 Post subject: PLZ GURUS SAMSUNG SSD 850 PRO MACAFEE ENCRYPTION
PostPosted: May 24th, 2018, 8:26
This ssd has MACAFEE ENCRYPTION i did tray to PSID revert but wont work kindly help me to decryption of this drive.
 Post subject: Re: PLZ GURUS SAMSUNG SSD 850 PRO MACAFEE ENCRYPTION
PostPosted: May 24th, 2018, 18:33
You will need the mcaffee decryption software, the code of the day and the decryption key.
<itch>
скратчи
PostPosted: May 30th, 2018, 4:43
well thx to reply but i dont have any code or decryption key is there any way to force decrypt the drive bcoz i dont need any data from it any solution ?
PostPosted: May 30th, 2018, 6:10
Just reformat the SSD if you don't care about the data and want to reuse it.
RAID Data Recovery
PostPosted: May 30th, 2018, 13:32
we can probably help you if interested, we are based in Faisalabad.
Do let me know if you are interested ? @ 03006689939
Data Recovery Pakistan
PostPosted: May 30th, 2018, 13:34
my bad, sorry if you dont need data why bother to decrypt it ? as mentioned by Luke just format it use it.
good luck
PostPosted: June 2nd, 2018, 3:33
Well its wont format until its decrypted thats why i am looking for solution i have try many tools bt still wont format...
PostPosted: June 2nd, 2018, 9:07
It doesn't make sense.
MACAFEE ENCRYPTION is SOFTWARE ONLY and the encrypted data is stored on the SSD as sector data (LBA). It shouldn't "lock" the SSD in any way.
Power up the SSD in a known good computer and try to detect it with MHDD/Victoria/etc ... Can you see the SSD ? Does it report as locked ? If not try to ERASE the ssd with those mentioned tools. Can they write to the SSD ? ALL DATA WILL BE GONE.
If you can't write to the SSD by LBA then the SSD is broken ...
PostPosted: June 11th, 2018, 4:28
THX
Every one for such a nice comment i have unlock the ssd and its work fine now my apology it was TCG OPAL security which i found in Samsung magician watever it was i will share how did i unlock this drive with (sedutil)https://github.com/Drive-Trust-Alliance/sedutil/wiki/PSID-Revert
here is the file http://www.mediafire.com/file/u638377asinna3c/RESCUE32.img.gz/file
which u can tansfer to usb drive with Disk Image Writer and follow the commands on website hope this will help others user.
PostPosted: June 11th, 2018, 9:12
Thanks for sharing this info/solution !
PostPosted: June 14th, 2018, 5:06
Welcome and its good to hear a positive response from you Spildit as i seen many time you did cooperate with many user which explain u a good person i have seen many forums expert wont even reply your topic but Gurus are decent and special long live Spildit :P
