October 1st, 2023, 6:14
October 1st, 2023, 6:48
October 1st, 2023, 7:31
October 1st, 2023, 7:48
October 1st, 2023, 8:12
October 1st, 2023, 10:05
October 1st, 2023, 19:04
tcccorp wrote:do you know if there is a way to have a SWD or JTAG pins on PCB? I didn't find a datasheet :(
October 2nd, 2023, 2:25
October 2nd, 2023, 3:52
October 5th, 2023, 14:58
October 5th, 2023, 15:18
October 5th, 2023, 15:20
Unlikely - the controller itself is probably fine, the firmware is stored on the nand chips .tcccorp wrote: So I think if I m able to change controler, it ll work?
October 7th, 2023, 5:18
Lardman wrote:tcccorp, This might give you a little insight - http://www2.futureware.at/~philipp/ssd/ ... Manual.pdf
October 7th, 2023, 5:22
Lardman wrote:Unlikely - the controller itself is probably fine, the firmware is stored on the nand chips .tcccorp wrote: So I think if I m able to change controler, it ll work?
October 7th, 2023, 16:20
October 14th, 2023, 5:50
October 16th, 2023, 17:39
