Post new topic Reply to topic  [ 984 posts ]  Go to page Previous  1 ... 44, 45, 46, 47, 48, 49, 50  Next
 Post subject: Re: Unlocking ATA Password for Western Digital
PostPosted: January 22nd, 2016, 17:13
Hi guys, I have a problem( My HDD MDL:WD3200BEKT-60PVMT0 ATA Password locked. I don't know Master and User....Please tell me how to unlock it. I tried (WDR-Demo and clear password, no unlock), ZU.exe not unlock. If you can give a link to a tutorial on reading password in MHDD. When I tried script in MHDD I get an error DRQ
Sorry for my English =(
PostPosted: January 29th, 2016, 18:23
Locked SA access when password is present.
Use WDMarvel instead.
Method 2 - Universal.
If not you will need to block SA access and edit module 02 and write it back whithout the drive loading to RAM the locked firmware.
HOT swap with unlocked compatible drive will do as well.
PostPosted: January 29th, 2016, 18:29
will not help any program if there is no drq,ie not correctly selected channel
PostPosted: March 26th, 2016, 8:38
Hi, I new to this forum I learned a lot on how to read 22.bin ...
I have a panasonic CF-53 any HDD or SSD I put inside get a password.
I have two SSD with password yet, so I put a old WD hdd inside, bios also put password on it.
I really need to know the password, I will be able to unlock 2 SSD
So I managed to read 22.bin from my WD2500BEVS
Thanks for the help,
Best regards.
22.zip [444 Bytes]
Downloaded 398 times
PostPosted: March 26th, 2016, 16:23
@hayk57
I've replyed to you on my forum. Please check :
http://www.hddoracle.com/viewtopic.php?f=3&t=1541
Regards.
PostPosted: May 12th, 2016, 23:33
hi guys, thank you for this thread.
I reset my HDD using RedoBackup system, I didn't know it will ask for a password!!
my HDD is ATA WDC wd1600bevt-75zct2
i found it here:
https://forum.hddguru.com/viewtopic.php ... &start=120
but i tried entering
241e32..etc
and the other password as well and couldn't open it
is there a way to enter the passwords?
i am extremely new to these things so please help me what should i do?
PostPosted: May 12th, 2016, 23:36
Spildit, please help i don't care about the data i just want to use my HDD.
PostPosted: May 13th, 2016, 15:25
Either you figure out what is the password that RedoBackup sets by contacting them, for example (i assume RedoBackup did something like secure erase on the target drive) or you get some tools/scripts to read the password set ON YOUR OWN disk (instead of using passwords from drives of other people).
You can use free tools like HDDSuperTool - http://www.hddoracle.com/viewtopic.php?f=22&t=1327 - to read module 02 and figure out the password, or you can use MHDD script as explained on this thread or you can pay $15 for 30 days use of WDMarvel and unlock the drive with one click :
Regards and good luck.
PostPosted: May 13th, 2016, 20:56
Spildit, thanks for your time.
I have put a bios password and I know it & I can enter the bios and change settings, but the password doesn't work with the HDD.
I read here that the redo backup factory reset does not put a password to any HDD
actually the interface when i boot is from Dell Company exactly like this pic (but different serial)
http://www.online-unlock.com/UserFiles/ ... d_595B.gif
https://sourceforge.net/p/redobackup/di ... /dcebd388/
i'm going to use your suggested tools as well as other tools suggested in the link above and see what will happen.
I really appreciate your help.
PostPosted: May 13th, 2016, 22:40
two people had the same issue with redobackup
https://sourceforge.net/p/redobackup/di ... /28ce1c25/
two aggreed with your suggestion by using MHDD
could you please provide me with MHDD downlod link? i tried this one
http://hddguru.com/download/software/mh ... 4.6iso.zip
there is only REDME.txt file in the ISO and nothing else.
PostPosted: May 13th, 2016, 23:49
thank you so muck for helping me.
i am really happy my drive worked again.
i tried the MHDD softwre (i found it in heren boot cd),
two people used the reset in redobackup and had the same issue, but one of them could review the source code of (reset in redo bckup) and found the password to be RESET, but this password could only be used in MHDD
and i did as they tried.
thank you very much for helping me, thanks to the open source philosophy, without it we would be slaves to the big companies where encryption is used for bad technical purposes.
and thanks to all whom support any open source project.
PostPosted: May 14th, 2016, 4:46
You could had used the MHDD script as explained here on the start of this thread and you would get the password from the WD HDD drive firmware (mod 02).
At any rate congratulations for your unlocked drive !!!
PostPosted: June 9th, 2016, 18:37
please tell me my password here is my 22.bin
PostPosted: October 18th, 2016, 19:06
Is there anyone who can find the password for my hdd?
bin files are also attached
bin.zip [84.05 KiB]
Downloaded 385 times
PostPosted: October 18th, 2016, 19:49
Has anyone ever even tried this with HDDSuperTool, with either the dump mod 02 script, or the dump mod 42 script for the older drives? And if they have, has anyone paid any attention to the screen output from those commands? :twisted: :twisted: :twisted:
Feed you like babies I have, and yet no one notices :roll:
http://www.sdcomputingservice.com
Home of HDDSuperClone and HDDSuperTool
PostPosted: October 19th, 2016, 2:34
http://www.sdcomputingservice.com/hddsupertool/scripts/wd_royl_dump_mod02?attredirects=0&d=1
# show the user and master passwords
seti $offset = 18 * 4
seti $offset = $offset + 0x32
seti $record_offset = scratchpad $offset w
seti $record_offset = $record_offset + 4
echo ""
echo "User password:"
printscratchpad $record_offset 32
seti $record_offset = $record_offset + 32
echo "Master password:"
PostPosted: October 20th, 2016, 13:48
Hey people,
Just to inform you that I have successfully unlocked a 2.5" WD HDD with zu.exe
WD3200BUCT-63TWBY0
Motherboard: Intel Board i946 (with C2D E6600 and 2x Samsung 1gb DDR2 667Mhz)
SATA Mode: Legacy
Boot from USB
The other drive I was trying to unlock (wd 500gb) and asked for help in my previous post is unusable - first sector (literally first) is bad, MBR is damaged and irreparable. Actually, it is unlocked and functional, but it is impossible to create a partition
PostPosted: October 20th, 2016, 17:01
If the drive were working properly, you should be able to write to the bad sector and the drive should then reallocate LBA 0 to a spare sector. Are you able to read other sectors? You could use a disc editor such as DMDE.
PostPosted: October 22nd, 2016, 17:22
I didn't try too much. I even have problems with disk initialization - first GPT and then convert to MBR. After that, I am able to make a partition, but it's impossible to format it.
Thanks for the DMDE, but I doubt I will try anything else
My next task is to unlock a Seagate 250gb (st3250310as)
Wish me luck
PostPosted: March 24th, 2017, 12:54
I know that this is an older thread but I have a WD Sporpio Blue hard drive Model: WD1600BEVT-75ZCT2 that is password protected. I have no idea what the user or Master passwords are. I've tried several things that I have read and do have the 22.bin file. I just don't know how to properly read it and I have tried several hex viewers. Any help is appreciated. I've attached my 22.bin file but changed the ext to .txt to be able to upload it.
22.txt [512 Bytes]
Downloaded 716 times
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 47 guests
