 Post subject: Softcenter/FE Reader cannot ID FD32B08UCH1-49 Chip
PostPosted: May 14th, 2018, 19:59
Hi, I have a chip that I can't seem to ID in FE.
The chip comes from a Kingston 32GB USB stick (DT101 G3).
Controller:
PHISON
PS2251-07-V
U01613C
SSNHG2CF
Chip:
FD32B08UCH1-49
S1640- 3058161.06
Looks similar to this one, but 32GB (and one chip) instead of 64GB (http://flash-extractor.com/forum/viewtopic.php?t=9598)
On PC3K, I can see the ID, but I do not have this chip in the database, and I am unable to read the chip.
Does anyone have a datasheet for this chip?
Alternatively, does anyone know why it would ID with PC3K and not with FE?
 Post subject: Re: Softcenter/FE Reader cannot ID FD32B08UCH1-49 Chip
PostPosted: May 14th, 2018, 21:13
what is the ID of the chip from PC3K? ad 3a 18 03?
I see this ID in NR.
is this one of the chips that VCCQ requires 1.8v ? there has been some chips that will not ID with FE until you give VCCQ 1.8v and not 3.3v
do you have new power adapterhttp://flash-extractor.com/forum/viewtopic.php?t=9847?
http://www.flash-extractor.com/forum/viewtopic.php?t=9573
PostPosted: May 14th, 2018, 21:23
Yes you are correct. The ID in PC3K is 0xAD3A1803
Unfortunately, I do not have VNR.
PostPosted: May 14th, 2018, 21:30
I was talking about the new adapter for SC's NR. Of course VNR would be good as it gives you alot better control, and much more research ability anyway.
PostPosted: May 16th, 2018, 4:51
Controller:
PHISON
PS2251-07-V
U01613C
SSNHG2CF
Chip:
FD32B08UCH1-49
S1640- 3058161.06
I've just check the PC3K database and here it is:
Maybe you need to update the software?
PostPosted: May 16th, 2018, 13:38
Ah, sorry for the misunderstanding. I currently do not have the new power adapter for SC's NR, but it looks like I will be buying it soon.
PostPosted: May 24th, 2018, 21:22
Update:
I have the SC Power adapter, and I have it set to 1.8v.
However, it still does not ID this chip.
Could it be that the chip itself has failed?
PostPosted: May 25th, 2018, 1:42
Try 2.4V
You'll need an external PSU for this, to supply voltage into the adaptor via the external voltages pins.
Users browsing this forum: Google Adsense [Bot] and 21 guests
