 Post subject: Kingston DT101G2 16GB [ Controller SSS6695 ,Strange NAND ]
PostPosted: December 29th, 2016, 7:52
Hello Everyone ,
Got This Drive [ USB Flash ] , God Why The Hell Cannot i Get Simple Cases To Learn And Earn [ Arvika ,Jermyb And Haque Can You Folks Tell Me Come Controllers and Memory Chips That i Can Help Myself In The Learning Process ] .This is a Kingston DT101G2 16GB .The Thing Is That It Has a Controller SSS6695 That is Not Present Here - > http://www.flash-extractor.com/library/SSS/ And Also Here -> http://www.pc-3000flash.com/solbase/ind ... 1&lang=eng .I Do Not Have Access To Rusolut [ Sasha I Am Saving Money For This Now ,Might Be You Can Extend The Curtsy To The Forums ] .The NAND Chip Was Also Having a Very Rare Marking " FT16B08UCT2-55" Which ID's As " 0x983AA892 " .This ID Possibly Is Quite Common In Acelab Global Solution Center .Has Anyone Worked On This Exact Combination ? . I Have Read The NAND ID And Now i Am Reading The Same ,Once Done I Will Work On This a Little And Let You Know Whats The Progress In This Case .
Controller Details By One Software Are Below
Controller: SSS 6695 BD
Possible Memory Chip(s): Not available
VID: 0C76
PID: 0005
Screenshot Of Progress
 Post subject: Re: Kingston DT101G2 16GB [ Controller SSS6695 ,Strange NAND
PostPosted: December 29th, 2016, 8:13
Start from older Phison controllers.
PostPosted: December 29th, 2016, 12:15
Any specific models and whats special in these
PostPosted: December 30th, 2016, 12:03
Sir ,
Nailed This One Too ...
Preparations should be:
1. Possible Bad Columns cutting;
2. XOR;
3. ECC on XOR;
4. First typical Interleave;
5. Second typical Interleave;
Then - RAW on last string of transform graph. Right now it's not possible to build image for SSS6695-6-7-8 family. Translator under developing.
PS : Acelab does not have a ready translator for this hence data in file structure wise was not possible ,Is this possible with Rusolut And Softcenter Tools As Of Now ? .Case is Solved Though
Users browsing this forum: Google [Bot] and 20 guests
