 Post subject: Question for experts on 4Kn
PostPosted: March 1st, 2024, 19:55
Hi everyone.
is it possible to identify a 4K disk from the label ?
https://www.westerndigital.com/products ... ku=0B35946
the datasheet shows two model numbers for the 6TB SATA disk, SE or TCG but there is not specific part number for 4K or 512e.
this is a WD webshop link which allows one to select 4K or 512e however no other retailers have this option available so I don't know what am I trying to purchase
 Post subject: Re: Question for experts on 4Kn
PostPosted: March 1st, 2024, 21:43
https://documents.westerndigital.com/content/dam/doc-library/en_us/assets/public/western-digital/product/data-center-drives/ultrastar-dc-hc300-series/data-sheet-ultrastar-dc-hc310.pdf
PostPosted: March 2nd, 2024, 23:29
this datasheet is useless because it doesn't show the part # number
this applies to the other datasheet, there is no model number for the pure 4Kn disks
https://documents.westerndigital.com/co ... series.pdf
I found out an older datasheet and this time I can see the 4Kn disks model number
https://documents.westerndigital.com/co ... le-pin.pdf
maybe this indicates WD is no longer manufacturing 4K disks in that size so the product description on the website is absolutely BS because they are mostly 512e disks.
PostPosted: March 3rd, 2024, 20:59
read the datasheet again
PostPosted: March 3rd, 2024, 22:50
I have to read nothing.
if you have the model number of the 4Kn disks send it to me.
PostPosted: March 4th, 2024, 1:24
the model numbers are in the datasheet
PostPosted: March 4th, 2024, 13:27
What a friendly and nice dude you are.
PostPosted: March 4th, 2024, 17:45
Either you're too lazy, or incapable of understanding English.
This is your model number: HUS726TxTALE6yz
xT = Capacity of this model (6T = 6TB, 4T = 4TB)
E6⁹ = Interface (512e SATA 6Gb/s)
512e models can be converted to 4Kn format and vice versa.
y = Power Disable Pin 3 status
    0 = Power Disable Pin 3 support
    L = Legacy Pin 3 config – No Power Disable Support
z = Data Security Mode
    1 = SED**: Self Encrypting Drive. TCG-Enterprise and Sanitize Crypto Scramble / Erase.
    4 = Base (SE)**: No Encryption. Sanitize Overwrite only.
    5 = SED-FIPS: SED w/ certification (SAS only).
** ATA Security Feature Set comes standard on SATA
PostPosted: March 6th, 2024, 4:22
how do you convert it without hacking the drive firmware ?
I did not mention it but it's gonna be used on a legacy system without GPT format support.
PostPosted: March 6th, 2024, 4:26
I posted above an older datasheet link and the 4Kn drives model number ends with N6 not E6.
PostPosted: March 6th, 2024, 10:24
So? Times have changed.
Hint: Read about "fast format".
PostPosted: March 8th, 2024, 9:53
on linux:
sg_format -vv --format --size=512 --fmtpinfo=0 /dev/sg$
or
sg_format -vv --format --size=4096 --fmtpinfo=0 /dev/sg$
on freebsd (same commands with sg_format as above) or with native camcontrol:
camcontrol cmd da$ -v -c "15 10 0 0 v:i1 0" 12 -o 12 "0 0 0 8 0 0:i3 0 v:i3" 512
camcontrol format da$ -v
or
camcontrol cmd da$ -v -c "15 10 0 0 v:i1 0" 12 -o 12 "0 0 0 8 0 0:i3 0 v:i3" 4096
This is full/long/slow/low level format (I prefer that) and also wipes out type2-protection if it exists (you likely don't want that). There are commands for fast format/conversion, but I had 512e-disks on hand that just won't work with AF/4k-sectors.
If the disk shows an "AF"-Logo, that means advanced format and 4k format is guaranteed.
Edit:
http://talesinit.blogspot.com/2015/11/f ... n-huh.html
PostPosted: March 8th, 2024, 11:33
mr44er wrote:
If the disk shows an "AF"-Logo, that means advanced format and 4k format is guaranteed.l
Prior to the introduction of FastFormat, HDD manufacturers made separate 512e and 4Kn SATA models. Both carried the AF logo. Nowadays AF drives can be instantly reformatted as one or the other.
https://wiki.archlinux.org/title/Advanced_Format#Advanced_Format_hard_disk_drives
If your SATA HDD supports multiple logical sector sizes and the optional ATA command SET SECTOR CONFIGURATION EXT (e.g. Seagate drives advertising FastFormat support), you can use hdparm to change between the supported logical sector sizes.
This is Seagate's whitepaper on the subject:
https://www.seagate.com/files/www-content/product-content/enterprise-performance-savvio-fam/enterprise-performance-15k-hdd/_cross-product/_shared/doc/seagate-fast-format-white-paper-04tp699-1-1701us.pdf
Users browsing this forum: No registered users and 141 guests
