 Post subject: WD20NMVW-11EDZS7 need help, outsource? MRT remotely?
PostPosted: August 10th, 2019, 10:29
I have this HDD:
WD20NMVW-11EDZS7
It was clicking, so I replaced the heads successfuly. Thing is I do not have software tools yet (MRT on its way).
I was able to access the drive after replacing the heads, with DMDE, and retrieve some data. At one point it became very slow and now it only sees the drive but it has a really sloooooow response.
Seems to be a firmware issue, but as I said before, I cannot go any further without tools.
It is USB 3.0, I don't have a compatible SATA board (if needed, which one?)
Before you ask: yes, heads were replaced in a vertical laminar flow bench safely. I have done it a ton of times. Everytime I had a firmware issue I tried to outsource it or ask for help.
Will anybody help with this? Even maybe remotely if I had MRT?
Many thanks in advance.
 Post subject: Re: WD20NMVW-11EDZS7 need help, outsource? MRT remotely?
PostPosted: August 10th, 2019, 11:59
Sata connection best for recover that drive. MRT working some usb WD drives over usb connection like connected over Sata. Not all models.
My suggestion that you should fix slow response with tool first. And there could be some bad sectors or weak head . Need to head map to get data from good head and parts first . Than other parts. But for safety as you know necessary a tool. So you can understand what is going on .
What is patient USB PCB number?
2060 771961 usb 》》771959 and 1960 Sata (both working)
2060 771801 usb 》》771823 Sata
A Recovery Service In Turkey . Veri Kurtarma Türkiye https://www.digitalverikurtarma.com
Donor Drives hdddonormarket.com
PostPosted: August 10th, 2019, 12:07
Thank you for your reply. This is the PCB number:
2060-771961-001 REV B
PostPosted: August 11th, 2019, 12:36
speakerbox wrote:
I have this HDD:
WD20NMVW-11EDZS7
Hi ,
We in India Can Do This For USD 204/- ODD Dollars ,If you had MRT i can remote in and try solve the issue .If you want you send me some bucks fine , if not no tension ,Your call
PostPosted: August 26th, 2019, 7:04
Banned User
the problem is without firmware tool :shock:
PostPosted: September 4th, 2019, 3:21
I already have MRT now, cheers!
PostPosted: September 4th, 2019, 3:22
Case sorted by @pcimage
Will be working now with him from now on
He has the best communication response I have ever seen IN MY WHOLE LIFE
PostPosted: September 4th, 2019, 4:06
You are in good hands with sean :D
PostPosted: September 4th, 2019, 4:10
pcimage is pure gold in every aspect.
WD Trusted Partners
PostPosted: September 4th, 2019, 5:03
Cheers guys! :-)
PostPosted: September 4th, 2019, 5:32
good choice ... you will not be disappointed...
Data Recovery Pakistan
PostPosted: September 4th, 2019, 6:38
+1 Wise choice, you will not regret it.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: September 5th, 2019, 17:01
pcimage rocks!!!
http://www.datasaversllc.com
PostPosted: September 7th, 2019, 12:04
Hi ,
I am of the opinion that there is always a scope of improvement in a individual ,I would like to know what you liked about the communication and did you communicate with other people here too ,What was the difference , Might be we all could learn a bit from our senior
Users browsing this forum: pepe and 39 guests
