02 e0 00     00:43:42.576  READ DMA EXT
Error 18 [17] occurred at disk power-on lifetime: 5 hours (0 days + 5 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     00:32:45.985  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     00:32:45.984  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 00 e0 00     00:32:45.698  READ DMA EXT
  25 00 00 00 20 00 00 74 70 6d 8f e0 00     00:32:45.695  READ DMA EXT
  25 00 00 00 20 00 00 00 00 00 02 e0 00     00:32:45.695  READ DMA EXT
Error 17 [16] occurred at disk power-on lifetime: 4 hours (0 days + 4 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     00:00:06.994  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     00:00:06.994  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 00 e0 00     00:00:06.704  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 21 e0 00     00:00:06.702  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     00:00:06.702  READ DMA EXT
Error 16 [15] occurred at disk power-on lifetime: 4 hours (0 days + 4 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     00:47:16.446  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     00:47:16.446  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 21 e0 00     00:47:16.169  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     00:47:16.168  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 1f e0 00     00:47:16.168  READ DMA EXT
Error 15 [14] occurred at disk power-on lifetime: 4 hours (0 days + 4 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     00:04:28.211  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     00:04:28.211  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 21 e0 00     00:04:24.179  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     00:04:24.179  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 1f e0 00     00:04:24.179  READ DMA EXT
Error 14 [13] occurred at disk power-on lifetime: 3 hours (0 days + 3 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     00:00:02.752  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     00:00:02.752  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 21 e0 00     00:00:02.471  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     00:00:02.471  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 1f e0 00     00:00:02.471  READ DMA EXT
Error 13 [12] occurred at disk power-on lifetime: 3 hours (0 days + 3 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     00:00:03.100  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     00:00:03.097  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 21 e0 00     00:00:02.813  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     00:00:02.813  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 1f e0 00     00:00:02.813  READ DMA EXT
Error 12 [11] occurred at disk power-on lifetime: 3 hours (0 days + 3 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     03:12:53.555  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     03:12:53.555  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 21 e0 00     03:12:53.272  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     03:12:53.272  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 1f e0 00     03:12:53.272  READ DMA EXT
Error 11 [10] occurred at disk power-on lifetime: 3 hours (0 days + 3 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     03:08:52.203  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     03:08:52.203  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 21 e0 00     03:08:51.915  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     03:08:51.915  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 1f e0 00     03:08:51.915  READ DMA EXT
Error 10 [9] occurred at disk power-on lifetime: 3 hours (0 days + 3 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     02:50:56.456  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     02:50:56.456  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 21 e0 00     02:50:56.170  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     02:50:56.170  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 1f e0 00     02:50:56.169  READ DMA EXT
Error 9 [8] occurred at disk power-on lifetime: 2 hours (0 days + 2 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     01:28:05.396  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     01:28:05.395  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 21 e0 00     01:28:05.112  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     01:28:05.112  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 1f e0 00     01:28:05.111  READ DMA EXT
Error 8 [7] occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     00:05:01.974  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     00:05:01.974  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 21 e0 00     00:05:01.688  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     00:05:01.688  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 1f e0 00     00:05:01.687  READ DMA EXT
Error 7 [6] occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     00:00:06.332  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     00:00:06.332  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 21 e0 00     00:00:06.048  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     00:00:06.047  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 1f e0 00     00:00:06.047  READ DMA EXT
Error 6 [5] occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     00:00:03.482  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     00:00:03.482  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 00 e0 00     00:00:03.187  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 21 e0 00     00:00:03.184  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     00:00:03.184  READ DMA EXT
Error 5 [4] occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     00:00:03.375  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     00:00:03.374  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 00 e0 00     00:00:03.085  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 21 e0 00     00:00:03.083  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     00:00:03.082  READ DMA EXT
