Post new topic Reply to topic  [ 86 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Old Maxtor recovery - I/O error
PostPosted: August 24th, 2019, 9:42
In fact the baud rate was wrong. In Spildit's guide is written for 7200.10 the baud rate is 9600. My mistake, thank you for pointing it out.
Here is the output although it is not really relevant
Reset
4096k x 32 DRAM
GALAXY2D - 1_Disk    S-6B   06-29-06_12:39
Buzz HM SFI
(P)SATA Reset
(H)SATA Reset
(----->typing ctrl+a)
Eng Rev = .0EW
Compat/Hardware = .6D1
GALAXY2D - 2_Disk    3.AAD  06-29-06_12:42 AAD,GX_2D_4H_S,3A
CERT Rev = .0AP
NONE
Mask Rom Rev = S-6B
Orig Code = AAD3A0 TONKA2_GX_3A0.0EW.0AP
(----->typing ctrl+l)
Built for GALAXY2D,PITKIN,Redback,TI1810 PreAmp,Agere7531 PreAmp,McKinleyDT,2Disk,220 Servos,7200RPM,8Pole,133MHz,RwFeat=0002,VBAR
The output is identical with both TTL adapters.
Okay. It seems I am now ready to try the faulty drive.
dick wrote:
Take note your drive to diagnose is a 7200.11 and your test drive is a 7200.10
Double checking the specs the drive appear to be a 7200.12
This time the baud rate should be 38400
And here it is ladies and gentlemen
Rst 0x10M
(P) SATA Reset
(----->typing ctrl+z)
ASCII Diag mode
F3 T>
Package Version: PH0G2D.CCD3.AA8400.CC38    , Package P/N: 100593077, Package Builder ID: AT,
Package Build Date: 09/18/2009, Package Build Time: 14:25:51, Package CFW Version: PH0G.CCD3.00205150.AT00,
Package SFW1 Version: D24C, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 09181425, CustomerRel: CC38, Changelist: 00205150, ProdType: PH0G.CCD3, Date: 09/18/2009, Time: 142551, UserId: 00236537
Servo FW Rev: D24C
RAP FW Implementation Key: 10, Format Rev: 0001, Contents Rev: A1 09 08 03
New Skews Pharaoh 0F with VTPI,RAP16,Common Code 3
Product FamilyId: 3F, MemberId: 05
HDA SN: 6VMAFKDM, RPM: 7201, Wedges: 120, Heads: 2, Lbas: 2542EAB0, PreampType: 73 03
PCBA SN: 0000K0249WQS, Controller: YETIST_3_*/4_0(649B)(3-12-3-3), Channel: AGERE_COPPERHEAD_LITE, PowerAsic: MCKINLEY DESKTOP LITE Rev 94, BufferBytes: 1000000
Servo FW Rev: D24C
Features:
- Quadradic Equation AFH enabled
- VBAR with adjustable zone boundaries enabled
- Volume Based Sparing enabled
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled
- LTTC-UDR2 disabled
PostPosted: August 30th, 2019, 14:40
I had a look around for the first line in the log: Rst 0x10M, but very little came up. Does anyone know its meaning?
Following the commands list the drive very kindly provided. Where could I start to investigate the source of the I/O error?
There are a lot of interesting entries I would like to try but I'd rather wait for your advice..
Thank you for your time
Rst 0x10M
(P) SATA Reset
ASCII Diag mode
F3 T>/c
F3 C>Q
Online CR: Rev 0011.0000, Flash,   Abort
Online ESC: Rev 0011.0000, Flash,   Abort Looping Command or Batch File
Online ' ': Rev 0001.0000, Flash,   Pause Output
Online '.': Rev 0011.0000, Flash,   Display Active Status
Online '?': Rev 0011.0000, Flash,   Display Diagnostic Buffer Information
Online '`': Rev 0012.0001, Flash,   Display Read/Write Statistics
Online '$': Rev 0012.0001, Flash,   Display Read/Write Statistics By Zone
Online '{': Rev 0011.0000, Flash,   Toggle EIB-Specific R/W Tracing
Online ^D: Rev 0011.0000, Flash,   Toggle R/W Tracing
Online ^N: Rev 0011.0000, Flash,   Toggle R/W Tracing
Online ^W: Rev 0011.0000, Flash,   Enable and Init RW Statistics
Online ^O: Rev 0001.0000, Flash,   Advance Servo Tracing State
Online '!': Rev 0011.0000, Flash,   Display Current Read Channel Settings
Online '<': Rev 0011.0000, Flash,   Decrement Read/Write Scope Sync
Online '>': Rev 0011.0000, Flash,   Increment Read/Write Scope Sync
Online '~': Rev 0011.0000, Flash,   Display Native Interface Command State
Online ^A: Rev 0012.0000, Flash,   Display Firmware Revision
Online ^B: Rev 0012.0000, Flash,   Get Thermistor Temperature
Online ^C: Rev 0011.0000, Flash,   Firmware Reset
Online ^E: Rev 0011.0000, Flash,   Display Native Interface Configuration
Online ^F: Rev 0011.0000, Flash,   Display Native Interface Read Cache Information
Online ^I: Rev 0011.0000, Flash,   Display Controller Registers
Online ^K: Rev 0011.0000, Flash,   Display DST Status
Online ^L: Rev 0013.0000, Flash,   Display Sign On Message
Online ^P: Rev 0011.0000, Flash,   Toggle Diag Idle Mode
Online ^Q: Rev 0011.0000, Flash,   Resume Interface Task
Online ^R: Rev 0011.0000, Flash,   Enable ASCII Online Serial Port Mode
Online ^S: Rev 0011.0000, Flash,   Pause Interface Task
Online ^T: Rev 0011.0000, Flash,   Enable ESLIP Serial Port Mode
Online ^U: Rev 0011.0000, Overlay, Display Congen
Online ^V: Rev 0011.0000, Overlay, Toggle Interface Command Echo
