 Post subject: About Bitlocker decryption without password/recovery key
PostPosted: February 8th, 2020, 5:22
I came through a blog post https://pulsesecurity.co.nz/articles/TPM-sniffing saying that it's possible to extract a Bitlocker key from a Trusted Platform Module (TPM) and decrypt it.
This needs some electronic knowledge.
@fzabkar: you are THE expert in electronics in this forum (my opinion), could you please confirm if it's true what this security expert is saying?
Did anyone test this method before and could decrypt the Bitlocker key?
Please share your knowledge.
Kind regards
 Post subject: Re: About Bitlocker decryption without password/recovery key
PostPosted: February 10th, 2020, 3:35
No one interested in this topic? :roll: :roll: :roll:
PostPosted: February 10th, 2020, 4:25
Thanks for sharing the link.
Surely I can learn a lot from the post.
PostPosted: February 10th, 2020, 7:27
Kind regards
What is the point of this actions? Getting access to the data from stolen laptops?
Users who are willing to recovery their files in 99% cases provide us with pass/key .
Angel Data Recovery
PostPosted: February 10th, 2020, 8:46
Not necessary. some clients encrypt their hard drives and forget the password and forget to save the recovery key or forget where they put it.
PostPosted: February 10th, 2020, 11:56
Why would anybody need to extract a key from TPM when they have access to TPM?
https://www.linkedin.com/in/artemrubtsov/
PostPosted: February 10th, 2020, 12:01
What if you forget the password and you don't remember where you put your recovery key (I had some clients in this situation), are you able to recover data from that drive?
PostPosted: February 10th, 2020, 12:10
"What if you forget the password and you don't remember where you put your recovery key (I had some clients in this situation), are you able to recover data from that drive?"
Billable hours, correct? Reading other discussion boards, I see a few threads about clients not having at the ready passwords or recovery keys.
"Take care of thy backups and thy restores shall take care of thee." Ben Franklin revisited
Per my understanding TPM holds a key that unlocks Bitlocker
Should be able to unlock Bitlocker, using TPM with a boot CD on the original laptop
PostPosted: February 10th, 2020, 13:09
Doomer, I'm a beginner, what has been your experience with TPM? I never knew that one could use just TPM to unlock BitLocker. I'd like to learn more!
PostPosted: February 10th, 2020, 13:18
There are several types of protectors that can be used with Bitlocker, one of them is TPM only protector, which is old but sometimes can still be found on Bitlocker protected volumes
PostPosted: February 12th, 2020, 3:36
Hi Guys
Pls. refer my post in this regard which is still unanswered unfortunately .
Bitlocker in some cases can be decrypted without key /password in pc3000. I have raised concerns as how AES128 key can be decrypted.
Can someone pls.look at it particularly senior members like Doomer , Dr-Kiev ,fzabkar , pepe to name few.
here is the post -
https://forum.hddguru.com/viewtopic.php ... er#p278195
PostPosted: February 12th, 2020, 11:22
terminator2 wrote:
Hi Guys
here is the post -
Sometimes Bitlocker stores metadata called "clear key". Clear key can decrypt Bitlocker without a password
It has nothing to do with AES "crackability"
PostPosted: February 13th, 2020, 9:42
Thanks Doomer :good: :-D
PostPosted: February 14th, 2020, 2:08
Many Dell Laptops Use Bitlocker and TPM i have recovered a few of these combos in india for my clients and i have also done that magic were key is not required as explained by doomer [ Were key is stored and the app finds it ]
Users browsing this forum: ccc, Google [Bot] and 32 guests
