 Post subject: WD20NMVW-11EDZS7 Shrek LT Module Problem ???
PostPosted: May 12th, 2019, 21:50
sn: wxa1eb6d9hoj
dcx DE70BWZ9
dcm EHMTJBKB
date 01 sep 2017
Working with MRT
1 week ago I have looked this drive. I coulnt see any ID info and any modules. I guessed dead head case.
Today I decided to try with LDR.
I tried this http://files.hddguru.com/index.php?acti ... hrek%20LT&
I can get XYZ with 0 gb.
I Could check heads :
H0, 1 , 2 , 3 fine
4 5 6 7 8 bad
I Could read some modules. backed up
BY ID: 01 31 33
COPY 1 : 0C 01 02 03 32 35 36 40 49
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 8
Head map : .....................................: FF
SA Cyl Count : .................................: 256
Serials Mark : .................................: 0xFE16
Control version : ..............................: A5C0
Zone allocation table : ........................: Err
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 256 Kb
ROM version : ..................................: 21.4AH
ROM generation : ...............................: 21.4AH
Link table version : ...........................: N0.41
ROM Firmware version : .........................: 0021004A
ROM Modules:
Flash ROM dir reading : ........................: OK
Switched off heads : ...........................: Yes
Heads number : .................................: 0x8
Heads number in use : ..........................: 0x8
heads map : ....................................: 0,1,2,3,4,5,6,7
Load LDR(0x1B), As permanent overlay...
Send Data(0x1B) : ..............................: OK
Load LDR(0x11), As permanent overlay...
Send Data(0x11) : ..............................: Err(Send Data Fail)
Load LDR : .....................................: Err
load 01...
load 01 to HDD RAM...
The data source : ..............................: HDD
Get 01 module from HDD : .......................: OK
Load module list : .............................: OK
Open SA access ...
Get SA access information : ....................: OK
Check SA access data : .........................: OK
Open SA access : ...............................: OK
Load LDR : .....................................: OK
load 01...
Zone allocation table : ........................: OK
SA SPT : .......................................: 1480
Open SA access ...
Load LDR(0x411), As permanent overlay...
Send Data(0x411) : .............................: OK
load 01...
Open SA access ...
Upload 02 ...
Get module list from HDD : .....................: OK
Get 02 module from HDD : .......................: failed
Upload 02 ...
Executing SA structure test
ID    :   Copy    : Importance :   ABA      : Size   : Read  : Hdr   :  CS Value     calc/read    : Version       : Desription
0001  :   ByID   :      B     :   00119812 :     20 :    Ok :    Ok :           1AFA6807/1AFA6807 :     00020000 :  Modules directory
0035  :   ByID   :     Dd     :   00000032 :      A :    Ok :    Ok :           4AF42212/4AF42212 :     1028-D50 :  SA Defects
0002  :   ByID   :      B     :   00119844 :      5 :   Err :   Err :           00000000/00000000 :  not find    :  Configuration (HDD ID)
0011  :   ByID   :      B     :   00120832 :    566 :   Err :   Err :           00000000/00000000 :  not find    :  microprogram code
0033  :   ByID   :     Dd     :   00002524 :    4EC :    Ok :    Ok :           2CE1F777/2CE1F777 :     00150000 :  P-List (Primary defect list)
0031  :   ByID   :     Ad     :   00003784 :    5A5 :    Ok :    Ok :           45AB8DB0/45AB8DB0 :     00400000 :  Translator
000C  :   ByID   :      B     :   00005229 :      C :    Ok :    Ok :           8B0FD7A3/8B0FD7A3 :     00010100 :  Models table
0032  :   ByID   :     Ad     :   00005289 :     3C :    Ok :    Ok :           70E66943/70E66943 :     00170000 :  Relo Bad Block Module
0036  :   ByID   :     Ad     :   00005349 :     2C :    Ok :    Ok :           338D7881/338D7881 :     00010000 :  T-List Module
0040  :   ByID   :     As     :   00005404 :    226 :    Ok :    Ok :           C0697EDE/C0697EDE :     00010000 :  Adaptive data
0049  :   ByID   :     As     :   00008922 :      E :    Ok :    Ok :           669706A8/669706A8 :     00010000 :  Adaptive data
0003  :   ByID   :     As     :   00008970 :    151 :    Ok :    Ok :           E095E5CA/E095E5CA :     00020000 :  Format Select Data Module
SA structure test is completed!