Online ^X: Rev 0011.0000, Flash,   Display Native Interface and Read/Write Command History
Online ^Y: Rev 0011.0000, Flash,   Display DST Status
Online ^Z: Rev 0011.0000, Flash,   Enable ASCII Diagnostic Serial Port Mode
Online ^\: Rev 0011.0000, Flash,   Toggle Debug Display Enable
All Levels CR: Rev 0011.0000, Flash,   Abort
All Levels '/': Rev 0001.0000, Flash,   Change Diagnostic Command Level, /[Level]
All Levels '+': Rev 0012.0000, Flash,   Peek Memory Byte, +[AddrHi],[AddrLo],[NotUsed],[NumBytes]
All Levels '-': Rev 0012.0000, Flash,   Peek Memory Word, -[AddrHi],[AddrLo],[NotUsed],[NumBytes]
All Levels '=': Rev 0011.0002, Flash,   Poke Memory Byte, =[AddrHi],[AddrLo],[Data],[Opts]
All Levels '@': Rev 0001.0000, Overlay, Batch File Label, @[LabelNum]
All Levels '|': Rev 0001.0000, Overlay, Batch File Terminator, |
All Levels '*': Rev 0011.0000, Overlay, Special Batch File Function, *[FuncId],[FuncParm0],[FuncParm1]
All Levels 'A': Rev 0011.0000, Overlay, Set Test Space, A[OptsOrParmSelect],[ParmValue],[AddrType],[HdForCylLimit]
All Levels 'L': Rev 0001.0002, Overlay, Enable Looping, L[Opts],[CountOrStopOnErrCode]
Level 1 'S': Rev 0011.0001, Flash,   Edit Processor Memory Byte, S[AddrHi],[AddrLo],[MemValue],[NumBytes],[Opts]
Level 1 'U': Rev 0011.0001, Flash,   Edit Buffer Memory Byte, U[AddrHi],[AddrLo],[MemValue],[NumBytes]
Level 1 'e': Rev 0011.0000, Flash,   Spin Down and Reset Drive, e[MsecDelay],[Opts]
Level 1 'm': Rev 0011.0001, Flash,   Edit Processor Memory Word, m[AddrHi],[AddrLo],[MemValue],[NumBytes],[Opts]
Level 1 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits]
Level 1 'D': Rev 0011.0001, Overlay, Memory Block Display, D[AddrHi],[AddrLo],[CompVal],[NumBytes],[Opts],[SizeInBytes]
Level 1 'G': Rev 0011.0000, Overlay, Generic Read/Write Request, G[Parm0],[Parm1],[Parm2],...[Parm9]
Level 1 'I': Rev 0001.0000, Overlay, Buffer DLL Tune, I[action][DLL]
Level 1 'N': Rev 0015.0000, Overlay, SMART Control, N[SubCmd],[SubCmdParm0],[SubCmdParm1]
Level 1 'c': Rev 0011.0000, Overlay, Buffer Compare, c[SrcBlk],[RefBlk],[NumBlks],[ContOnErr]
Level 1 'j': Rev 0001.0000, Overlay, Display Hardware Jumper Setting, j[HardwareJumperSelect]
Level 2 'J': Rev 0001.0000, Flash,   Particle Sweep, J[ Start Cyl ],[ End Cyl ],[ Duration mSec ],[ Dwell mSec ],[ JIT mode ]
Level 2 'U': Rev 0011.0000, Flash,   Spin Up Drive, U[HoldState],[Hd],[Cyl]
Level 2 'Z': Rev 0011.0000, Flash,   Spin Down Drive, Z
Level 2 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits]
Level 2 'C': Rev 0011.0000, Overlay, Buffer Copy, C[SrcBlk],[DestBlk],[NumBlks]
Level 2 'E': Rev 0012.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level 2 'F': Rev 0011.0000, Overlay, Modify Track Defect List, F[PSctr/LBA],[Action]
Level 2 'H': Rev 0011.0000, Overlay, Select Logical Head, H[Hd],[SkType],[Options]
Level 2 'I': Rev 0011.0003, Overlay, Display / Modify Adaptive Parameter, I,[GroupId]
Level 2 'K': Rev 0011.0000, Overlay, Set Tracking Offset, K[OffsetValue],[PersOrTempOpt],[UnitsOpt],[ChanReload]
Level 2 'M': Rev 0012.0000, Overlay, Set Diag Idle Mode, M[ModeSelect],[ModeMask],[ResetToPowerOn]
Level 2 'N': Rev 0001.0000, Overlay, Set Direct Write Mode, N[EnableDirWrtModeOpt]
Level 2 'O': Rev 0011.0000, Overlay, Seek Repeatedly Between Physical Cylinders, O[StartPhyCyl0],[StartPhyCyl1],[NumSkPairs],[NumSeconds],[Hd]
Level 2 'P': Rev 0011.0000, Overlay, Set Buffer Pattern, P[PatternSelOrPatternLow],[PatternHi],[PatternBits],[Opts],[BlkNum],[NumBlks]
Level 2 'Q': Rev 0011.0000, Overlay, Write, Read, Read CHS, Q[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 2 'R': Rev 0011.0000, Overlay, Read CHS, R[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 2 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 2 'T': Rev 0013.0000, Overlay, Measure Throughput, T[Opts],[CylSkew],[HeadSkew],[MiniZoneSkew],[SkewStep],[LengthInTracks],[OffsetInTracks],[NumberOfRetries]
Level 2 'V': Rev 0011.0000, Overlay, Read Verify CHS, V[Sec],[NumSecs],[CompareBlk],[Opts]
Level 2 'W': Rev 0011.0000, Overlay, Write CHS, W[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 2 'X': Rev 0011.0000, Overlay, Display Track Information, X[LogCyl],[Hd],[SysAreaOpt],[Opts],[RowsPerPage]
Level 2 'Y': Rev 0011.0000, Overlay, Set Retries - DERP, Y[Mode],[MaxRdRetries],[MaxWrtRetries],[OtcTLevel],[Options]
Level 2 'a': Rev 0001.0000, Overlay, Measure Optimum Skew, a
Level 2 'c': Rev 0011.0000, Overlay, Buffer Compare, c[SrcBlk],[RefBlk],[NumBlks],[ContOnErr]
Level 2 'h': Rev 0011.0000, Overlay, Translate Physical Sector, h[Sec],[NumSecs]
Level 2 'i': Rev 0011.0000, Overlay, Display Defects On Current Track, i
Level 2 'j': Rev 0011.0000, Overlay, Read Wedge, j[WedgeAddr],[NumWedges],[NumSkipedWedges],[TranSize],[Opts],[RegAddr0],...,[RegAddr13]