Error 4 [3] occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     00:00:26.493  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     00:00:26.493  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 00 e0 00     00:00:26.218  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 21 e0 00     00:00:26.216  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     00:00:26.216  READ DMA EXT
Error 3 [2] occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  b4 00 20 00 00 00 00 00 72 4c 6b e0 00     00:03:00.968  SANITIZE DEVICE
  f5 00 00 00 00 00 00 00 00 00 00 e0 00     00:03:00.968  SECURITY FREEZE LOCK
  25 00 00 00 01 00 00 00 00 00 00 e0 00     00:03:00.695  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 21 e0 00     00:03:00.693  READ DMA EXT
  25 00 00 00 01 00 00 00 00 00 20 e0 00     00:03:00.693  READ DMA EXT
SMART Extended Self-test Log Version: 1 (1 sectors)
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%        10         -
# 2  Short offline       Completed without error       00%         9         -
# 3  Short offline       Completed without error       00%         4         -
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version:                  3
SCT Version (vendor specific):       258 (0x0102)
SCT Support Level:                   1
Device State:                        Active (0)
Current Temperature:                    35 Celsius
Power Cycle Min/Max Temperature:     28/37 Celsius
Lifetime    Min/Max Temperature:     22/40 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/60 Celsius
Min/Max Temperature Limit:           -41/85 Celsius
Temperature History Size (Index):    128 (116)
Index    Estimated Time   Temperature Celsius
117    2019-01-31 22:59    36  *****************
...    ..(  2 skipped).    ..  *****************
120    2019-01-31 23:02    36  *****************
121    2019-01-31 23:03    35  ****************
...    ..( 36 skipped).    ..  ****************
  30    2019-01-31 23:40    35  ****************
  31    2019-01-31 23:41    34  ***************
...    ..(  5 skipped).    ..  ***************
  37    2019-01-31 23:47    34  ***************
  38    2019-01-31 23:48     ?  -
  39    2019-01-31 23:49    34  ***************
...    ..( 17 skipped).    ..  ***************
  57    2019-02-01 00:07    34  ***************
  58    2019-02-01 00:08    35  ****************
  59    2019-02-01 00:09    34  ***************
...    ..(  6 skipped).    ..  ***************
  66    2019-02-01 00:16    34  ***************
  67    2019-02-01 00:17    35  ****************
  68    2019-02-01 00:18    34  ***************
  69    2019-02-01 00:19    34  ***************
  70    2019-02-01 00:20    34  ***************
  71    2019-02-01 00:21    35  ****************
  72    2019-02-01 00:22    35  ****************
  73    2019-02-01 00:23    34  ***************
  74    2019-02-01 00:24    35  ****************
  75    2019-02-01 00:25    34  ***************
...    ..( 15 skipped).    ..  ***************
  91    2019-02-01 00:41    34  ***************
  92    2019-02-01 00:42     ?  -
  93    2019-02-01 00:43    34  ***************
...    ..(  4 skipped).    ..  ***************
  98    2019-02-01 00:48    34  ***************
  99    2019-02-01 00:49    35  ****************
...    ..( 16 skipped).    ..  ****************
116    2019-02-01 01:06    35  ****************
SCT Error Recovery Control:
           Read:     85 (8.5 seconds)
          Write:     85 (8.5 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2           29  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2           32  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000d  2            0  Non-CRC errors within host-to-device FIS
0x000f  2            0  R_ERR response for host-to-device data FIS, CRC
0x0012  2            0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4        12718  Vendor specific
I have also made performance measurements with the Ubuntu Disks tool (Some screeshots are in Spanish, sorry :)),
It also passes correctly to SMART tests.
I could not find detailed information about SMART data for HGST disks.
There are ATA errors (26) on the disk but all correspond, according to the LOG, to the first 7 hours of disk life. I suppose they correspond to the period in which the disc was in the factory. What worries me are two values. On the one hand G-Sense_Error_Rate, which originally was 28, and has increased to 33.
On the other hand, the RAW value of the variable Seek_Error_Rate, which changes all the time when operations are performed on the disk. The value changes increasing until it reaches a value between 65000 and 66000 (I assume that it must be 65535, for a 16 bit register), after which it restarts to zero and starts growing again. I attached a video conformed with screenshots of the moment it is restarted. The mentioned thing is observed while updating the SMART values ​​in gSmartControl (I was making copies of files on the disk at the same time). Screenshots were taken approximately every two seconds. Can you assume that the RAW value is actually an error counter? Since the normalized values ​​have not changed after copying approximately 500GB of junk files to disk.
File comment: [VIDEO] Seek_Error_Rate Reboot moment
Seek_Error_Rate_Restart.zip [282.37 KiB]
Downloaded 30 times
When there is no operation on the disk the value of Seek_Error_Rate increases very slowly (this was what worried me originally). As mentioned before, when performing operations on the disk, the value is triggered and begins to rise rapidly until reaching the mentioned threshold in which it is restarted, but the normalized value has not changed after 500 Gb of file copy.
I use Ubuntu 18.04 as my main system, but I have a partition with Windows 10, on which I have run CrystalDiskInfo.This is a capture of the SMART data represented on a hexadecimal basis.
I still have seven days to return the disk without costs, and I try to determine if the disk has problems. Is it possible that this behavior is normal?
Thank you very much for your answers.
Apologies for my bad English! Greetings.
 Post subject: Re: Seek_Error_Rate on 1[TB] HGST Drive
PostPosted: February 5th, 2019, 22:30
ISTM that your drive is a rebadged WD model. I haven't noticed that WD's new Seek Error Rate attributes have changed in the way that you have discovered, but you seem to have interpreted them correctly. FWIW, Seagate's drives count up to 250 million seeks before rolling over. ISTM that there is nothing to be concerned about.
Users browsing this forum: Google Adsense [Bot] and 32 guests
cron
