 Post subject: donor for seagate st1000lm035
PostPosted: June 26th, 2019, 13:24
hi guys, I have to replace the heads on the hard disk mentioned in the subject but I can't find donors with wbz serial, someone based on his experience knows if other serials can be compatible? below the data on the label: Serial wbz0btcy model st1000lm035 fw sbm3 site wu Sun 20 Nov. 2016 thanks to all
 Post subject: Re: donor for seagate st1000lm035
PostPosted: June 26th, 2019, 14:27
I Will Suggest Once You Tell Me ,
Have You Ever Done This Before ?
PostPosted: June 26th, 2019, 14:34
You can match just the second and third in the SN# and that should match. All other parameters should be the same (or very close).
PostPosted: June 27th, 2019, 2:34
you can use same ST1000LM035 heads. no need to match. only check 2 or 4 heads. if you have 4 heads you should get ST2000LM hard drive.
PostPosted: June 27th, 2019, 4:19
oh yes friend, i'm not beginner ;)
PostPosted: June 27th, 2019, 4:21
In my experience with seagate it's first time can I read this, are you sure ?
PostPosted: June 27th, 2019, 8:43
not all seagate. i told about st1000lm035. also no need head adaptives
PostPosted: June 27th, 2019, 10:33
so a set of heads of an identical model even if with different serial initials it works?
PostPosted: June 27th, 2019, 11:14
if only a head problem, it works fine. also i have checked st4000lm024.
also no need adaptives. st1000lm035 heads are bit harder than st4000lm024.
st4000lm024 is very fragile.
this will help to others. bec. st4000lm024 is expensive hard.
PostPosted: June 27th, 2019, 11:52
it was just a problem with the heads, normally I always chose the donors with the second and third letters of the serial, that's why it seemed strange to me. If you tell me that a disk with a serial is any good enough that it has the same model then you have solved a serious problem for me. Thank You very much
PostPosted: June 27th, 2019, 12:02
It is not.
PostPosted: June 27th, 2019, 12:22
this base only my experiment and experiance. if you have any doubt, wait and see other ideas.
first you should chk. how many heads are there. if it has 4 heads you can't easily find 1tb donor. you should get 2tb.
can u upload the pictures of paitent and donor.
sometime i feel your drive has 4 heads.
PostPosted: June 27th, 2019, 12:47
Last week I started to try to make sense of why some heads would work enough to read, but not write to SA and figured I'd make a log of my findings on my forum (https://www.recoveryforce.com/forums/vi ... f=12&t=537) as I encounter them. Feel free to contribute any concrete findings you have in that thread.
RAID Data Recovery
PostPosted: June 27th, 2019, 13:46
of course, thanks bro
PostPosted: June 28th, 2019, 3:04
hi friend Icoughey
i appriciate you great info on your forum. but sometime we can 100% judge about st1000lm hard drive.
according to your forum wbz has 2 heads. but i can show you wbz 3 heads hard drive.(physically 4).
this is 1tb hard drive(patient) i got 2 tb wdz hard for heads.
@magnet.
other set is successful head swapped case. deferant s/n
PostPosted: June 28th, 2019, 6:38
Can you read the specific family number for the 3 head model and the 4 head model? I have only recorded what I have found and verified, in the past week or two.
RAID Data Recovery
PostPosted: June 28th, 2019, 8:55
on monday i will check it for sure.
PostPosted: July 1st, 2019, 13:06
Rosewood A5
PostPosted: July 16th, 2019, 9:11
Dananjaya wrote:
Rosewood A5
Thanks, documented.
RAID Data Recovery
PostPosted: July 16th, 2019, 13:18
You Just Open The Drive ,Check No of Platters ,Its Its 1 Then Ue any St1000lm035 DRive ,If You Have Two Platters And Three Active Heads ,Use a 2 TB Model ,You Do Not Ned To Do Anything Else .If You even Have a Issue That Heads Are Not Able To Write ,Just Swap again To a Different One ,thats All .
Users browsing this forum: Majestic-12 [Bot] and 18 guests
cron