Level 2 'k': Rev 0001.0000, Overlay, Set User Cylinder/Head/MiniZone Skew, k[CylSkew],[HeadSkew],[MiniZoneSkew]
Level 2 'l': Rev 0011.0000, Overlay, Translate Logical Sector, l[Sec],[NumSecs]
Level 2 'o': Rev 0001.0000, Overlay, Corrupt LBA, o[Lba],[NumBlocks],[BurstSpan],[BurstOffset],[NumberOfRandomCorrupt],[Flags]
Level 2 'r': Rev 0011.0000, Overlay, Read Long CHS or Read System CHS, r[LongSec],[LongSecsOrSysSec],[SysSecs],[LongPhySecOpt],[LongOpts],[SysOpts]
Level 2 's': Rev 0011.0000, Overlay, Seek to Physical Cylinder and Head, s[Cyl],[Hd],[ValidKey],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 2 't': Rev 0011.0000, Overlay, Translate Wedge, t[Wdg],[NumWdgs]
Level 2 'u': Rev 0011.0000, Overlay, Enable/Disable Channel/Preamp Register Display, u[EnableDisableOpt]
Level 2 'v': Rev 0011.0000, Overlay, Convert Data Track Percentage To Servo Offset Count, v[Percentage]
Level 2 'w': Rev 0011.0000, Overlay, Write Long CHS or Write System CHS, w[LongSec],[LongSecsOrSysSec],[SysSecs],[LongPhySecOpt],,[SysOpts]
Level 2 'x': Rev 0013.0000, Overlay, Display Zone Information, x[Partition],[Hd],[Zone],[Options]
Level 2 'y': Rev 0011.0000, Overlay, Set DERP Retry State, y[Type],[PathState],[RetryStateCnt],[LoopCnt1],[LoopCnt2]
Level 2 'z': Rev 0011.0001, Overlay, Write Wedge, z[WedgeAddr],[NumWedges],[NumSkipedWedges],[TranSize],[Opt],[RegAddr0],...,[RegAddr13],[TSpacing]
Level 2 '7': Rev 0011.0000, Overlay, Write Verify CHS, 7[Sec],[NumSecs],[WrBufBlk],[Opts]
Level 3 'U': Rev 0011.0000, Flash,   Spin Up Drive, U[HoldState],[Hd],[Cyl]
Level 3 'V': Rev 0011.0000, Flash,   Read or Write Power ASIC Register, V[RegAddr],[RegValue],[WrOpt]
Level 3 'Z': Rev 0011.0000, Flash,   Spin Down Drive, Z
Level 3 'D': Rev 0011.0000, Overlay, Measure Seek Access Time, D[SkLength],[SkType],[NumSks]
Level 3 'E': Rev 0012.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level 3 'H': Rev 0011.0000, Overlay, Select Logical Head, H[Hd],[SkType],[Options]
Level 3 'O': Rev 0011.0000, Overlay, Seek Repeatedly Between Physical Cylinders, O[StartPhyCyl0],[StartPhyCyl1],[NumSkPairs],[NumSeconds],[Hd]
Level 3 'Q': Rev 0011.0000, Overlay, Write, Read, Write, Read CHS, Q[Sec],[NumSecs],[Opts]
Level 3 'R': Rev 0011.0000, Overlay, Read Current Servo Destination, R
Level 3 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 3 'c': Rev 0001.0000, Overlay, Measure Latch Force, c[NumberOfSamples]
Level 3 'f': Rev 0013.0000, Overlay, Real Time Servo Trace, f[SubCmd],[SubPrm0],[SubPrm1],[SubPrm2]
Level 3 'p': Rev 0011.0000, Overlay, Translate Physical Sector, p[Sec],[NumSecs]
Level 3 'q': Rev 0011.0000, Overlay, Translate Logical Sector, q[Sec],[NumSecs]
Level 3 's': Rev 0011.0000, Overlay, Seek to Physical Cylinder and Head, s[Cyl],[Hd],[ValidKey],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 4 'B': Rev 0011.0000, Overlay, Enable / Disable RVFF, B[NewRvffControlMode]
Level 4 'D': Rev 0011.0000, Overlay, Measure Seek Access Time, D[SkLength],[SkType],[NumSks]
Level 4 'E': Rev 0012.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level 4 'H': Rev 0011.0000, Overlay, Select Logical Head, H[Hd],[SkType],[Options]
Level 4 'K': Rev 0011.0000, Overlay, Set Tracking Offset, K[OffsetValue],[PersOrTempOpt],[UnitsOpt],[ChanReload]
Level 4 'O': Rev 0011.0000, Overlay, Display Micro Jog for Logical Cylinder and Head, O[LogCyl],[Hd],[Opts],[SysAreaOpt]
Level 4 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 4 'U': Rev 0011.0000, Overlay, Servo Batch Test sub commands, U[SubCmd],[SubCmdParm0],[SubCmdParm1],[SubCmdParm2]
Level 4 'c': Rev 0001.0000, Overlay, Find Min Or Max Cylinders c[Head],[Mode],[RangeMultiplier],[RetryCountLimit],[FilterTimeConstant]
Level 4 'd': Rev 0001.0000, Overlay, Display Servo Disc Slip
Level 4 'e': Rev 0011.0000, Overlay, Enable / Disable PES Output, e[PesLeftShiftCnt],[DisablePesOut]
Level 4 'g': Rev 0001.0000, Overlay, Display Servo Sector Error Log, g
Level 4 'k': Rev 0001.0000, Overlay, Get VGA Data, k[OpType],[StartHt],[EndHt],[HtInc]
Level 4 'l': Rev 0011.0000, Overlay, Scan Track for Servo Defects and ZAP, l[RdPositionOpt]
Level 4 'q': Rev 0001.0000, Overlay, Display Servo Event Log, q
Level 4 's': Rev 0001.0000, Overlay, Display Servo Sector Error Count, s
Level 4 't': Rev 0011.0000, Overlay, Display / Modify ZAP Table, t[EntryNum],[EntryValue]
Level 4 'u': Rev 0011.0000, Overlay, Set Seek Speed, u[Opts],[SkSpeed]
Level 4 'v': Rev 0011.0000, Overlay, Butterfly Seek Test, v[StartPhyCyl0],[StartPhyCyl1],[NumSkPairs],[NumSeconds],[Hd]
Level 5 'S': Rev 0011.0000, Flash,   Enter Servo Matlab Shell, S
