Hello guys,,,
I was wondering if someone knows about this issue or had similar cases like this...
MicroSD memory added to Android Mobile (Android 6+ & higher) and you use it for a while (Enabled Encryption or not its the same)
when you pull it out and connect to windows you are able to READ its data but you CANNOT FORMAT/MODIFY it
no matter what you do, it says Format done, but nothing changes... DATA remains the same (either Encrypted or not)
anyone got similar to this scenario?
Note: I came up with a result about this matter and wanted to verify with those who had similar cases...
you may PM if don`t want to go public about it...
thank you
