 Post subject: WD Charger - Resources Request ROM 00050006
PostPosted: March 24th, 2020, 4:17
Hi ,
I had this case of a charger WD ,During my testing i suspect Mod 02 Is either not of the actual patient " Seems Its gone to a DR Company " Who has injected Corona Virus Into It :lol: ,This is The Details Of The Log And The Mod 02 is attached .Does Somone have a donor mod 02 i can try
******************** 3/13/2020 4:41:50 PM ********************
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 384
Zone allocation table................... : Ok
SA SPT.................................. : 1860
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 1024 Kb
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 0
SA regions address...................... : shifted
SA regions address (RAM)................ : by default
Module 02 access........................ : Granted
SA Translator loading................... : Ok
SA defects assigned..................... : 4
ROM Modules:
ROM version............................. : 05.06G
ROM F/W version......................... : 00050006
Overlay F/W version..................... : 05.07G
Servo F/W version....................... : 03.65
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
Service area:
SA dir reading (ID)..................... : Ok
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
PS : This is Ver 6.5 of PC3K In This Machine
02.zip [1.49 KiB]
Downloaded 54 times
 Post subject: Re: WD Charger - Resources Request ROM 00050006
PostPosted: March 24th, 2020, 9:32
that 02 is seriously corrupted, i have seen some with some records inited with default values in the past, but yours have wrong sizes in the dir and the header is corrupted as well. I thing you can use one taken from any charger drive...
It is still odd how those bit errors might have been injected :shock: and only in the dir section.
No bitcoin donations :)
PostPosted: March 24th, 2020, 11:28
Pepe Sir ,
I did also notice that checksum was correct which was wierd ,The Bloody Lockdown Now is Extended To 21 in entire country .When i saw i had the same impression ,Unfortunately I do not have the drive exact model as due to lockdown i am at home for next 21 days ,So this is what i am looking for anyone with 00050006 Rom full resources ,I still have remote access to the office system and i can upload full resources here is anyone needs .Thanks for the reply senior sahib
PostPosted: March 24th, 2020, 11:57
Amarbir[CDR-Labs],
https://yadi.sk/d/_rzFoFqycpOBTg
05.06R
05.06G - no
PostPosted: March 24th, 2020, 18:24
Is there a backup copy of mod 02 in 0x802E or 0x802F ?
PostPosted: March 24th, 2020, 19:04
I see that 0x802E and 0x802F are empty. :-(
Just FYI, I have dumped each of the 52 sections of module 02. There are some nonsensical entries due to a damaged directory (as already stated).
mod2dump_Tomset.7z [3.05 KiB]
Downloaded 50 times
mod2dump_Amarbir.7z [5.68 KiB]
Downloaded 45 times
PostPosted: March 25th, 2020, 4:35
Tomset wrote:
Amarbir[CDR-Labs],
05.06R
05.06G - no
Hello Tomset ,
Sweet of you brother ,This is Ver 0006000R not the one i need ,Might be it works or does not work.
PostPosted: March 25th, 2020, 4:53
Amarbir[CDR-Labs],
Sorry brother.
Something in my head got messed up.
There is no other yet.
PostPosted: March 25th, 2020, 5:43
Hello Frank ,
Are you talking about module 0x802E and 0x802F ,Or a location in Mod 0x02 .If you are talking about mods the mods are empty in my case .
PostPosted: March 25th, 2020, 6:39
Tomset wrote:
Amarbir[CDR-Labs],
Sorry brother.
Hey Tomset ,
Not at all ,You are one of the most helpful guys across ,Any one else who has resources for this rom in charger series
PostPosted: March 25th, 2020, 6:48
i think you could take 02 from any other fw that has 0x34 entries...
PostPosted: March 25th, 2020, 7:53
A little bit:
http://files.hddguru.com/download/PC-30 ... y/Charger/
PostPosted: March 25th, 2020, 11:20
pepe sir ,i could not understand what you meant by 0x34 entries ?
PostPosted: March 25th, 2020, 11:21
Tomset wrote:
Yup ,
But none of them are version i need
PostPosted: March 25th, 2020, 11:24
Friends ,
Have a Peek Here -> https://www.youtube.com/watch?v=1VaPO0vmwg0 .I need To Try This Out when we start office god knows when
PostPosted: April 2nd, 2020, 12:11
Bump ,
I am still interested to get resources ,If some guy can help please
PostPosted: April 15th, 2020, 4:46
00050006
WDC WD20SMZW-11YFCS0-01-01A01-WD-WXF1AB7DJU24.rar [12.04 MiB]
Downloaded 42 times
PostPosted: April 17th, 2020, 8:01
jerry1 wrote:
00050006
Thanks a Tonn Boss ,I will Try This Once I am In My Office After Covid 19 Lockdown is over
Users browsing this forum: BGman and 80 guests
