 Post subject: iPhone 3GS data recovery, does chip-off work?
PostPosted: May 5th, 2018, 13:02
Or does the device need to be repaired due to encryption? not sure when Apple started doing that.
TIA
 Post subject: Re: iPhone 3GS data recovery, does chip-off work?
PostPosted: May 5th, 2018, 16:36
i4 is crypted for sure. 3G not crypted, 3GS not crypted too (based on one case quite long time ago).
Odzyskiwanie danych
PostPosted: May 6th, 2018, 5:00
+10
Encryption started from 4S
PostPosted: May 6th, 2018, 11:20
TIA
This Phone Model is Not Encrypted .Chip off work properly
PostPosted: May 31st, 2018, 11:44
I have had a 3GS in for recovery a while ago. We did a chip off and the data was encrypted. I think the 3GS is where they started testing encryption, so some are and some aren't encrypted.
PostPosted: December 4th, 2018, 7:48
Hi Michal, do you remember what layout you used, or tool?
Are you speaking from experience, did you dump and recover? If so would you say which tool and give any details?
I have a 3GS chip here.
package: LGA52
marking: Micron 9VA18
Crystals: 4 x 4GB
ID : 2c d7 94 3e
Bus : 8 bit
page : 3420
possibly could be software bad columns.
Anyone done chip off on these? not convinced this is encrypted as entropy not all that high.
PostPosted: December 4th, 2018, 9:55
I have done a chip off on the 3GS and it was encrypted. FWIK, the 3 was not encrypted, the 3G is where they were testing encryption and the 3GS is was full encryption. However there may be variations to this.
PostPosted: December 4th, 2018, 19:21
Thanks for that, cheers