Level 5 'B': Rev 0011.0000, Overlay, Servo Bode Plot, B[BodeType],[InjAmp],[Fmin],[Fmax],[NumFreq],[NumSamples],[EnableTracing]
Level 5 'C': Rev 0011.0000, Overlay, Generic Servo Command, C[CmdNum],[Parm1],...[Parm7]
Level 5 'D': Rev 0011.0000, Overlay, Read / Unlock DDR Buffer, B[OperateCode]
Level 5 'E': Rev 0001.0000, Overlay, Measure Disc Eccentricity
Level 5 'G': Rev 0011.0000, Overlay, Select Servo Controller, G[Head],[Controller],[InputShift]
Level 5 'K': Rev 0001.0000, Overlay, Servo Disc Slip, K [OperationSelectId]
Level 5 'R': Rev 0011.0000, Overlay, Read Servo RAM at Address, R[Addr],[NumBytes]
Level 5 'U': Rev 0011.0000, Overlay, Enable / Disable Servo Updates, U[VcmDacUpdateOpt],[AToDUdateOpt]
Level 5 'W': Rev 0011.0000, Overlay, Write Servo RAM at Address, W[Addr],[NumBytes],[Data]
Level 5 'Z': Rev 0011.0000, Overlay, Read Zap from Disc to Table, Z
Level 5 'd': Rev 0011.0000, Overlay, Disable / Enable Servo ZAP coefficients and ZAP read, d[ZapControlMode]
Level 5 'e': Rev 0001.0000, Overlay, Enable / Disable Shock Sensor, e[Operation]
Level 5 'i': Rev 0011.0000, Overlay, Read Servo Symbol Table at Index, i[Index]
Level 5 'r': Rev 0011.0000, Overlay, Read Servo RAM at Index, r[Index],[NumBytes],[ByteOffset]
Level 5 'w': Rev 0011.0000, Overlay, Write Servo RAM at Index, w[Index],[NumBytes],[Data],[ByteOffset]
Level 6 'B': Rev 0011.0000, Overlay, Run Batch File, B[BatchFileNum],[DisplayOpt]
Level 6 'D': Rev 0011.0000, Overlay, Display Batch File, D[BatchFileNum]
Level 6 'E': Rev 0011.0000, Overlay, Enter Batch File, E[BatchFileNum]
Level 7 'Z': Rev 0011.0000, Flash,   Spin Down Drive, Z
Level 7 's': Rev 0011.0000, Flash,   Write Peripheral Register - channel or preamp, s[OpType],[RegAddr],[RegValue],[RegMask],[RegPagAddr]
Level 7 't': Rev 0011.0000, Flash,   Write Peripheral Register - channel or preamp, t[OpType],[RegAddr],[NumRegs],[RegMask],[RegPagAddr]
Level 7 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits]
Level 7 'C': Rev 0011.0000, Overlay, Buffer Copy, C[SrcBlk],[DestBlk],[NumBlks]
Level 7 'D': Rev 0012.0000, Overlay, Display Temperature, D,[DevSelect]
Level 7 'E': Rev 0012.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level 7 'H': Rev 0011.0000, Overlay, Select Logical Head, H[Hd],[SkType],[Options]
Level 7 'I': Rev 0011.0003, Overlay, Display / Modify Adaptive Parameter, I,[GroupId]
Level 7 'K': Rev 0011.0000, Overlay, Set Track Format, K[UserAreaTrkFormatType],[SysAreaTrkFormatType]
Level 7 'P': Rev 0011.0000, Overlay, Set Buffer Pattern, P[PatternSelOrPatternLow],[PatternHi],[PatternBits],[Opts],[BlkNum],[NumBlks]
Level 7 'Q': Rev 0011.0000, Overlay, Write, Read, Read CHS, Q[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 7 'R': Rev 0011.0000, Overlay, Read CHS, R[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 7 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 7 'U': Rev 0011.0001, Overlay, Channel Temperature Adjust, U[TweakTemperature],[Partition],[Hd],[Zone],[Opts]
Level 7 'W': Rev 0011.0000, Overlay, Write CHS, W[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 7 'X': Rev 0011.0000, Overlay, Display Preamp Head Resistance
Level 7 'Y': Rev 0011.0000, Overlay, Set Retries - DERP, Y[Mode],[MaxRdRetries],[MaxWrtRetries],[OtcTLevel],[Options]
Level 7 'b': Rev 0011.0000, Overlay, Erase Track, b[AdjacentTrkCnt],[EraseCntPerTrk],[AcEraseOpt]
Level 7 'c': Rev 0011.0000, Overlay, Off Track Capability, c[Sec],[NumSecs],[SecIncrement],[Offset]
Level 7 'h': Rev 0011.0001, Overlay, Mark Media Flaw, h[PhyCyl],[Hd],[PhySec],[UndisturbedRadius],[EraseBandTrks],[PtrLen],[WgSpec],[Od/Id]
Level 7 'i': Rev 0011.0000, Overlay, Generic Read/Write Request, i[Parm0],[Parm1],[Parm2],...[Parm9]
Level 7 'm': Rev 8003.0000, Overlay, Display Single Track Directed Offline Scan Information, m[clr,min scn]
Level 7 'r': Rev 0011.0000, Overlay, Read Non-Volatile Adaptive Parameters, r[Opts]
Level 7 'u': Rev 0011.0000, Overlay, Enable/Disable Write Fault, u[Op]
Level 7 'w': Rev 0011.0000, Overlay, Save Adaptives To Flash, w[Seg],,22
Level 7 'x': Rev 0013.0000, Overlay, Display Zone Information, x[Partition],[Hd],[Zone],[Options]
Level 7 'y': Rev 0011.0000, Overlay, Set DERP Retry State, y[Type],[PathState],[RetryStateCnt],[LoopCnt1],[LoopCnt2]
Level 8 'U': Rev 0011.0000, Flash,   Spin Up Drive, U[HoldState],[Hd],[Cyl]
Level 8 'Z': Rev 0011.0000, Flash,   Spin Down Drive, Z
Level 8 'C': Rev 0011.0000, Overlay, Servo Diag Sub Cmds, C[SubCmd],[Parm0],[Parm1],[Parm2]
Level 8 'R': Rev 0011.0000, Overlay, Read Current Servo Destination, R
Level 8 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 8 'd': Rev 0001.0000, Overlay, Head Smash Test, d[HeadDirection],[AccelerationDuration],[DecelerationDuration],[AccelerationCurrent],[DecelerationCurrent]
