 Post subject: Reallocated Sector Count...
PostPosted: May 15th, 2005, 10:32
Hi !
My Maxtor 6Y160P0 has a lots of bad sectors which I "repaired" using mhdd and other programs. After this operation there is one problem with SMART:
Reallocated Sector Count 1 1 63
...so smart status is alert . Has someone any idea how to repair this error ? or maybe is any way to change this attribute to correct ..or something else ?
ps. sorry for my bad english :) :roll:
PostPosted: May 15th, 2005, 12:16
If you reset this attribute, you will have all your defects back. :-)
PostPosted: May 15th, 2005, 13:38
.... or maybe is any way to hide this attribute and it makes possibility that smart status will be OK lol :] ?
PostPosted: May 15th, 2005, 14:16
Well, you can kill the smart at all by erasing smart module from firmware. I don't know other way :-)
PostPosted: May 15th, 2005, 15:55
Try rewriting a new SMART module from drive with good SMART status.
PostPosted: May 16th, 2005, 2:38
How can I do that ? Which program can do it?
PostPosted: May 16th, 2005, 3:12
It will not help you...
PostPosted: May 16th, 2005, 3:40
Why not?
First move G-List to P-list, and write good SMART attrib module.
 Post subject: an easy way
PostPosted: May 16th, 2005, 4:03
If you have remaped all bad blocks from you HDD just run the Maxtor utility Powermax - its short diagnostic (90 seconds test). It will automatically reset the SMART attributes.
PostPosted: May 16th, 2005, 4:08
Why not?
and anything about move...
 Post subject: Re: an easy way
PostPosted: May 16th, 2005, 4:10
It not help me :( BTW: In another post, user Gustav wrote: „ SMART - hmmm
there is nothing to discuss about!
it is simple to "repair" the BAD status of the SMART !
when the status goes BAD you can empty G-LIST and add the sectors in the P-LIST !
go go go”
What does G-LIST and P-LIST means ? How can i move sectors from g-list to p-list ? Maybe a should ask him :P ?
PostPosted: May 16th, 2005, 7:24
Yes Valera My first post wasn't complete at all.
PostPosted: May 16th, 2005, 7:46
[quote="Wojo]
What does G-LIST and P-LIST means ? How can i move sectors from g-list to p-list ? Maybe a should ask him :P ?[/quote]
G-LIST means grown deffect list and P-LIST means primary deffect list. The fact that you are asking such a question means that you are not able to solve the problem by yourself. Please find a specialist to do the job for you! Otherwise you can damage the HDD.
PostPosted: May 16th, 2005, 14:21
A man learns from his own mistakes ... :)
PostPosted: May 17th, 2005, 5:02
Some people learn from the textbooks, Internet, etc. ...and from the others mistakes, too...
Good luck in learning!
PostPosted: July 12th, 2005, 6:34
Hello Dmitry, I have the same problem, but If I would like to reset this attribute even if bads will back, Is it easy to do this? If you would tell how Can I do this, I will be very pleased.
Thanks in advance
DAMON
PostPosted: July 12th, 2005, 9:52
That could be done by clearing G-List...
PostPosted: July 12th, 2005, 11:03
Here is what I would do:
1. Clear G-list,
2. fill the drive with zeroes,
3. check it for bads.
and if it worked, I would cool it hard in the rest of its life!
if it still contains bads, I would place it on my shelf maybe some day I can use its heads or other parts, hehehe :lol:
 Post subject: clear G-list
PostPosted: July 18th, 2005, 18:16
I don't understand!!!
when me clear G-list the drive dies I put drive in the garbage :? :? :?
to carry and to save firmware seagate
 Post subject: Re: clear G-list
PostPosted: July 18th, 2005, 18:29
OK.
the most of sectors are created by writing errors caused by overheating, and if U re-write all the sectors with drive cooled, you can get rid of them.
I wrote to erase Glist just to re-write the original sectors that became bad and not the reallocated ones.
There is nothing to worry about it, if they cannot be repaired by this method, the drive will re-assign them on the next try to read them.
correct me if I am wrong :)
Users browsing this forum: Google [Bot] and 19 guests
