 Post subject: Blue screen appeared
PostPosted: December 26th, 2007, 22:41
hi everyone..
i need some advice or suggestion here. my friend has 40gb Maxtor & not detect. so i do the process to make it detect & success. i've checked the bad sector & cleaned it in MHDD and i try to format it. all ok & then i pass it to her.a few days a go she gave it back to me & said blue screen appeared. so now i need to know what cause of the blue screen problem because when i check back i found error in module.
rgds
 Post subject: Re: Blue screen appeared
PostPosted: December 26th, 2007, 23:20
Most likely the drive is dying ... Either bad head or surface. The bad sectors are filling the limits of the G-List causing typical Maxtor firmware curruption ...
Just a guess.
Go buy a new hard drive.
By the way, what modules are damaged, what's the moddel of the drive and what tool are you using to fix it ?
PostPosted: December 27th, 2007, 5:42
hi spildit,
i'm sorry i didn't remember what module is damage because the hdd i already give it back to my friend yesterday. but i still remember the model is N40 & i'm using pc3k (pci)...
i already ask her to buy another one..ok thanks for your reply
PostPosted: December 27th, 2007, 12:17
A new drive should do the trick ;)
Users browsing this forum: No registered users and 61 guests
