 Post subject: Canvio Advance (HDTC9******A) FAIL
PostPosted: October 23rd, 2021, 13:19
hello everyone, this is the second toshiba canvio advance 2.5 external that breaks without any warning, exactly 1 month after the warranty expires.
The models are Canvio Advance (HDTC9******A).
Right away I noticed that they had problems with windows 10 64bit, when I wanted to safely disconnect them, they would stay connected, (I read a lot about it, the only way was to use diskpart and remove all dismount) which never happened to me before toshibas!
I have a reallocated sectors error, also I only see 0.99Tb total and 994Gb free
PS: I make 3 copies for my photos and documents, they are 2.5 drives I never keep them on only when I make copies of new files, they are in an isolated box. So I don't need much speed for reading and writing. What disks do you recommend? I haven't lost any data for about 20 years, I started with Maxtor, Seagate then after their decline I started using WD, I wanted to drop in price and switched to Toshiba, but the experience was bad.
Besides WD can you recommend any good brands? I'm at 3.5TB, so a 4TB would be good.
Thanks for your help
I attach the report of cristaldisk
CrystalDiskInfo 8.12.12 (C) 2008-2021 hiyohiyo
                                Crystal Dew World: https://crystalmark.info/
    OS : Windows 10  [10.0 Build 19042] (x64)
  Date : 2021/10/23 18:53:58
-- Controller Map ----------------------------------------------------------
+ Intel(R) 100 Series/C230 Chipset Family SATA AHCI Controller [ATA]
   - SAMSUNG MZNLN256HCHP-000L2
- Controller spazi di archiviazione Microsoft [SCSI]
- BayHubTech Integrated MMC/SD controller [SCSI]
-- Disk List ---------------------------------------------------------------
(01) SAMSUNG MZNLN256HCHP-000L2 : 256,0 GB [0/0/0, pd1] - sg
(02) TOSHIBA MQ03UBB300 : 3000,5 GB [1/0/0, sa1]
           Model : SAMSUNG MZNLN256HCHP-000L2
        Firmware : EMT23L0Q
   Serial Number : S22YNXAGA13645
       Disk Size : 256,0 GB (8,4/137,4/256,0/----)
     Buffer Size : Sconosciuto
     Queue Depth : 32
    # of Sectors : 500118192
   Rotation Rate : ---- (SSD)
       Interface : Serial ATA
   Major Version : ACS-2
   Minor Version : ATA8-ACS version 4c
   Transfer Mode : SATA/600 | SATA/600
  Power On Hours : 11456 ore
  Power On Count : 2629 volte
      Host Reads : 41862 GB
     Host Writes : 38487 GB
     Temperature : 35 C (95 F)
   Health Status : Buono
        Features : S.M.A.R.T., NCQ, TRIM, DevSleep
       APM Level : ----
       AAM Level : ----
    Drive Letter : C: D:
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
05 100 100 _10 000000000000 Settori riallocati
09 _97 _97 __0 000000002CC0 Ore accensione
0C _97 _97 __0 000000000A45 Cicli accensione
AA 100 100 _10 000000000000 Blocchi riservati non usati (Chip)
AB 100 100 _10 000000000000 Fallimenti programma (Chip)
AC 100 100 _10 000000000000 Fallimenti cancellazione (Chip)
AD _86 _86 __5 00000000011F Wear Leveling
AE _99 _99 __0 00000000007E Mancanze alimentazione inaspettate
B2 100 100 _10 000000000000 Blocchi riservati usati (chip)
B4 100 100 _10 000000000305 Blocchi riservati non usati (totali)
B8 100 100 _97 000000000000 Rilevamento errore
BB 100 100 __0 000000000000 Errori non correggibili
C2 _65 _40 __0 000000000023 Temperatura
C7 100 100 __0 000000000000 Errori CRC
E9 _85 _85 __0 000000DB4394 Wear-out normalizzato media
F1 _99 _99 __0 000000009657 Scritture LBA (totali)
F2 _99 _99 __0 00000000A386 Letture LBA (totali)
F9 _99 _99 __0 000000011F90 Specifico del produttore
-- IDENTIFY_DEVICE ---------------------------------------------------------
        0    1    2    3    4    5    6    7    8    9
000: 0040 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 5332 3259 4E58 4147 4131 3336 3435 2020 2020 2020
020: 0000 0000 0000 454D 5432 334C 3051 5341 4D53 554E