Level A 'C': Rev 0011.0000, Overlay, Translate PBA, C[PbaHi],[PbaLow],[NumPbas]
Level A 'D': Rev 0011.0000, Overlay, Translate Symbols From Index, D[PhyCyl],[Hd],[Sfi],[NumSfis]
Level A 'E': Rev 0012.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level A 'F': Rev 0011.0000, Overlay, Translate LBA, F[LbaHi],[LbaLo],[SysAreaOpt],[NumLbas]
Level A 'M': Rev 0011.0000, Overlay, Set Controller Test Port, M[Port],[Value]
Level A 'P': Rev 0012.0000, Overlay, Merge Alt List into Slip List, P
Level A 'Q': Rev 0011.0000, Overlay, Write, Read, Read LBA, Q[Lba],[NumLbas],[Opts]
Level A 'R': Rev 0011.0000, Overlay, Read LBA, R[Lba],[NumLbas],,[Opts]
Level A 'S': Rev 0011.0000, Overlay, Seek to LBA, S[LbaHi],[LbaLo],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level A 'W': Rev 0011.0000, Overlay, Write LBA, W[Lba],[NumLbas],,[Opts]
Level A 'Y': Rev 0011.0000, Overlay, Set Retries - DERP, Y[Mode],[MaxRdRetries],[MaxWrtRetries],[OtcTLevel],[Options]
Level A 'c': Rev 0011.0000, Overlay, Translate Logical Cylinder, Logical Head and Logical Sector, c[Cyl],[Hd],[Sec],[SysAreaOpt],[NumSecs]
Level A 'd': Rev 0011.0000, Overlay, Translate Physical Cylinder, Logical Head and Physical Sector, d[Cyl],[Hd],[Sec],[NumSecs]
Level A 'e': Rev 0011.0000, Overlay, Translate Nominal Cylinder and Logical Head, e[Cyl],[Hd],[Sec],[SysAreaOpt]
Level A 'f': Rev 0011.0000, Overlay, Translate Physical Cylinder, Logical Head and Physical Wedge, f[Cyl],[Hd],[Wdg],[NumWdgs]
Level A 'l': Rev 0011.0000, Overlay, Display Track Information, l[LogCyl],[Hd],[SysAreaOpt],[Opts],[RowsPerPage]
Level A 'y': Rev 0011.0000, Overlay, Set DERP Retry State, y[Type],[PathState],[RetryStateCnt],[LoopCnt1],[LoopCnt2]
Level C 'Q': Rev 0001.0000, Overlay, Display ASCII Command Information, Q[CmdLevel],[Cmd]
Level C 'T': Rev 0011.0000, Overlay, Goop Plot, T[Hd],[StartTrk],[EndTrk],[ECCLvl],[NoFrcSync],[SkipCnt]
Level E 'B': Rev 0011.0001, Overlay, Write Wedge, B[WedgeAddr],[NumWedges],[NumSkipedWedges],[TranSize],[Opt],[RegAddr0],...,[RegAddr13],[TSpacing]
Level E 'C': Rev 0011.0000, Overlay, Read Wedge, C[WedgeAddr],[NumWedges],[NumSkipedWedges],[TranSize],[Opts],[RegAddr0],...,[RegAddr13]
Level E 'G': Rev 0001.0000, Overlay, HeadDegradation, G[OperationControlOptions],[MeasurementControlOptions]
Level E 'd': Rev 0001.0000, Overlay, SQMS Dibit Optimization, d[OptiAlgorithm],[LATE01 NOMR/F],[SweepStartVal],[SweepEndVal],[IterationCnt],[Verbose]
Level E 'm': Rev 0011.0000, Overlay, Fast MSESER Measurement, m[]
Level E 'n': Rev 0001.0000, Overlay, Dibit Extraction, n[sctr],[cnt],[dibit],[dibit],[dibit],[skip],[trim],[dsply]
Level E 'o': Rev 0011.0000, Overlay, Fine RW Offset Measurement, o[NumAvgs],[TrkStepSize],[NumGuardTrks]
Level E 'w': Rev 0011.0001, Overlay, Slow Write CHS, w[Sec],[NumSecs],[ConSec],[Skip],[UnitOfSkip]
Level F 'U': Rev 0011.0000, Flash,   Spin Up Drive, U[HoldState],[Hd],[Cyl]
Level F 'Z': Rev 0011.0000, Flash,   Spin Down Drive, Z
Level F 'b': Rev 0011.0000, Flash,   Set Baud Rate, b[BaudRate],[MsecDelay]
Level F 't': Rev 0011.0000, Flash,   Write Peripheral Register - channel or preamp, t[OpType],[RegAddr],[RegValue],[RegMask],[RegPagAddr]
Level F 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits]
Level F 'C': Rev 0011.0000, Overlay, Buffer Copy, C[SrcBlk],[DestBlk],[NumBlks]
Level F 'D': Rev 0011.0001, Overlay, Memory Block Display, D[AddrHi],[AddrLo],[CompVal],[NumBytes],[Opts],[SizeInBytes]
Level F 'E': Rev 0001.0000, Overlay, Symbol Error Map, E[trk],[hd],[srt sctr],[sctr cnt],[action],[mx err]
Level F 'P': Rev 0011.0000, Overlay, Set Buffer Pattern, P[PatternSelOrPatternLow],[PatternHi],[PatternBits],[Opts],[BlkNum],[NumBlks]
Level F 'V': Rev 0011.0000, Overlay, Buffer Compare, V[SrcBlk],[RefBlk],[NumBlks],[ContOnErr]
Level F 'Y': Rev 0011.0000, Overlay, Set Retries - DERP, Y[Mode],[MaxRdRetries],[MaxWrtRetries],[OtcTLevel],[Options]
Level F 'r': Rev 0011.0000, Overlay, Read System CHS, r[LogSec],[NumSecs],[Opts]
Level F 's': Rev 0011.0000, Overlay, Seek to Physical Cylinder and Head, s[Cyl],[Hd],[ValidKey],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level F 'y': Rev 0011.0000, Overlay, Set DERP Retry State, y[Type],[PathState],[RetryStateCnt],[LoopCnt1],[LoopCnt2]
Level F 'z': Rev 0011.0000, Overlay, SataDebug, z[SubCmd],[Parm1],[Parm2],[Parm3]
Level G 'B': Rev 0011.0000, Overlay, Fill Correction Buffer, B[StartAddr],[EndAddr],[Pattern],[Opts]
Level G 'C': Rev 0011.0000, Overlay, Copy Correction Buffer, C[SrcAddr],[DestAddr],[NumSyms]
Level G 'D': Rev 0011.0000, Overlay, Display Correction Buffer, D[StartAddr],[EndAddr],[CompareData]
Level G 'F': Rev 0011.0000, Overlay, Fill Super Parity RAM, F[StartAddr],[EndAddr],[Pattern]
