 Post subject: Apple mz-cpa2560 ssd
PostPosted: March 3rd, 2018, 8:55
Hi guys, got this one in...when put into adapter nothing happens and adapter is not recognized by system, adapter alone is recognized...so some kind of short is it.
I have a good drive to cross-check with and all power measure looks ok, in the picture the voltage is the same on both working and non working drive.
The chip close to connector is:
7MAE
913
The other half way up is:
CAT
06W
ZH7D
Thanks for looking
http://www.rescue-it.se
 Post subject: Re: Apple mz-cpa2560 ssd
PostPosted: March 3rd, 2018, 15:24
Why are you powering a 3.3V SSD from a 5V adapter?
MP5003EQ, Monolithic Power, 3.3V, 1A-3A Programmable Current Limit Switch with Auto Enable, QFN10, marking 7M:
https://www.monolithicpower.com/DesktopModules/DocumentManage/API/Document/GetDocument?id=1407
TPS62410, Texas Instruments, 2.25MHZ 2x800mA Dual Step-Down Converter with 1-Wire Interface, Vin = 2.5V - 6V, QFN10, marking CAT:
http://www.ti.com/lit/gpn/tps62410
PostPosted: March 3rd, 2018, 15:43
The adapter is a proper Envoy from OWC and works fine with working ssd's.
PostPosted: March 3rd, 2018, 15:59
No, it isn't "proper". Please STOP using it. The correct adapter would supply 3.3V via its own 3.3V LDO regulator. Your adapter is supplying 4.60V. That in itself says something about your "+5V" supply.
Please read the label of your client's SSD.
The only reason that your SSD is working with this adapter is that the MP5003EQ IC is protecting your client's data by limiting the output voltage to 4.04V. In doing so it is dissipating approximately 0.5W when it should be dissipating nothing.
PostPosted: March 3rd, 2018, 16:13
Ok, I will check that out...thanks for pointing it out.
Then they sell adapters with wrong voltage, and thats scary.
PostPosted: March 3rd, 2018, 16:19
Can you show us photos of your adapter's electronics? Is it powered from the USB port?
PostPosted: March 3rd, 2018, 16:25
Yep it's powered by usb. I will be in at office by monday, will get it then.
PostPosted: March 3rd, 2018, 16:41
USB 3.0 allows for a maximum current of 0.9A. ISTM that an appropriate adapter should be powered from its own supply rather than drawing current from a USB port.
PostPosted: March 3rd, 2018, 18:06
The adapter that been used is this one from OWC, designed for that SSD:
https://eshop.macsales.com/item/Other%2 ... 1520105353
PostPosted: March 3rd, 2018, 18:32
It's only USB 2.0 (20 - 30 MB/s) and ...
0GB for Apple MacBook Air 2010 & 2011 Flash Drive (SSD)
I'd be very keen to see inside. Something is not right.
PostPosted: March 3rd, 2018, 18:50
Yep it's usb 2.0, I'm not in a hurry :wink: ...and the 0Gb means that it's just an empty enclosure...no ssd included.
I have used it for years on maby 100's jobs, and it has always does it job...make me clone the ssd.
Specifically made for 2010-2011 MacBook Air SSDs, but when adapter is removed, will work with any 2.5" SATA hard drive or SSD up to 2.2TB in capacity and up to 12.5mm in size.
eSATA/FireWire 800/USB 2.0 Assembly Manual, Model # OWCMEPM944Q1B, OWCMEPM934Q1B:
https://eshop.macsales.com/tech_center/manuals/OWCMANMEPMQ.pdf
https://eshop.macsales.com/tech_center/index.cfm?page=/manuals/item/mercminial.html
ISTM that the enclosure and its bridge PCB are OK, but the internal adapter is faulty or inappropriate.
PostPosted: March 3rd, 2018, 19:06
Here is an adapter with a 3.3V (?) LDO regulator:
You should have something like that inside your enclosure, preferably with a switchmode regulator rather than linear.
PostPosted: March 3rd, 2018, 19:16
USB 2.0 has an 0.5A current limit. ISTM that you should invest in a DC adapter for the enclosure.
PostPosted: March 4th, 2018, 17:30
For the frustration I went into the office today and checked the ssd with another adapter...and the incoming power on the ssd was 3.29v...so no problem there.
There is no power problem on that ssd, "only" firmware corruption.
Thanks for looking
PostPosted: March 4th, 2018, 18:40
In another thread (?) someone posted the following "test points". Could they be shorting points for safe mode?
PostPosted: March 4th, 2018, 19:05
Yes they are.
PostPosted: March 4th, 2018, 19:06
I've recovered this model with PC3K, but getting to safe mode is trickier than one would want.
RAID Data Recovery
PostPosted: March 5th, 2018, 6:42
Firmware fixed, and drive now cloning.
PostPosted: March 5th, 2018, 6:43
Yep, very true.
Users browsing this forum: arvika and 8 guests