030: 4720 4D5A 4E4C 4E32 3536 4843 4850 2D30 3030 4C32
040: 2020 2020 2020 2020 2020 2020 2020 8010 4000 2F00
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0110
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0F00
070: 0000 0000 0000 0000 0000 001F 850E 00C6 016C 006C
080: 03FC 0039 746B 7D01 4163 7469 BC01 4163 407F 0001
090: 0004 0000 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 32B0 1DCF 0000 0000 0000 0008 4000 0000 5002 538D
110: 0000 0000 0000 0000 0000 0000 0000 0000 0000 401E
120: 401C 0000 0000 0000 0000 0000 0000 0000 0021 0000
130: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0001
170: 2020 2020 2020 2020 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 003D 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 0001 0000 0000
220: 0000 0000 107F 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0000 0800 0000 0000 0000 0000
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 F7A5
-- SMART_READ_DATA ---------------------------------------------------------
     +0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 01 00 05 33 00 64 64 00 00 00 00 00 00 00 09 32
010: 00 61 61 C0 2C 00 00 00 00 00 0C 32 00 61 61 45
020: 0A 00 00 00 00 00 AA 32 00 64 64 00 00 00 00 00
030: 00 00 AB 32 00 64 64 00 00 00 00 00 00 00 AC 32
040: 00 64 64 00 00 00 00 00 00 00 AD 33 00 56 56 1F
050: 01 00 00 00 00 00 AE 32 00 63 63 7E 00 00 00 00
060: 00 00 B2 13 00 64 64 00 00 00 00 00 00 00 B4 13
070: 00 64 64 05 03 00 00 00 00 00 B8 33 00 64 64 00
080: 00 00 00 00 00 00 BB 32 00 64 64 00 00 00 00 00
090: 00 00 C2 32 00 41 28 23 00 00 00 00 00 00 C7 3E
0A0: 00 64 64 00 00 00 00 00 00 00 E9 13 00 55 55 94
0B0: 43 DB 00 00 00 00 F1 32 00 63 63 57 96 00 00 00
0C0: 00 00 F2 32 00 63 63 86 A3 00 00 00 00 00 F9 32
0D0: 00 63 63 90 1F 01 00 00 00 00 00 00 00 00 00 00
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53
170: 03 00 01 00 02 85 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 6F
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 01 00 05 0A 00 00 00 00 00 00 00 00 00 00 09 00
010: 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 00
020: 00 00 00 00 00 00 AA 0A 00 00 00 00 00 00 00 00
030: 00 00 AB 0A 00 00 00 00 00 00 00 00 00 00 AC 0A
040: 00 00 00 00 00 00 00 00 00 00 AD 05 00 00 00 00
050: 00 00 00 00 00 00 AE 00 00 00 00 00 00 00 00 00
060: 00 00 B2 0A 00 00 00 00 00 00 00 00 00 00 B4 0A
070: 00 00 00 00 00 00 00 00 00 00 B8 61 00 00 00 00
080: 00 00 00 00 00 00 BB 00 00 00 00 00 00 00 00 00
090: 00 00 C2 00 00 00 00 00 00 00 00 00 00 00 C7 00
0A0: 00 00 00 00 00 00 00 00 00 00 E9 00 00 00 00 00
0B0: 00 00 00 00 00 00 F1 00 00 00 00 00 00 00 00 00
0C0: 00 00 F2 00 00 00 00 00 00 00 00 00 00 00 F9 00
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0
       Enclosure : TOSHIBA External USB 3.0 USB Device (V=0480, P=0820, sa1)
           Model : TOSHIBA MQ03UBB300
        Firmware : JP050U
   Serial Number : X8NDT2XJT
       Disk Size : 3000,5 GB (8,4/137,4/3000,5/3000,5)
     Buffer Size : 16384 KB
     Queue Depth : 32
    # of Sectors : 5860533168
   Rotation Rate : 5400 RPM
       Interface : USB (Serial ATA)
   Major Version : ATA8-ACS
   Minor Version : ----
   Transfer Mode : SATA/300 | SATA/300
  Power On Hours : 7 ore
  Power On Count : 11 volte
     Temperature : 30 C (86 F)
   Health Status : Pericolo
        Features : S.M.A.R.T., APM, NCQ
       APM Level : 0080h [ON]
       AAM Level : ----
    Drive Letter : Z:
01 100 100 _50 000000000000 Errori lettura
02 100 100 _50 000000000000 Prestazione medie
03 100 100 __1 0000000014C1 Tempo avvio motore
04 100 100 __0 00000000001B Avvia/ferma conteggio
05 __1 __1 _50 000000003FF8 Settori riallocati
07 100 100 _50 000000000000 Errori seek
08 100 100 _50 000000000000 Prestazioni tempo seek
09 100 100 __0 000000000007 Acceso da (ore)
0A 100 100 _30 000000000000 Riavviamenti motore
