 Post subject: over powerd my board, help a numpty out
PostPosted: November 12th, 2018, 19:37
Hey guys
So I wired up a China HDD docking station with the incorrect voltage.. wahoooo
can you guys please see attached and give me a direction on where to test the pcb and how to dodgey it up
I go alright with a soldering iron and a multi meter
Thanks smart people
 Post subject: Re: over powerd my board, help a numpty out
PostPosted: November 12th, 2018, 19:48
Most likely it's better to just replace the PCB with a known good one moving the ROM chip from the bad PCB to the donor compatible PCB.
And pray for the pre-amp to be ok ...
And DO NOT DAMAGE THE ROM CHIP otherwise it's bye-bye data for good ...
PostPosted: November 12th, 2018, 20:11
ooooo sounds riveting
So even if I get a donor pcb I still have to move a chip? which chip is the rom chip?
cheers budd
PostPosted: November 12th, 2018, 21:30
The photo identifies the "BIOS" IC (aka "ROM").
https://www.hdd-parts.com/13022903.html
https://sep.yimg.com/ay/yhst-14437584971410/91711095-6.gif
Measure the voltages at the +5V and +5V(fused) test points. Also measure the resistances of the circled components.
PostPosted: November 12th, 2018, 22:05
looks like we found a busted fuse
jump it ? can i just solder over the top?
Thanks so much
PostPosted: November 12th, 2018, 22:52
One of the diodes is shorted. You'll have to remove the TVS diode (the other would a Schottky rectifier). Can you tell us the part markings on each diode? I can see an "R" but nothing else.
Edit: I see that the other is an "A1".
PostPosted: November 12th, 2018, 22:55
r and a1
PostPosted: November 12th, 2018, 22:58
RSA5M, Rohm, TVS diode, 200W, 5V, marking A1:
http://www.rohm.com/web/global/datasheet/RSA5M
http://www.1688eric.com/upload/pdf/2012 ... RSA5MG.pdf
Try removing A1. If the short goes away, then replace the fuse (or bridge it if you feel lucky).
I would test the PCB off the drive. Measure the voltages (V1 - 3) at each of the two inductors (near the TLS2601 motor controller, and the transistor.
PostPosted: November 12th, 2018, 23:06
Sir
You are my hero, ill let you know how it goes
PostPosted: November 13th, 2018, 19:15
It might be "safer" to replace the entire PCB assuming you can move the ROM without damaging it ....
If you damaged the ROM chip is game over.
PostPosted: November 13th, 2018, 21:17
:D cool!
PostPosted: October 12th, 2019, 18:18
Hello! If I have do have the donor PCB and move the BIOS ROM from the damaged one to the donor PCB, do I need any kind of special software or tools to make it work? or will it just work like that? like just connect it the my PC start the data backup?
Greetings!
Users browsing this forum: MSN [Bot] and 29 guests