0001  :   Copy0   :      B     :   00119812 :     20 :    Ok :    Ok :           1AFA6807/1AFA6807 :     00020000 :  Modules directory
0035  :   Copy0   :     Dd     :   00000032 :      A :    Ok :    Ok :           4AF42212/4AF42212 :     1028-D50 :  SA Defects
0002  :   Copy0   :      B     :   00119844 :      5 :    Ok :   Err :           9656D869/58585858 :     XXXXXXXX :  Configuration (HDD ID)
0011  :   Copy0   :      B     :   00120832 :    566 :   Err :   Err :           00000000/00000000 :  not find    :  microprogram code
0033  :   Copy0   :     Dd     :   00002524 :    4EC :   Err :   Err :           00000000/00000000 :  not find    :  P-List (Primary defect list)
0031  :   Copy0   :     Ad     :   00003784 :    5A5 :   Err :   Err :           00000000/00000000 :  not find    :  Translator
000C  :   Copy0   :      B     :   00005229 :      C :    Ok :    Ok :           8B0FD7A3/8B0FD7A3 :     00010100 :  Models table
0032  :   Copy0   :     Ad     :   00005289 :     3C :    Ok :    Ok :           70E66943/70E66943 :     00170000 :  Relo Bad Block Module
0036  :   Copy0   :     Ad     :   00005349 :     2C :    Ok :    Ok :           338D7881/338D7881 :     00010000 :  T-List Module
0040  :   Copy0   :     As     :   00005404 :    226 :    Ok :    Ok :           C0697EDE/C0697EDE :     00010000 :  Adaptive data
0049  :   Copy0   :     As     :   00008922 :      E :    Ok :    Ok :           669706A8/669706A8 :     00010000 :  Adaptive data
0003  :   Copy0   :     As     :   00008970 :    151 :    Ok :    Ok :           E095E5CA/E095E5CA :     00020000 :  Format Select Data Module
0001  :   Copy1   :      B     :   00498692 :     20 :    Ok :    Ok :           F4F98125/1AFA6807 :     00020000 :  Modules directory
0035  :   Copy1   :     Dd     :   00378912 :      A :    Ok :    Ok :           4AF42212/4AF42212 :     1028-D50 :  SA Defects
0002  :   Copy1   :      B     :   00498724 :      5 :    Ok :   Err :           D9F0E851/54D0BE71 :     °T_Ô³}±E :  Configuration (HDD ID)
0011  :   Copy1   :      B     :   00499712 :    566 :   Err :   Err :           00000000/00000000 :  not find    :  microprogram code
0033  :   Copy1   :     Dd     :   00381404 :    4EC :   Err :   Err :           00000000/00000000 :  not find    :  P-List (Primary defect list)
0031  :   Copy1   :     Ad     :   00382664 :    5A5 :   Err :   Err :           00000000/00000000 :  not find    :  Translator
000C  :   Copy1   :      B     :   00384109 :      C :    Ok :    Ok :           8B0FD7A3/8B0FD7A3 :     00010100 :  Models table
0032  :   Copy1   :     Ad     :   00384169 :     3C :    Ok :    Ok :           70E66943/70E66943 :     00170000 :  Relo Bad Block Module
0036  :   Copy1   :     Ad     :   00384229 :     2C :    Ok :    Ok :           338D7881/338D7881 :     00010000 :  T-List Module
0040  :   Copy1   :     As     :   00384284 :    226 :    Ok :    Ok :           C0697EDE/C0697EDE :     00010000 :  Adaptive data
0049  :   Copy1   :     As     :   00387802 :      E :    Ok :    Ok :           669706A8/669706A8 :     00010000 :  Adaptive data
0003  :   Copy1   :     As     :   00387850 :    151 :    Ok :    Ok :           E095E5CA/E095E5CA :     00020000 :  Format Select Data Module
Here report file:
WorkLog.rtf [46.9 KiB]
Downloaded 69 times
I checked Mode 02
Cannot read BY ID
COPY 0 starting with xxxxxxxxxxxxxx
COPY 1 looked ok.
I rewrited good m02 over one, but I dont remember which one have been writed by good m02. I guess rewrited copy0
Now there is no good mod 02 even ID, Copy0, copy 1.
I afraid rewrite it again. I couldnt decide which one is good copy.
Also there is no mod 11 except LDR file that I found.
and I couldnt see user data .
Need Help and advices.
Is it firmware problem or necessary to swap head. And which way should I follow?
Modules and log attached.
Modules.rar [140.73 KiB]
Downloaded 65 times
A Recovery Service In Turkey . Veri Kurtarma Türkiye https://www.digitalverikurtarma.com
Donor Drives hdddonormarket.com
 Post subject: Re: WD20NMVW-11EDZS7 Shrek LT Module Problem ???
PostPosted: May 13th, 2019, 3:34
Why don't you swap heads?
ACELab partner
PostPosted: May 13th, 2019, 5:18
i think you should swap the heads.
if 4 heads ok and rest of others heads are not working mean, there can be filter damage or platter damage or residue inside.
sometimes all heads have poor reading since HSA has an error like preamp.
so just try to swap the heads and check filters and other.
PostPosted: May 13th, 2019, 10:55
I am searching and waiting for donor.
Thanks for response
PostPosted: May 19th, 2019, 15:13
Changing the head block should be the last option and probably will not be the solution in this case.
As far as the op comments nothing indicates that the problem is heads (although it can be), but before changing the block of heads would look at other ways.
It is a shrek LT (SED)....... mod 11, 31, 02.... cannot be read..., well, nothing new on the horizon......
PostPosted: May 20th, 2019, 14:00
SED ?
I should consider this info. I had read ROM from USB PCB (patient), and writed to Sata PCB.
Patient hdd dropped case. I guessed head issue. I am researching a cheap donor still.
Users browsing this forum: FarazAhmad, Google [Bot], siamak5561 and 18 guests
