jjczopek wrote:
Hi!
I got two disks. Damaged disk, Maxtor 6Y060L0421001 has the D6FYA PCB and the good one has E4FYA PCB. Can I replace them with no problems, or maybe they are incompatibile?
If you are sure, the D6FYA is damaged, you need to measure the preamp first, before try the other pcb.
The pcb is phisically compatible, and maybe works with the bad drive.
If the rom content is uncompatible, nothing happens, only clicks. (safe for some minute)
But if you preamp is short, the new pcb will be fried as well....
Regards,
Janos
