Hi Techs,
I found out the issue with the drive. It has a very burnt IC, it was under a metal guard that protects the ribbon cable.
Was wondering if my board repair guy(he's excellent fixes 5 MacBook logic boards a day), could try replacing the blown chip from the donor or if maybe that 6 legged chip(X17 ZB) was important that's next to it. The chips have different markings, even though the donor board is an exact match.
If I just swap the donor board it has a blinking green light. Is there EEPROM or other memory chip on these that needs to be swapped?
I have a deepspar, but I can also send it to my friend with a PC-3000 to get a better diagnosis, or maybe find a place that can do a hot swap, but from what I've read matching head maps on these is a nightmare.
Appreciate any input you have?
Thanks in advance!
