Post new topic Reply to topic  [ 86 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: Old Maxtor recovery - I/O error
PostPosted: September 24th, 2019, 16:25
Backblaze provides its hard drive reliability statistics on a quarterly basis:
https://www.backblaze.com/blog/hard-drive-stats-q2-2019/
HGST has been the most reliable, but Toshiba appears to be challenging for the top spot.
PostPosted: October 22nd, 2019, 12:46
All 3 appear to be 3.3V TTL-serial converters. Take your pick, but make sure you get an additional cable for the first two.
Just a question. I bought some adapters and connectors to try but all the connectors were far too large to connect to the serial pins in Seagate and a Maxtor drives. I was able to do a loopback test on the USB-TTL devices on PuTTY and RealTerm, but likely to bend or destroy the pins on the drives. Trying to find wires with small enough connectors on the drive end to work. Can you suggest a solution?
PostPosted: October 22nd, 2019, 15:09
Well, I learned an important lesson:
Don't buy Seagate hard drives.
Is there a good preferred brand among you guys?
PostPosted: October 22nd, 2019, 18:06
Remove the connectors from the square plastic, um, insulators (not sure what to call them). They should only be locked on with a tab you can push or pry. You will be left with just the metal and it should fit then, but it helps to put some thin tape on them to prevent shorting.
http://www.sdcomputingservice.com
Home of HDDSuperClone and HDDSuperTool
PostPosted: October 22nd, 2019, 19:33
Thanks, that worked!
PostPosted: November 22nd, 2019, 15:00
..and wrap every single pin with tape. Oops.. said already :lol:
