 Post subject: TOSHIBA MQ04UBB400 G-List not clearing
PostPosted: August 29th, 2019, 23:14
Hi
I got a Toshiba MQ04UBB400 with bad PCB, ROM moved to SATA and now the hard drive works fine.
Load Zones : .........................:OK
Cyl Num : ............................:397920
Head Num : ...........................:8
Vendor : .............................:TOSHIBA
Model : ..............................:MQ04ABB400
Microcode : ..........................:JS000U02
Defects in G-List : ..................9584
CP list:33,34,44,56,92,95,98,9A,9C,A2,A5,A7,A8,A9,AA,AD,AE,B1,B3,BB,BF,C1,C5,C6,C7,C8,C9,CB,CD,D0,D1,D3,D4,D6,D7,D9,DA,DB,DC,DD,EF,F1,F3,F4,F7,F8,FA,FB,FC,FF
I tried to clear the G-list i get
Clearing G-List,please wait......
G-List is cleared successfully!
But when I read the G-List again I get the same number or larger sometimes.
is there a way to move the G-List or clear G-List Manually.
 Post subject: Re: TOSHIBA MQ04UBB400 G-List not clearing
PostPosted: August 30th, 2019, 0:15
tried to manually edit the g-list and save changes it gets "saved successfully" but after refreshing the list still the same no changes saved :roll:
PostPosted: August 30th, 2019, 0:26
probably heads can read but nut write
PostPosted: August 30th, 2019, 0:29
Well,
You go ahead with recovery ,This is not going to stop you from doing a recovery ,Why does everyone wanna clear g lists in toshiba ,Do this only if its creating problems not otherwise
PostPosted: August 30th, 2019, 0:54
Amarbir[CDR-Labs] wrote:
Well,
I need the MBR and MFT badly since the customer wants few files out of full 4tb, when I started imaging the drive it started to give me all black sectors after the imaging hit the first one, which marked the beginning of the partition and the MFT as bad sectors
PostPosted: August 30th, 2019, 3:40
LostDataSa wrote:
Hi
Try open with Com connection. Sometimes working .
But I think your case not about clear g list .
A Recovery Service In Turkey . Veri Kurtarma Türkiye https://www.digitalverikurtarma.com
Donor Drives hdddonormarket.com
PostPosted: August 30th, 2019, 5:12
Very high number of defects in Glist, drive is not supported.
Data Recovery Pakistan
PostPosted: September 2nd, 2019, 2:12
You have to patch the DD.bin module (if you know how)....
PostPosted: September 2nd, 2019, 3:22
Can you read the tracks?
PostPosted: September 5th, 2019, 3:10
Do you? :shock: :shock: :shock:
PostPosted: September 5th, 2019, 17:09
Why would you touch the P-List if your intention is to recover the data?
PostPosted: September 6th, 2019, 4:53
The OP has said nothing about data recovery...
You should ask him the same question about the G-List.
PostPosted: September 6th, 2019, 6:29
Wow ,
Brain Antenna Says Post If About Data Recovery Lol . Also i wanted to ask thread starter do all your heads read fine in different area of srive like 25% 50% 75 % and 100% i reverse
PostPosted: September 6th, 2019, 9:20
No. It says conventional hard drives, which means Data Recovery and HDD Repair.
PostPosted: September 7th, 2019, 12:00
Well,
There is a typo above " Wow ,Brain Antenna Says Post If About Data Recovery Lol . Also i wanted to ask thread starter do all your heads read fine in different area of srive like 25% 50% 75 % and 100% i reverse " , I Wanted To Say " Wow , My Brain Antenna Says Post Is About Data Recovery Lol . Also i wanted to ask thread starter do all your heads read fine in different area of Drive like 25% 50% 75 % and 100% in reverse "
Users browsing this forum: Google [Bot] and 27 guests
