July 5th, 2022, 3:57
Friends ,
Acelab is focussed on few chipsets in SSD data recovery ,I came across a few chinese brands that are heavily dominating the Indian SSD sales ,I would like to ask my friends in india and other countries how is the sales of SSD in your countries ,Like in india we have Silicon Motion , Phison and now some other brand chipsets ,These chipsets are just not supported by the tools ,Does anyone of you know anything about this ...
PS : You can even get a SSD manufactured by chinese guys with HDDGURU written on it
Brand : Consistent " India Company Selling Under its Branding "
Chipset : RTS5733DLQ
Research : Company is Realtek
The latest update from acelab is here ->
https://blog.acelab.eu.com/pc-3000-ssd- ... dated.html . No Support for SSD's that are heavily dominating sales .Also friends does some of you have a tool to identify these working or non working SSD/s so that we could see the chipset without opening the SSD in general .
July 5th, 2022, 8:09
Eventually I always find myself on some Chinese forum when trying to find info on devices like these
https://www.mydigit.cn/forum.php?mod=vi ... tid=155152
July 5th, 2022, 12:33
Did you read this after conversion to english ,From what i can understand its the Factory Tool to program The SSD and Not a Data Recovery tool ,Also its for the RTS5732DL .
July 6th, 2022, 9:55
Amarbir[CDR-Labs] wrote:Hi,
Yes, I did, it was just an example. No it's not a data recovery tool indeed, basically a MPTool like the ones for UFD's. Basically anyone can poop out an SDD with custom firmware/parameters.
July 6th, 2022, 18:47
I suspect that the PCB may be a reference design.
July 6th, 2022, 23:53
fzabkar wrote:I suspect that the PCB may be a reference design.
Yes ,
That could be ,the reason is that so many factories are producing the same stuff be it SM ,phison or this realtek .While googling i read that some of the firmware in this realtek are buggy .I did see a factory tool i think from SM that did have a data recovery option in its last tab ,I remember one of the pro data recovery guy here on hddguru boasting about recovering that particular series of SM SSD's " though in reality it was that they were using that tool " .
July 7th, 2022, 0:03
I find it strange that there is an unpopulated DC-DC converter with an output labelled "DDR1V8". This suggests that the PCB can support an optional SDRAM. However, there is no space reserved for a DRAM. Alternatively, if there is a version of the controller with an embedded SDRAM, I would have expected to see an unpopulated 1.8V bypass capacitor near the controller, but this doesn't appear to be the case, either.
July 7th, 2022, 0:22
Well,
I will try to upload more clear images today for this please
August 12th, 2022, 18:54
Have you tried dumping the chips to check for encryption?
Perhaps such a weak controller dismissed that feature.
August 13th, 2022, 4:37
DRUG wrote:Have you tried dumping the chips to check for encryption?
RTS5732DLQ encrypt the data so chance that RTS5733DLQ will too is high.
http://flash-extractor.com/library/Real ... 98_3f__2x4
August 13th, 2022, 14:49
This appears to be the same PCB design, but with an RTS573
5DLQ controller and no external "ROM":
https://ireland.apollo.olxcdn.com/v1/files/xd9hv4wv0wau2-UA/image
October 30th, 2022, 3:52
Friends,
I have another Consistent SSD Now ,This one is with the supported SSd controller ,Can you people help me with safe mode points , The picture is here
The Drive Goes into Safe Mode With This , Might be i am wrong ?
PS :I have PC3K UDMA With SSD Addon Updated Till Ver 7.0 , Version 7.1 has New loaders for SM2259XT ,With My Version I Get errors after loader upload ,Can we add new loaders to pc3k if yes how
November 2nd, 2022, 14:05
Hi !
I have the same pcb SSD. My is: KingFast F10.
I have 7.1 pc3000, but still i can't load fw(loader). I'm getting error : Sector read error(LBA: 21 930); HDD DMA RQ timeout (10000)
Did you resolved that case?
November 8th, 2022, 10:54
mehaniz wrote:Hi !
Hey
if your support at acelab is there can you take support and check
September 28th, 2023, 20:43
Still without solution ??
2023
September 28th, 2023, 22:21
