HDD GURU FORUMS http://forum.hddguru.com/ |
SanDisk X300s Power issue? http://forum.hddguru.com/viewtopic.php?f=10&t=36442 |
Page 2 of 2 |
Author: | fzabkar [ February 21st, 2018, 17:04 ] |
Post subject: | Re: SanDisk X300s Power issue? |
Here is one more important question that needs an answer. Attachment: why.jpg [ 73.46 KiB | Viewed 12329 times ] |
Author: | mrcico [ February 26th, 2018, 23:44 ] |
Adisa wrote: pcimage wrote: On this device, it’s much more likely that it’s suffering from firmware damage and/or flash degradation than an actual electronic fault. Looks like you are correct. It get BSY state as soon as its recieve any ATA command. According to ACE, there is no solution for that issue yet. Anyone who had success fixing this? I killed 4 of them with diskpart / clean command. I'm sure disk's stuck at busy state and unable to access them. Most probably i'll send them to rma but i opened one for investigation. I hope i find out something to fix. |
Author: | fzabkar [ February 27th, 2018, 0:15 ] |
mrcico wrote: [I killed 4 of them with diskpart / clean command. I'm sure disk's stuck at busy state and unable to access them. Most probably i'll send them to rma but i opened one for investigation. I hope i find out something to fix. Could you at least take the same measurements as the OP so that we can compare? In particular, could you measure the voltage at the "0V capacitor"? Photos of your PCB may also be good for comparison purposes. For example, your ICs will probably have different date codes. This can be useful when identifying part markings. BTW, Diskpart merely writes zeros to the drive. I can't see how it could have killed your drives, unless they already had other problems. |
Author: | fzabkar [ March 5th, 2018, 3:41 ] | |||||||||||
Post subject: | Re: SanDisk X300s Power issue? | |||||||||||
Can you measure the voltages in the photo clips? References: 88SS9190-BJM2, Marvell, 4-channel flash controller TPS22965, Texas Instruments, 5.7V, 6A, 16mO Load Switch With Adjustable Rise Time and Optional Quick Output Discharge, marking ZSA0, 8-pin: http://www.ti.com/lit/ds/symlink/tps22965.pdf TPS62085, Texas Instruments, adjustable 3A Step-Down Converter with DCS-Control and Hiccup Short Circuit Protection, 2x2 HotRod Package, marking PD5Q, 7-pin: http://www.ti.com/lit/ds/symlink/tps62087.pdf http://www.ti.com/lit/ug/slvu809/slvu809.pdf TLV71318, Texas Instruments, 4-pin, 150-mA, 1.8V, capacitor-less LDO Regulator, marking AW: http://www.ti.com/lit/ds/symlink/tlv713p.pdf TLV71310, Texas Instruments, 4-pin, 150-mA, 1.0V, capacitor-less LDO Regulator, marking ET: http://www.ti.com/lit/ds/symlink/tlv713p.pdf TPS3897, Texas Instruments, 6-pin, Adjustable Supervisory Circuit with Active-High, Open-Drain Output, marking UM: http://www.ti.com/lit/gpn/tps3897 TMP103, Texas Instruments, 1.4V Temperature Sensor, I2C/SMBus, 4-pin WCSP, marking TA: http://www.ti.com/lit/ds/symlink/tmp103.pdf
Author: | fzabkar [ March 5th, 2018, 3:44 ] | ||||
More images:
Author: | mkorosec [ January 12th, 2021, 11:32 ] | ||||||||
I have the same drive, SanDisk X300. I did the measurements on points you marked.
Author: | fzabkar [ January 12th, 2021, 16:03 ] |
ISTM that those voltages are OK. |
Page 2 of 2 | All times are UTC - 5 hours [ DST ] |
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
