 Post subject: Toshiba USB I/O error
PostPosted: April 13th, 2018, 12:43
I have this error with this Toshiba Transmemory 16GB USB.
VID:04B3 PID:3025
I have successfully flashed a Kingston that had the same error using Phison UPTool but that would only leave the drive "usable" erasing everything.
The I/O refers to the controller, right? I could "just" do a chip-off recovery.
 Post subject: Re: Toshiba USB I/O error
PostPosted: April 13th, 2018, 18:58
yes for IO error, either fix PCB problems (resistor short/open or broken solder joints) or chip-off.
PostPosted: April 13th, 2018, 19:13
Google tells me that VID:04B3 PID:3025 is an "IBM SK-8825 KeyBoard" or "CHICONY USB NetVista Full Width Keyboard". :?
PostPosted: April 13th, 2018, 19:48
Don't search like that
http://flashboot.ru/iflash/
PostPosted: April 13th, 2018, 20:07
Also you can use this:
http://www.flashdrive-repair.com/2013/1 ... tware.html
PostPosted: April 13th, 2018, 20:43
AFAICT, 0x04B3 is IBM's VID. Toshiba's VID is 0x0930.
http://www.users.on.net/~fzabkar/USB_IDs/uvcview_vid_nam.txt
http://usb.userbenchmark.com/SpeedTest/4802/TOSHIBA-TransMemory
http://www.tomshardware.com/answers/id-2715491/toshiba-transmemory-8gb-formatting-problems.html
https://github.com/brandonlw/Psychson/issues/14
https://www.webfoobar.com/node/24
    Toshiba Transmemory 8GB / 32GB -> VID = 0930, PID = 6544 / 6545
PostPosted: April 14th, 2018, 15:40
Hmmm weird, that is what I got with ChipGenius!!
PostPosted: April 14th, 2018, 15:50
As per Chipgenius instructions, disconnect all other things usb from your computer before running it. It probably is detecting your keyboard, or you really have a fake usb drive.
PostPosted: April 14th, 2018, 19:50
When controller goes bad, anything can be reported. regardless of what it is reporting, just read the chip.
is it a monolith or what is the controller and chip? what did CG say the nand ID is?
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 13 guests
