 Post subject: PLZ GURUS SAMSUNG SSD 850 PRO MACAFEE ENCRYPTION
PostPosted: May 24th, 2018, 8:26
This ssd has MACAFEE ENCRYPTION i did tray to PSID revert but wont work kindly help me to decryption of this drive.
 Post subject: Re: PLZ GURUS SAMSUNG SSD 850 PRO MACAFEE ENCRYPTION
PostPosted: May 24th, 2018, 18:33
You will need the mcaffee decryption software, the code of the day and the decryption key.
https://www.mjm.co.uk/
PostPosted: May 30th, 2018, 4:43
well thx to reply but i dont have any code or decryption key is there any way to force decrypt the drive bcoz i dont need any data from it any solution ?
PostPosted: May 30th, 2018, 6:10
Just reformat the SSD if you don't care about the data and want to reuse it.
Recovery Force Data Recovery
PostPosted: May 30th, 2018, 13:32
we can probably help you if interested, we are based in Faisalabad.
Do let me know if you are interested ? @ 03006689939
Data Recovery Pakistan
PostPosted: May 30th, 2018, 13:34
my bad, sorry if you dont need data why bother to decrypt it ? as mentioned by Luke just format it use it.
good luck
PostPosted: June 2nd, 2018, 3:33
Well its wont format until its decrypted thats why i am looking for solution i have try many tools bt still wont format...
PostPosted: June 11th, 2018, 4:28
THX
Every one for such a nice comment i have unlock the ssd and its work fine now my apology it was TCG OPAL security which i found in Samsung magician watever it was i will share how did i unlock this drive with (sedutil)https://github.com/Drive-Trust-Alliance/sedutil/wiki/PSID-Revert
here is the file http://www.mediafire.com/file/u638377asinna3c/RESCUE32.img.gz/file
which u can tansfer to usb drive with Disk Image Writer and follow the commands on website hope this will help others user.
PostPosted: June 14th, 2018, 5:06
Spildit wrote:
Thanks for sharing this info/solution !
Welcome and its good to hear a positive response from you Spildit as i seen many time you did cooperate with many user which explain u a good person i have seen many forums expert wont even reply your topic but Gurus are decent and special long live Spildit :P
Users browsing this forum: Google [Bot] and 75 guests
