 Post subject: Sandisk datasheet
PostPosted: March 6th, 2018, 4:52
Hello guys,,
anyone knows the datasheet for this Sandisk?
i was searching and seems cannot find it
thank you
 Post subject: Re: Sandisk datasheet
PostPosted: March 6th, 2018, 6:00
You won't find datasheet very likely, we figured out pinout long time ago using XRAY.
This is BGA-154 chip, in VNR starter kit you can find special adapter but you'll need to reball the chip (this one is easy).
If you have problem with NAND config drop me message
VISUAL NAND RECONSTRUCTOR. A big revolution in chip-off data recovery
PostPosted: March 6th, 2018, 6:04
Just found a picture of device, it was reballed.
PostPosted: March 6th, 2018, 6:19
Thank you Sasha...
the Sandisk Expert... i really forgot to ask you 1st. about it.
this is my 1st. case with such BGA-154 here
thank you again.... i`ll dig more here and will let you know if needed help
have a good day :wink:
PostPosted: March 6th, 2018, 10:48
Its rare chip, quite often need read as 16-8bit.
Odzyskiwanie danych
PostPosted: March 7th, 2018, 3:59
@ arvika
maybe thats why no info. about it yet.
