micro SD question
http://forum.hddguru.com/viewtopic.php?f=10&t=36696
Author:  jerovsek [ April 16th, 2018, 7:59 ]
Post subject:  micro SD question
is possible to get pads description for following Transcend and Kingston micro SD cards
Best regards
Author:  fzabkar [ April 16th, 2018, 18:53 ]
Post subject:  Re: micro SD question
Maybe you can find it in the documentation for an appropriate adapter?
https://multi-com.eu
BTW, I reduced your 3.4MB image to less than 30KB just by cropping and converting to JPEG.
Author:  jerovsek [ April 17th, 2018, 4:08 ]
Thank you Mr. Žabkar
I Will keep in mind file size for next time :)
Author:  HaQue [ April 17th, 2018, 6:51 ]
Also for the Kingston one
Can't see the back clear enough to know what pinout it is
If it is the same you don't mention it
Good way to take picture is to put MicroSD near a white wall or and shine a desk lamp on the wall so you don't get glare. Angle phone or camera various ways until the back PCB is visible
If you play around with this method you can determine pcb/pinout without removing coating
