 Post subject: Looking for particular ROM version for WD3200BEVT-11A03T0
PostPosted: August 4th, 2019, 5:13
I am trying to access the data on a WD3200BEVT-11A03T0 (PCB 701609) with failed PCB. I have a donor working 701609 PCB from the same model drive, but the donor has a different ROM version, and I can't find a ROM that is compatible with the patient drive to get it to initialise properly. It has an embedded ROM, no external chip.
Using the donor PCB/ROM, I can get the drive to a ready state and read all firmware, but the drive shows as 0lba. The modules on the platters which usually contain the ROM modules are all Not Init, so I can't rebuild rom from firmware on the platters.
According to Module 11 the firmware version is 5002B. Does anyone have a ROM version 5002B from a WD3200BEVT-11A03T0 they'd be kind enough to share?
I've searched but I can't find any way to rebuild the ROM.
 Post subject: Re: Looking for particular ROM version for WD3200BEVT-11A03T
PostPosted: August 26th, 2019, 7:05
Banned User
acelab have a post on rebuild rom.
Users browsing this forum: Google [Bot], gps31, Kum Ruzvelt and 32 guests
cron