Level G 'G': Rev 0011.0000, Overlay, Display Super Parity RAM, G[StartAddr],[EndAddr]
Level H 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits]
Level H 'D': Rev 0001.0000, Overlay, Field Adjust Fly Height, c[Flags],[NumCollectionsToAvg],[PctOfBpiLowFreq],[PctOfBpiHighFreq],[PctOfTgtClr],[CTFFR],[ATT2R],[VgaLowFreq],[VgaHighFreq],[StartHtr],[EndHtr],[HtrIncr],[StartPreHtr],[ContactDac],[NumPreHeatSects],[NumPreChanCollectHeatSects],[NumChanCollectHeatSects],[NumPostChanCollectHeatSects],[HscIntgLength],[ChannelPreheatRevs]
Level H 'F': Rev 0002.0002, Overlay, Modulation Detection Contact Detect, F[Flags],[NumRevsToAvg],[PctOfBpi],[HscIntgLength],[PatternSelect],,[CTFFR],[ATT2R],[VGA],[StartHtr],[EndHtr],[HtrIncr],[StartPreHtr],[NumPreHeatSects],[NumPreChanCollectHeatSects],[NumChanCollectHeatSects],[NumPostChanCollectHeatSects],[CoarseSearchStartClr],[FineSearchStartClr],[ContactSearchLimitClr]
Level H 'P': Rev 0011.0000, Overlay, Set Buffer Pattern, P[PatternSelOrPatternLow],[PatternHi],[PatternBits],[Opts],[BlkNum],[NumBlks]
Level H 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level H 'b': Rev 0013.0000, Overlay, Contact Detect, b[Flags],[Revs],[BaselineRevs],[StartWedge],[A],[B],[C],[D],[E],[StartHt],[HtInc],
[FixedPESThresh],[FilterDelta],[RangeStart],[RangePts],[AdjThreshSigmaLimit],[VarContactThreshBackup]
Level H 'c': Rev 0003.0000, Overlay, Calibrate Clearance Coefficients Adjustment, c[Flags],[NumRevsToAvg],[PctOfBpi],[PctOfTgtClr],[LowerHIWPLimit],[UpperHIWPLimit],[CTFFR],[ATT2R],[VGA],[StartHtr],[EndHtr],[HtrIncr],[StartPreHtr],[NumPreHeatSects],[NumPreChanCollectHeatSects],[NumChanCollectHeatSects],[NumPostChanCollectHeatSects],[HscIntgLength]
Level L 'C': Rev 0011.0000, Overlay, Copy Log File, C[SrcLog],[DestLog],[AppendOpt]
Level L 'D': Rev 0012.0000, Overlay, Display Log File, D[Log],[ErrCode]
Level L 'E': Rev 0011.0001, Overlay, Enable / Disable Logging, E[ErrLoggingOpt],[AsciiLoggingOpt],[RwStatsLoggingOpt]
Level L 'I': Rev 0011.0000, Overlay, Display Log FileInfo, I[Log]
Level L 'c': Rev 0011.0000, Overlay, Create Log File, c[Log],[LogType],[BufferOrDiskOpt],[NumBytes]
Level L 'd': Rev 0011.0000, Overlay, Delete Log File, d[Log]
Level L 'i': Rev 0011.0000, Overlay, Initialize Log File, i[Log]
Level M 's': Rev 0001.0000, Overlay, Serial Port Test Results, s[Sub-command],[SptIndex],[ValidKey]
Level T 'B': Rev 0011.0000, Flash,   Set Baud Rate, B[BaudRate],[MsecDelay]
Level T 'm': Rev 0012.0803, Flash,   Format Partition, m[Partition],[FormatOpts],[DefectListOpts],[MaxWrRetryCnt],[MaxRdRetryCnt],[MaxEccTLevel],[MaxCertifyTrkRewrites],[ValidKey],[DataPattern]
Level T 'E': Rev 0012.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level T 'F': Rev 0011.0000, Overlay, Display / Modify Congen, F[ValueRef],[Data],[ResetEnable]
Level T 'J': Rev 0011.0001, Overlay, Display / Modify CAP, J[ParmValue],[ParmId],[ParmArrayBytes],[ParmByteArrayOffset]
Level T 'O': Rev 0001.0000, Overlay, Select Data Output Mode, O[Mode],[VerboseOpts]
Level T 'P': Rev 0011.0000, Overlay, Download Generic File, P[FileBytes]
Level T 'R': Rev 0011.0000, Overlay, Read Non-Volatile Adaptive Parameters, R[Opts]
Level T 'T': Rev 0011.0000, Overlay, Odd Even Encroachment Test, T[strt tk],[end tk],[hd],[rtry thrshld][ECC thrshld
Level T 'V': Rev 0015.0000, Overlay, Display Defect Lists, V[ListMask],[Hd],[StartCyl],[NumCyls],[Summary],[FlagsMask]
Level T 'W': Rev 0011.0000, Overlay, Save Adaptives To Flash, W[Seg],,22
Level T 'i': Rev 0011.0002, Overlay, Initialize Defect List, i[DefectListSelect],[SaveListOpt],[ValidKey]
Level T 'r': Rev 0001.0000, Overlay, Read File, r[FileId],[VolumeNum],[CopyNum],[ByteOffset],[Length],[OutputFmt]
Level T 'w': Rev 0001.0000, Overlay, Write File, w[FileId],[VolumeNum],[CopyNum],[ByteOffset]
Level T '[': Rev 0011.0000, Overlay, ASCII Log Control, [[LogFunction],[Log]
F3 C>
PostPosted: September 5th, 2019, 4:40
Does anyone have any idea/clue/whispered-codeword-advice where I could start investigate the problem? Just a lead...
PostPosted: September 5th, 2019, 16:57
Try the "F" commands in the following thread:
http://www.hddoracle.com/viewtopic.php?f=59&t=1842&start=60
Hopefully they will stabilise the drive enough so that you can clone it.
WARNING: The commands are Case Sensitive.
PostPosted: September 7th, 2019, 8:03
Thank you a lot fzabkar!! I will have a look at it asap.
PostPosted: September 9th, 2019, 17:35
A small success!!
@fzabkar, to you my sincerest thanks for your help.
On the right way! Hard to believe.. my hopes were almost entirely gone.
maximus wrote:
Try cloning/imaging with HDDSuperClone for about 5 minutes or so, stop it and attach the log here.
