 Post subject: Interpreting smartctl output in this odd-looking case
PostPosted: June 18th, 2020, 10:15
I bought a new drive on Amazon. When it arrived, I ran a smartctl test when value 9 (power on hours) was 0 hours. Recently I saw a second test in the log which confused me because it had over 40,000 hours. I ran a third test to confirm the order of the log, it goes newest to oldest. See the output here now showing all three tests, third test (40 hours), second test (0 hours), third test (40829 hours).
I also noticed that the are three errors logged at 40829 hours. How is this possible? Could someone have noticed they have a failing drive (the errors happened), ran a test, dropped the power on hours to 0, then sold it on amazon? Is there something I'm not understanding, and this really is a new drive? I'm really confused by this.
~/ sudo smartctl -a /dev/sde
smartctl 6.6 2016-05-31 r4324 [x86_64-linux-4.15.0-106-generic] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     MB4000ECWLR
Serial Number:    PAGZSAET
LU WWN Device Id: 5 000cca 22bcdfabc
Firmware Version: HPG3
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ATA8-ACS T13/1699-D revision 6
SATA Version is:  SATA 3.0, 3.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Wed Jun 17 05:34:25 2020 EDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (   24) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        No Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        ( 533) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Error Recovery Control supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0027   138   100   054    Pre-fail  Always       -       76
  3 Spin_Up_Time            0x0023   100   100   024    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       2
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002f   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0025   140   100   020    Pre-fail  Offline      -       26
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       40
10 Spin_Retry_Count        0x0033   100   100   060    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       2
180 Unknown_HDD_Attribute   0x002b   100   100   098    Pre-fail  Always       -       0
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
185 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       161
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   052   048   000    Old_age   Always       -       48 (Min/Max 29/52)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       4
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       4
194 Temperature_Celsius     0x0022   125   117   000    Old_age   Always       -       48 (Min/Max 23/52)
196 Reallocated_Event_Count 0x0033   100   100   000    Pre-fail  Always       -       0
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
ATA Error Count: 3
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        SC = Sector Count Register [HEX]
        SN = Sector Number Register [HEX]
        CL = Cylinder Low Register [HEX]
        CH = Cylinder High Register [HEX]
        DH = Device/Head Register [HEX]
        DC = Device Command Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 3 occurred at disk power-on lifetime: 40829 hours (1701 days + 5 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  04 51 08 00 00 00 00  Error: ABRT
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  b1 c0 00 00 00 00 e0 00      00:00:02.226  DEVICE CONFIGURATION RESTORE [OBS-ACS-3]
  27 00 00 00 00 00 e0 00      00:00:02.224  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  ec 00 01 00 00 00 e0 00      00:00:01.813  IDENTIFY DEVICE
  42 00 01 01 00 00 40 00      00:00:01.802  READ VERIFY SECTOR(S) EXT
  ec 00 01 00 00 00 e0 00      00:00:01.800  IDENTIFY DEVICE
Error 2 occurred at disk power-on lifetime: 40829 hours (1701 days + 5 hours)
  04 51 00 00 00 00 00
  ec 00 00 00 00 00 00 00      00:00:01.799  IDENTIFY DEVICE
Error 1 occurred at disk power-on lifetime: 40829 hours (1701 days + 5 hours)
  10 51 01 3f 94 52 03  Error: IDNF 1 sectors at LBA = 0x0352943f = 55743551
  25 d0 01 3f 94 52 40 00      00:00:02.979  READ DMA EXT
  25 d0 01 87 52 6a 40 00      00:00:02.963  READ DMA EXT
  25 d0 04 00 00 00 40 00      00:00:02.945  READ DMA EXT
  25 d0 01 af be c0 40 00      00:00:02.926  READ DMA EXT
  25 d0 01 01 00 00 40 00      00:00:02.926  READ DMA EXT
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%        40         -
# 2  Short offline       Completed without error       00%         0         -
# 3  Short offline       Completed without error       00%     40829         -
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Users browsing this forum: No registered users and 121 guests
