 Post subject: Seagate 1.5TB not being detected through SATA
PostPosted: March 28th, 2020, 20:07
I have an old Seagate Backup plus portable that I shucked. The model of the HDD is ST1500LM006 which is a Samsung Spinpoint drive.
When I put it into the PC with a SATA cable, its not being detected. Works fine through the USB port with the SATA to USB adapter built in. Can anyone help?
https://www.newegg.ca/seagate-model-stdr2000101-2tb/p/N82E16822178436?item=9SIA9H5ADZ2420&source=region&nm_mc=knc-googleadwordscamkpl-pc&cm_mmc=knc-googleadwordscamkpl-pc-_-pla-aero+malls+inc.-_-hard+drives+-+portable+external-_-9SIA9H5ADZ2420&gclid=Cj0KCQjwpfHzBRCiARIsAHHzyZrbVYu6Lb7dnKu5uAcR_IzrbLH2g4MptA8_JbSO7N0DU15nGRJylc0aAhdhEALw_wcB
 Post subject: Re: Seagate 1.5TB not being detected through SATA
PostPosted: March 29th, 2020, 1:21
I just tried live booting through Gparted, no luck
PostPosted: March 30th, 2020, 18:04
Does it spin up?
PostPosted: March 30th, 2020, 19:57
If it works fine through the Seagate USB adapter but not directly SATA connected, it's probably due to a sector size mutation that the USB adapter is doing. Good data recovery software should still be able to access the files, but to get the drive mounting again will require you to initialize and partition it again. Or just keep operating through the USB.
PostPosted: April 2nd, 2020, 23:44
Does it spin up?
I couldnt tell this via SATA. But certainly spins up through USB.
PostPosted: April 2nd, 2020, 23:46
The HDD is empty, dont mind formatting. What software o you recommend on windows? and do you mean that I may need to format each time I boot?
PostPosted: April 3rd, 2020, 0:06
I was wondering whether the drive has been configured to Power Up In Standby (PUIS).
PostPosted: April 5th, 2020, 14:08
How do I check this?
Can you recommend a way to partition? Whats a good software?
Users browsing this forum: Google Adsense [Bot] and 24 guests
