 Post subject: Power indicators and registers tabs not visible in pc3000
PostPosted: July 30th, 2019, 5:00
Suddenly +5V /+12V power indication and status register pane has disappeared in my pc3000 , I have tried to search specific settings but not able to find it.
Can someone pls.guide how to enable view again.
thanks.
 Post subject: Re: Power indicators and registers tabs not visible in pc300
PostPosted: July 30th, 2019, 7:16
Try contacting ace tech support.
RAID Data Recovery
PostPosted: July 30th, 2019, 9:36
hi lcoughey
Unfortunately I dont have TS running ,so cant get tech support
PostPosted: July 30th, 2019, 10:19
still worth creating a ticket with them. They won't answer if you don't ask. The worse that they can say is that your support has expired.
RAID Data Recovery
PostPosted: July 30th, 2019, 15:19
Luke ,
This They Will Not Do They Will Definitely Solve His Issue ,He Is Not Taking Support In The Real Sense But Has a Issue With Product ,Secondly Reinstall The Last Version You Installed Might Be it Works Again
Users browsing this forum: Google [Bot], MSN [Bot] and 34 guests