0C 100 100 __0 00000000000B Cicli ON/OFF dispositivo
BF 100 100 __0 000000000000 Errori G-Sense
C0 100 100 __0 000000000006 Ritrazioni allo spegnimento
C1 100 100 __0 000000000038 Cicli load/unload
C2 100 100 __0 00270017001E Temperatura
C4 100 100 __0 00000000037B Eventi riallocazione
C5 100 100 __0 000000000000 Settori scrittura pendente
C6 100 100 __0 000000000000 Settori non correggibili
C7 200 253 __0 000000000000 Errori CRC UltraDMA
DC 100 100 __0 0000000000B2 Scostamento disco
DE 100 100 __0 000000000003 Ore lavoro
DF 100 100 __0 000000000000 Tentativi load/unload
E0 100 100 __0 000000000000 Carica frizione
E2 100 100 __0 000000000109 Tempo caricamento
F0 100 100 __1 000000000000 Ore volo testina
        0    1    2    3    4    5    6    7    8    9
010: 2020 2020 2020 2020 2020 2058 384E 4454 3258 4A54
020: 0000 8000 0000 4A50 3035 3055 2020 544F 5348 4942
030: 4120 4D51 3033 5542 4233 3030 2020 2020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00
050: 4000 0200 0000 0007 3FFF 0010 003F FC10 00FB 0110
060: FFFF 0FFF 0007 0007 0003 0078 0078 0078 0078 0108
070: 0000 0000 0000 0000 0000 001F EF06 0004 004C 0040
080: 01F8 0000 746B 7D09 6163 7449 BC09 6163 203F 8112
090: 8112 0080 FFFE 0000 0000 0000 0000 0000 0000 0000
100: A3B0 5D50 0001 0000 0000 0000 6003 0000 0000 0000
110: 0000 0000 0000 0000 0000 0000 0000 0000 0000 401C
160: 0000 0000 0000 0000 0000 0000 0000 0000 0003 0000
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
210: 0000 0000 0000 0000 0000 0000 0000 1518 0000 0000
220: 0000 0000 103F 0000 0000 0000 0000 0000 0000 0000
230: A3B0 5D50 0001 0000 0001 0080 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 7AA5
000: 10 00 01 0B 00 64 64 00 00 00 00 00 00 00 02 05
010: 00 64 64 00 00 00 00 00 00 00 03 27 00 64 64 C1
020: 14 00 00 00 00 00 04 32 00 64 64 1B 00 00 00 00
030: 00 00 05 33 00 01 01 F8 3F 00 00 00 00 00 07 0B
040: 00 64 64 00 00 00 00 00 00 00 08 05 00 64 64 00
050: 00 00 00 00 00 00 09 32 00 64 64 07 00 00 00 00
060: 00 00 0A 33 00 64 64 00 00 00 00 00 00 00 0C 32
070: 00 64 64 0B 00 00 00 00 00 00 BF 32 00 64 64 00
080: 00 00 00 00 00 00 C0 32 00 64 64 06 00 00 00 00
090: 00 00 C1 32 00 64 64 38 00 00 00 00 00 00 C2 22
0A0: 00 64 64 1E 00 17 00 27 00 00 C4 32 00 64 64 7B
0B0: 03 00 00 00 00 00 C5 32 00 64 64 00 00 00 00 00
0C0: 00 00 C6 30 00 64 64 00 00 00 00 00 00 00 C7 32
0D0: 00 C8 FD 00 00 00 00 00 00 00 DC 02 00 64 64 B2
0E0: 00 00 00 00 00 00 DE 32 00 64 64 03 00 00 00 00
0F0: 00 00 DF 32 00 64 64 00 00 00 00 00 00 00 E0 22
100: 00 64 64 00 00 00 00 00 00 00 E2 26 00 64 64 09
110: 01 00 00 00 00 00 F0 01 00 64 64 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 78 00 00 5B
170: 03 00 01 00 02 FF 00 F6 01 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A
000: 10 00 01 32 00 00 00 00 00 00 00 00 00 00 02 32
010: 00 00 00 00 00 00 00 00 00 00 03 01 00 00 00 00
020: 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00
030: 00 00 05 32 00 00 00 00 00 00 00 00 00 00 07 32
040: 00 00 00 00 00 00 00 00 00 00 08 32 00 00 00 00
050: 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00
060: 00 00 0A 1E 00 00 00 00 00 00 00 00 00 00 0C 00
070: 00 00 00 00 00 00 00 00 00 00 BF 00 00 00 00 00
080: 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00
090: 00 00 C1 00 00 00 00 00 00 00 00 00 00 00 C2 00
0A0: 00 00 00 00 00 00 00 00 00 00 C4 00 00 00 00 00
0B0: 00 00 00 00 00 00 C5 00 00 00 00 00 00 00 00 00
0C0: 00 00 C6 00 00 00 00 00 00 00 00 00 00 00 C7 00
0D0: 00 00 00 00 00 00 00 00 00 00 DC 00 00 00 00 00
0E0: 00 00 00 00 00 00 DE 00 00 00 00 00 00 00 00 00
0F0: 00 00 DF 00 00 00 00 00 00 00 00 00 00 00 E0 00
100: 00 00 00 00 00 00 00 00 00 00 E2 00 00 00 00 00
110: 00 00 00 00 00 00 F0 01 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 36
Users browsing this forum: No registered users and 123 guests
