 Post subject: what could be Exact technical issue in rebuilding rom
PostPosted: June 25th, 2019, 0:41
I am working on a WD Tornado family disk --- WD3200AVJS -63TBA0 PCB rev. PWB - 2060-701444-003 Rev.A ) ,Its original pcb is bricked.
This model has embedded rom within mcu.
I have arranged donor pcb fro same family model , there is slight difference in pcb rev though.
I am following procedure as per acelab video.When powered from donor pcb it clicks and spins down.
After loading permanant overlay disk get initiated from rom & shows ROM model, firmware ,capacity (partial) etc.
When I proceed for next step I could get SA SPT as well , but when tried to load dir in ram , disk gives errors and I could not proceed further.I cant read modules in SA as well , in short I get errors like LBA 0 translation error etc.
What to blame now -- difference in pcb rev / non compatible loader / weak heads , SA defects or anything else.
 Post subject: Re: what could be Exact technical issue in rebuilding rom
PostPosted: June 25th, 2019, 2:07
Wrong DIR address in mod 0B of donor ROM.
Try to read tracks and find modules 01, 02 , 11, 1B ...
PostPosted: June 25th, 2019, 21:09
Thanks BGman ,
Unfortunately now disk is not coming to DRD DSC but busy & SATA II (phy) led are flashing. What this could mean.
PostPosted: June 26th, 2019, 2:41
It means that you have done something wrong.
If the data is important to you, send the drive to a DR company. If not, just trash it.
PostPosted: June 29th, 2019, 14:58
posidon wrote:
Thanks BGman ,
That is mean you killed donor PCB trying to write improper version of rom . Get another one , or better, couple of them.
Angel Data Recovery
PostPosted: June 29th, 2019, 19:04
DR-Kiev wrote:
posidon wrote:
Thanks BGman ,
Not needed ....
You should be able to write new ROM by boot code mode even with bricked PCB due to wrong ROM code ... At least on the majority of models you should be able to do this ... Usre PC-3000 to connect to the drive by terminal and use boot code option on PC-3000 to read/write ROM by terminal ....
PostPosted: July 1st, 2019, 3:31
Thanks a ton Spildit
I did exactly what you said and fortunately could recover all data. Your post came just in time when I was about to give up the case. :D :good:
PostPosted: July 1st, 2019, 10:37
Give up the case just because of an incorrect ROM version!!! If you are a data recovery engineer you will get a lot tougher cases than this one.
PostPosted: July 1st, 2019, 13:32
congratulations SPILDIT and POSIDON
PostPosted: July 1st, 2019, 13:49
:shock: :shock: :shock:
Users browsing this forum: Google Adsense [Bot], MSN [Bot] and 9 guests