Sweat and blood went into this :lol:
# Disk progress log file created by HDDSuperClone version 2.1.13_20190804
# 2019-09-09_23.18.42.663669
# command= hddsuperclone
# Logfile: /media/lubuntu/Storage/HddSuper/okk
# 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
#      Source:   /dev/sdb (STM3320418AS, 6VMAFKDM)
# #Destination: /media/lubuntu/Storage/HddSuper/image (, )
#   Total LBA:  625142448        LBA to read:  625142448
#    Run time: 0:00:05:28        Remaining:   0:13:32:23
#        Rate:          0 B/s    Recent: 6525 KB/s  Total: 6137 KB/s
#   Skip size:       4096  Skips: 7  Slow: 6  Runs: 0  Resets: 0  Run size: 0
#    Position:    3969664        Status:    Phase 1
#    Finished:    3931648 (14 areas 0.628920%)
#   Non-tried:  621210672 (8 areas 99.371063%)
# Non-trimmed:        128 (1 areas 0.000020%)
# Non-divided:          0 (0 areas 0.000000%)
# Non-scraped:          0 (0 areas 0.000000%)
#         Bad:          0 (0 areas 0.000000%)
################ START CONFIGURATION DATA ################
# startconfig
# logfile     /media/lubuntu/Storage/HddSuper/okk
# source     /dev/sdb
# destination     /media/lubuntu/Storage/HddSuper/image
# verbose     0x0
# debug     0x0
# forcemounted     0
# forcedangerous     0
# importdd     0
# exportdd     0
# dodomain     0
# domaindd     0
# domainfile     /media/lubuntu/Storage/HddSuper/okk.domain
# repairlog     0
# nologbackup     0
# phaselogs     0
# softtimer     8000000
# hardtimer     800000
# busytimer     20000000
# initbusytimer     8000000
# resettimer     8000000
# generaltimer     60000000
# phasetimers     0
# p12softtimer     250000
# p3softtimer     350000
# p4softtimer     500000
# tdsofttimer     800000
# d2softtimer     800000
# scsofttimer     800000
# rtsofttimer     8000000
# usbbulkreset     1
# usbsoftreset     1
# usbhardreset     1
# usbportreset     1
# imagesource     0
# genericsource     0
# atapass     1
# scsipass     0
# skipfast     0
# skiptimer     1000000
# direct     0
# ahci     0
# usb     0
# resetstatus     0
# nophase1     0
# nophase2     0
# nophase3     0
# nophase4     0
# notrim     0
# nodivide1     0
# dodivide2     0
# notrim     0
# noscrape     0
# markbadhead     0
# readbadhead     1
# clustersize     128
# blocksize     1
# sectorsize     512
# blockoffset     0
# retries     0
# retried     0
# inputoffset     0
# outputoffset     -1
# size     625142448
# rateskip     50000
# exitonslow     -1000
# exitonslowtime     -1000
# minskip     4096
# maxskip     6251424
# reverse    0
# fillmode     0
# fillmark     0
# findserial
# quiet     0
# forcestupid     0
# model     STM3320418AS
# serial     6VMAFKDM
# skipsize     4096
# skips     7
# slowskips     6
# skipruns     0
# skipresets     0
# stoponerror     0
# callcommand     0
# commandtocall
# primaryrelayonerror     0
# callpowercommand     0
# powercommandtocall
# primaryrelaypowercycle     0
# writebufferdisable     0
# writebufferenable     0
# driverreturnerror     0
# driverreturnzeros     0
# driverreturnmarked     0
# driverdiskname     sdv
# driverminclustersize     1
# piomode     0
# enableprocesschunk     0
# enablescsiwrite     0
# sectorsizeadjust     0
# usephysicalsectorsize     0
# colorstatusbar     0
# primerelayactivatetime     3
# primerelaydelaytime     15
# primerelaysettings     0xff00
# endconfig
################ END CONFIGURATION DATA ################
################ START IDENTIFY DEVICE INFO ################
# 0: 5a 0c ff 3f 37 c8 10 00 00 00 00 00 3f 00 00 00 Z..?7.......?...
# 10: 00 00 00 00 20 20 20 20 20 20 20 20 20 20 20 20 ....
# 20: 56 36 41 4d 4b 46 4d 44 00 00 00 80 04 00 43 43 V6AMKFMD......CC
# 30: 38 33 20 20 20 20 54 53 33 4d 32 33 34 30 38 31 83    TS3M234081
# 40: 53 41 20 20 20 20 20 20 20 20 20 20 20 20 20 20 SA
# 50: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 10 80               ..
# 60: 00 00 00 2f 00 40 00 02 00 02 07 00 ff 3f 10 00 .../.@.......?..
# 70: 3f 00 10 fc fb 00 10 01 ff ff ff 0f 00 00 07 00 ?...............
# 80: 03 00 78 00 78 00 78 00 78 00 00 00 00 00 00 00 ..x.x.x.x.......
# 90: 00 00 00 00 00 00 1f 00 06 05 00 00 48 00 40 00 ............H.@.
# a0: f0 01 29 00 6b 34 01 7f 63 41 29 34 01 be 63 41 ..).k4..cA)4..cA
# b0: 7f 40 1f 00 1f 00 00 00 fe ff 00 00 00 fe 00 00 .@..............
# c0: 00 00 00 00 00 00 00 00 b0 ea 42 25 00 00 00 00 ..........B%....
# d0: 00 00 00 00 00 00 00 00 00 50 00 c5 17 1f fc 19 .........P......
# e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1e 40 ...............@
# f0: 1c 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .@..............
# 100: 29 00 b0 ea 42 25 b0 ea 42 25 20 20 02 00 40 01 )...B%..B%  ..@.
# 110: 00 01 00 50 06 3c 0a 3c 00 00 3c 00 00 00 08 00 ...P.<.<..<.....
# 120: 00 00 00 00 4f 00 80 02 00 00 00 00 08 00 00 00 ....O...........
# 130: 00 00 00 00 00 00 00 00 00 00 00 00 00 3f 00 98 .............?..
# 140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 190: 00 00 00 00 00 00 00 00 00 00 00 00 3f 10 00 00 ............?...
# 1a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 1b0: 00 00 20 1c 00 00 00 00 00 00 00 00 10 10 00 00 .. .............
# 1c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 1d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 1e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 1f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 a5 1e ................
# lba supported = yes
# 48 bit supported = yes
# smart supported = yes
# smart enabled = yes
# security locked = no
################ END IDENTIFY DEVICE INFO ################
# current position         status
0x3c9280               0x0
# position    size        status    info    err/status/time
0x000000    0x005880    0x7f    0x0    0x0
0x005880    0x000080    0x7f    0x80    0x5002
0x005900    0x001000    0x0    0x0    0x0
0x006900    0x00a880    0x7f    0x0    0x0
0x011180    0x000080    0x7f    0x80    0x5001
0x011200    0x001000    0x0    0x0    0x0
0x012200    0x043980    0x7f    0x0    0x0
0x055b80    0x000080    0x10    0x80    0x3110405
0x055c00    0x001000    0x0    0x0    0x0
0x056c00    0x235a80    0x7f    0x0    0x0
0x28c680    0x000080    0x7f    0x80    0x5003
0x28c700    0x001000    0x0    0x0    0x0
0x28d700    0x003080    0x7f    0x0    0x0
0x290780    0x000080    0x7f    0x80    0x5001
0x290800    0x001000    0x0    0x0    0x0
0x291800    0x000800    0x7f    0x0    0x0
0x292000    0x000080    0x7f    0x81    0x5001
0x292080    0x001c01    0x0    0x0    0x0
0x293c81    0x000400    0x7f    0x0    0x0
0x294081    0x000080    0x7f    0x82    0x5001
0x294101    0x0027ff    0x0    0x0    0x0
0x296900    0x132980    0x7f    0x0    0x0
0x3c9280    0x25065830    0x0    0x0    0x0
PostPosted: September 9th, 2019, 19:26
Initial analysis is that it does not show a dead or totally weak head. But it may be reading a bit slow, maybe in one head. There is good recovery potential, as long as any physical damage does not get worse. It could die at any time, or it could be a very productive recovery.
http://www.sdcomputingservice.com
Home of HDDSuperClone and HDDSuperTool
PostPosted: September 9th, 2019, 19:48
Assuming you continue with the imaging process, you can provide a log after awhile and I will be happy to give an update based on it.
PostPosted: September 10th, 2019, 3:08
Thank you so much!!
Happy to hear the situation does not seem that dire. Hopefully I will be able to access it again..
I will then try to clone some more. The drive is partially full, say half. Also fragmentation should be reasonably low as I did it not so long previous the failure with little changes (using mostly to browse internet and working on a few docs and pics). Hopefully important data will be recovered all first and then the rest will be empty space.
PostPosted: September 11th, 2019, 15:44
Question: Is it best to run cloning software set for one pass/one read each sector rather than multi-read attempts on any problematic sector?
"Take care of thy backups and thy restores shall take care of thee." Ben Franklin revisited
PostPosted: September 11th, 2019, 17:22
I would do 1 read per pass.
PostPosted: September 11th, 2019, 19:43
Always best to never retry any sector/cluster until after all other sectors/clusters have been attempted. Get the readable data first, then go back for the trouble spots. HDDSuperClone does this by default. The drive could die at any time, so spending time rereading sectors before all is attempted is a good way to not recover data.
PostPosted: September 12th, 2019, 3:30
Specialist equipment would help a lot in both diag and recovery, it might also save your data from getting completely ruined by drive and OS retries and wrong algorythms.
Specialist equipment with specialist knowledge i mean...
I would not give any other advice, coz experimenting leads to loss of all chances.
And i consider it a waste of time :(
No bitcoin donations :)
PostPosted: September 19th, 2019, 18:14
I resumed the cloning a couple of times for a total of around 10 h. The recovery seems to be proceeding at a stable pace and it should have gone past most of the meaningful data.
Log should be attached..
okk.rar [4.54 KiB]
Downloaded 229 times
PostPosted: September 19th, 2019, 18:38
Very good results so far. There is a slight pattern to indicate a weak head, but still reading almost all data, it just skips on some slow reads. As long as that head doesn't die and there isn't a bad spot yet to come up, I predict a very good recovery, 99.9999%
PostPosted: September 21st, 2019, 16:59
99.999306% :beer:
I stopped it after making sure the remaining non-scraped sectors would be taking ages to be processed.
I hope those few MBs left do not affect the few files I want to recover.
I plan to mount the image on Linux or Windows, performing a fsck first? Do you think there are chances I can access the data this way? Can I still resume the recovery after fsck or the image will be out of sync with the log file?
okk.rar [9.59 KiB]
Downloaded 209 times
PostPosted: September 21st, 2019, 17:10
I wouldn't use fsck or chkdsk to make any repairs. Instead I would recover your data to a third drive. (You may need to recover more non-scraped sectors, in which case any repairs made by fsck may cause problems.)
As for mounting the image, NTFS volumes have a backup copy of the boot sector at the very end. I don't know how the OS would deal with a missing backup.
Also, if your drive is partitioned as GPT rather than MBR, then there will be a backup copy of the GPT metadata at the end of the drive.
Congratulations, BTW.
PostPosted: September 21st, 2019, 18:15
Thank you!! I feel so much lighter now.
...to a third drive.
Well I could put the image in the spare 7200.10 test I have. What are the advantages of recovering data to a drive vs accessing the image directly (if possible)? I just have to recover a few docs and photos. I would prefer avoiding to tie up my PC for one more full day of recovery.
I think I will make a copy of the image and try to mount it in different ways. Any suggestion for that?
PostPosted: September 21st, 2019, 18:20
I would boot from a Linux Live CD and see if it will mount your FS. I would avoid Windows since it may launch CHKDSK automatically in repair mode.
PostPosted: September 24th, 2019, 15:43
I have successfully gained access to my data and recovered everything :-D
I had some small setbacks at mounting the image but I solved it specifying the partition offset.
In fact those few damaged blocks I gave up recovering I believe are not involved with any of my data but are all system based.
lubuntu@lubuntu:~$ sudo mount -o loop,offset=1048576 /media/lubuntu/Storage/HddSuper/prova/image /media/lubuntu/Storage/HddSuper/prova/mountpoint
Windows is hibernated, refused to mount.
Did not find any restart pages in $LogFile and it was not empty.
The file system wasn't safely closed on Windows. Fixing.
Falling back to read-only mount because the NTFS partition is in an
unsafe state. Please resume and shutdown Windows fully (no hibernation
or fast restarting.)
Could not mount read-write, trying read-only
Read-only was more that enough :wink:
It was April 21; a five month adventure where I learned many things and yet merely scratched the surface of DR. It was enough to have an idea of how complex is a HDD, how much time and effort you need to make a recovery and to build the necessary experience to be a DR person. I completely understand now why their services are so (relatively) expensive. This is what I got for not having backuped my data regularly, and I've been very lucky my HDD was in a still good enough state I could access it with a few commands. It was a good lesson.
A special thank goes to maximus and especially fzabkar who assisted me from the beginning until the end and everyone who took part in this discussion. Thank you guys!
Another thing I learned: stay away form Seagate. And speaking of which, what HDD brand would you guys advice these days?
I think I will try to run a CHKDSK with Windows and see if it is able to make the image bootable again, although I do not hold out much hope for it, and I will likely try to regenerate the HDD and use it for unimportant stuff; so I might post again for advice.
Users browsing this forum: No registered users and 31 guests
