 Post subject: Backup and Restore Android
PostPosted: January 10th, 2018, 20:46
Can HDDRawCopy be used to reliably backup and restore the full EMMC of a (Samsung Galaxy Note 5, SM-N920C) Android phone?
If so, what's the procedure for restoring the full image?
 Post subject: Re: Backup and Restore Android
PostPosted: January 11th, 2018, 15:42
By a restore you mean to restore to same phone or different board or just different eMMC (after upgrade to higher size so after resizing partitions) ????
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
PostPosted: January 12th, 2018, 14:36
Literally the same phone, unchanged.
PostPosted: January 12th, 2018, 17:41
if you will use any low level access as ISP or ChipOff and service box which will allows you to make full backup of eMMC (ROM1, ROM2, ROM3, RPBM, extCSD) then you can back to same state if you will rewrite those back into phone... HDDRAW Copy allows only access to ROM1 if Im not wrong
Best regards,
Boguslaw Rzepka,
PostPosted: January 13th, 2018, 8:18
That's a pity, but thanks for ruling out HDDRawCopy as a viable Android backup tool.
