 Post subject: Loader for WD10SPZX-22Z10T1
PostPosted: April 7th, 2021, 5:18
Hello everybody,
does anybody have a loader for WD10SPZX-22Z10T1 - Firmware Version is 0005008J.
Thank you very much.
 Post subject: Re: Loader for WD10SPZX-22Z10T1
PostPosted: April 7th, 2021, 9:09
I just found a possible one at http://files.hddguru.com/download/PC-30 ... ty/Palmer/
I will try it.
PostPosted: April 7th, 2021, 9:32
Very strange. I tried a loader from same firmware version 0005008J that i found at http://files.hddguru.com/download/PC-30 ... ty/Palmer/ but when I try to upload loader PC3K says: VCS ERR OFF TOO LARGE.
Is this possible? Same Fimware Version, but different loader?
PostPosted: April 7th, 2021, 10:25
Here you are
Mikippp
05.8JD.zip [743.07 KiB]
Downloaded 17 times
PostPosted: April 7th, 2021, 11:31
Thank you very much. Unfortunatly it says: VSC ERR OFF TOO LARGE.
But I found one in http://files.hddguru.com/download/PC-30 ... ty/Palmer/
"WDC WD10SPZX-00Z10T0-01-01A01-WD-WXH1A88A10X9.rar
WD10SPZX-00Z10T0 - ROM F/W version: 00050006"
This one worked fine. Unfortunatly HDD won't get good access to SA.
I can do a Head Test and it works fine with no errors, but I can't read the modules... Does this make any sense?
Any Idea about this case?
PostPosted: April 9th, 2021, 1:48
Stupid question, but I assume you're using a special "unlocked" PCB?
PostPosted: April 9th, 2021, 12:45
Yes, I use an unlocked PCB.
PostPosted: April 9th, 2021, 13:00
Have you checked if its the original ROM?
You can do this by checking the WWN number.
Users browsing this forum: No registered users and 45 guests
